I just got 5.9 hood louver vents for my ZJ - JeepForum.com
Closed Thread
post #1 of 77 Old 11-09-2013, 11:18 AM Thread Starter
kirkham715
Just won on eBay. Paid $130 which was more than I had planned, but the bidding was heavy.
Good but used shape with intact drip pans and all the screws. Came from a 5.9 owner who is parting out his Jeep.
My Plans (and I am open to your ideas)
I plan to mount on my '95 ZJ approximately where the 5.9 vents normally are
The openings between the fins of the vents seem too small to let much air out, so I plan to do some grinding to open them better. I saw someone in the forum do that recently and it seemed a good idea and would love to hear from whomever did that for tips.
I plan on finding longer screws and possibly spacers to open up greater air flow between the louvers and the drip pans.
Rather than a full rectangular opening or the smaller ovals of the original install, I plan on a swiss cheese area of 1-1.5 inch holes below the louvers which should preserve some of the hood and paint integrity. Some installers have commented about paint crinkling on the hood around the large holes they cut.
Finally the paint - I am keeping the white louvers for my white hood. I probably will use a can to spray several layers of primer then Duplicor and the just expect that I will have to pepaint in a few years.
Some things if you have tips...
I put several oven thermometers around the engine compartment and was getting 180 degree air consistently after even short rides on October days. In Los Angeles area where I am, summer days I am sure have engine compartment heat hitting higher than that. Would I be better off using some kind of high temp paint rather than the duplicolor. Should I use something like BBQ paint (black) around the holes I drill? Would professional paint job or powder coat be a better way to go.
Looking for your good ideas - Thanks
kirkham715 is offline
post #2 of 77 Old 11-09-2013, 11:44 AM
PolkaPower
I cut the entire portion of hood out under my vents minus the holes for the screws. Made a huge difference in the amount of hot air escaping. I can drive for several hours and the hood isn't hot to the touch afterward.
PolkaPower is online now
post #3 of 77 Old 11-09-2013, 12:18 PM
chaZJones
grinding the fins open wider seems pointless imo. its not like theres a massive volume of air that's going to be flowing through them. plus it will probably look bad. only my opinion
96 ZJ 5.2L 156k
chaZJones is offline
post #4 of 77 Old 11-09-2013, 01:36 PM
newfieZJ
Not so bad . I would go smaller next time .
Tape where you cut/drill , keeps the paint better intact . Use good tape , not some dollar store junk . 3M is good .
Wouldn't worry about any special heat paint .
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #5 of 77 Old 11-09-2013, 01:51 PM
riot1987
I didnt use 9er vents but I just cut giant gaping holes in my hood with an angle grinder
It came out great.
No bad paint.
My hood is plenty strong, not floppy because of the new holes.
I used a cookie pan for my drip trays.
Dont over think it man, mine work great and I used gd cookie pans..
Measure 3 times, cut.
Good luck chief
Build thread^^
riot1987 is offline
post #6 of 77 Old 11-09-2013, 03:14 PM
JasonStebbins
This thread has me intrigued. I picked up the entire hood of a 5.9L a few months ago for $50.00
Polka, you said you cut the hood out under the tray? What do you mean? And Newfie, are you using drip trays?
Poop
JasonStebbins is offline
post #7 of 77 Old 11-09-2013, 03:19 PM
PolkaPower
If you take the vents/ trays off of a 5.9 hood you will see that there are rather smallish ovals for the heat to escape. I just cut the rest of the hood like a big rectangle similar to riots but careful to leave the stock screw holes then painted and reinstalled the vents/trays. It vents heat much better now. I was going to put pacers in but when I felt how good it was keeping the hood cool after that I didn't see a need.
post #8 of 77 Old 11-09-2013, 04:32 PM
Pierre_r
1989 XJ Cherokee
Here is a great thread that shows how a 5.9 looks under the louvers and how to mod them so they will let out more heat.
http://www.jeepforum.com/forum/f13/5...t-mod-1370209/
Pierre_r is online now
post #9 of 77 Old 11-09-2013, 06:48 PM
newfieZJ
No drip trays , no problems either . Been 5 yrs now
newfieZJ is offline
post #10 of 77 Old 11-10-2013, 06:00 AM
JasonStebbins
I'll be doing what Zach did tomorrow afternoon. Didn't realize how constrictive the stock set up was.
Poop
post #11 of 77 Old 11-10-2013, 09:10 AM
PolkaPower
That's how I did mine except I didn't leave a support in the middle.
post #12 of 77 Old 11-12-2013, 01:19 AM
JasonStebbins
I'm trusting your word on this, no drip trays on mine anymore.
My hood actually had five small ovals, rather then three large ones like the other pictures. I actually made my rectangle about 1" larger then it was with the original holes.
I can't believe how restrictive the stock set up was, I never would have thought .
Poop
post #13 of 77 Old 11-16-2013, 09:01 AM
Lustra
Junior Member
Why hack your hoods for something that looks tacky and has no real purpose other then trapping dirt.
_______________________________________
We may have gotten off to a bad start , but , you are one ignorant SOB
Yes , the mileage is stored in the PCM , it's only available through a DRB scan, it is irrelevant to 99% of jeepers
What about the other 1%?
Lustra is offline
post #14 of 77 Old 11-16-2013, 10:31 AM
PolkaPower
They are quite functional in letting under hood heat vent from the engine bay.
post #15 of 77 Old 11-16-2013, 10:51 AM
JasonStebbins
They really do. Especially after you hack them larger. I think ZJs look better with the vents.
Poop
Closed Thread
