i hate whining..... - JeepForum.com
post #1 of 7 Old 09-25-2002, 05:35 AM Thread Starter
Big Dumb White Guy
Big Dumb White Guy's Avatar
i hate whining.....
especially when it comes from under the hood. it gets worse the faster you go. i think it is the a/c compressor. at least thats where it sounds like it is coming from. it even whines when at idle. something i can rebuild or do i have to replace???
4.0l I6
repost Nazi's suck!
A guy walks into the psychiatrist office wearing only Glad Wrap shorts. The shrink says, "Well, I can clearly see you're nuts."
Big Dumb White Guy is offline
post #2 of 7 Old 09-25-2002, 09:30 AM
moabster
moabster's Avatar
2011 WK
Stop your whining
Just a few ideas and a question.
Does it happen when the AC is both on and off? If so, it could be the AC Clutch. If the whine goes away when the AC is off it may be the compressor. How about the water pump? Is the serpentine (sp) belt orginal? If so, it may be time to replace it after 10 years. I had to replace my belt after about 5. My AC compressor started leaking at 7 years/72,000 miles. From what others have said, the 1993 air compressors went out often.
Good luck in stopping your whining.
2000 Jeep Grand Cherokee V8 Stock
93 YJ I6 hard top (really belongs to SPEED)
RE 4.5" Extreme Duty Lift, Advanced Adapters SYE, Tom Woods CV Drive Shaft, EA589 10" rims with 33" x 12.5" MT/Rs
Bullet Proof Front and Rear Bumpers and Tow bar
moabster is offline
post #3 of 7 Old 09-25-2002, 09:32 AM Thread Starter
Big Dumb White Guy
with a/c on and off it still whines.
is it possible to rebuild the a/c clutch???
repost Nazi's suck!
post #4 of 7 Old 09-25-2002, 10:35 AM
moabster
moabster's Avatar
2011 WK
I've only replaced an A/C clutch on an oldsmobile cutlass, and that was a 1971 one at that. It could not be rebuilt. I'm not sure about the A/C clutch on a GC. Check with an autopart store to see what they carry. New, rebuilds or kits. Other things to consider is the alternator and maybe power steering pump. Any of those things connected to the belt.
If it were my jeep, I think I would remove the belt for a few minutes and see if the whine is there when not turning any of the accessories. (For just a few seconds). Then try turning each item separately to see if you can tell where the whine is coming from.
Happy diagnosing
moabster is offline
post #5 of 7 Old 09-25-2002, 09:20 PM
Intrepidjeep
Intrepidjeep's Avatar
One old diagnostic trick is to press the blade or point of a long screwdriver against the body of the AC compressor and press your ear against the handle. You actually want to make sure your ear canal is 'closed' so that you only hear the noise coming through the screwdriver.
Press the point of the screwdriver against (unmoving) parts of other reachable components.
Sounds a little primitive, but it only takes a minute, it's free, and you're likely to find the whining part that way. Of course, be careful where you point that screwdriver.
Just don't post any messages that you hear voices in the engine, or your Jeep told you to do something, or anything really nuts like that . . .
-- Marcus
Cape Canaveral, Florida
2005 Jeep Grand Cherokee Laredo 4.7L
2005 Dodge Durango SLT 4.7L
Intrepidjeep is offline
post #6 of 7 Old 09-26-2002, 08:36 AM Thread Starter
Big Dumb White Guy
looks like we have a winner . the compressor was about 10x louder than the altenator.
screw it - next spring......
repost Nazi's suck!
post #7 of 7 Old 09-27-2002, 06:07 PM
gbgary
gbgary's Avatar
Originally posted by Big Dumb White Guy
if it ain't broke, you're not tryin' hard enough.
guess you did it.
'01 Black WJ Ltd. w/4.7; lowered street jeep w/ASE chip, H&Rs, Edelbrocks, K&N, Magnaflow, more.
street jeep and ranger
gbgary is offline
WJ Whining at 55-60 mph 2khb ZJ Grand Cherokee Forum 27 05-12-2011 08:26 PM
Whining still. Windowsrookie ZJ Grand Cherokee Forum 1 08-07-2008 12:42 PM
Whining RyanSBenson ZJ Grand Cherokee Forum 14 09-05-2007 05:05 AM
Whining noise when I let off the gas Myrtle Beach ZJ Grand Cherokee Forum 15 11-23-2004 09:18 AM
whining? darktiger ZJ Grand Cherokee Forum 0 12-09-2002 09:01 AM
