I found a 242 - JeepForum.com
post #1 of 29 Old 05-07-2009, 02:51 PM Thread Starter
shdybrady19
I found a 242
I found a 242 for about 200 bucks and its from a 96 grand cherokee just like mine. So that thing should bolt right in correct? Also since is has full time 4 wheel drive like my 249 wouldnt it have a viscous coupler as well?
1996 5.2 orvis: 6" lift, 33x12.50's, 8.8 rear, t-case skid, gas tank skid, 242
Originally Posted by nick62087 View Post
If you can weld and aren't afraid to take a chance, I'd say try it - someone's gotta do it.
LOOKING FOR 96-98 ZJ CARPET, TAN OR BLACK IN COLOR, ALSO LOOKING FOR HOOD HINGES. 93-95 MIGHT BE COMPATIBLE
shdybrady19 is offline
post #2 of 29 Old 05-07-2009, 06:03 PM
-cAcHe-
-cAcHe-'s Avatar
IT WILL NOT FIT!!! get it and send it to me ... <------ HAter......
if it is a real 242. it will not have a VC.check the case for the red round stamp..and make sure it says 242 on it.
Originally Posted by CarolinaWK View Post
I like happy endings :2thumbsup:
RIP Troy Edwards (bigbluezj94)
-cAcHe- is offline
post #3 of 29 Old 05-07-2009, 06:05 PM
crazymjb
The full time 4WD on the 242 is an open center diff, where as the full time 4wd on the POS 249 (mines on its way out) is a limited slip center diff. Basically, it locks up when it detects a certain amount of unequal apportioning, where as on a 242 if say you had both back wheels off the ground in full time 4wd, they would spin and no power would go to the front. But that doesn't really matter, since it has 4lock too... I honestly don't know why the hell jeep even made the 249s. This was going to be my next "fix" but since I'm replacing my plenum gasket...
Mike
crazymjb is offline
post #4 of 29 Old 05-07-2009, 06:33 PM Thread Starter
shdybrady19
but if it is a 242 then it should bolt right in right? I was going to buy a 231 but decided not to because the one I see is a slip yoke and I am at 6 inch of life. I just want to get it in there soon
post #5 of 29 Old 05-07-2009, 06:39 PM
Virmagicus
Virmagicus's Avatar
It should bolt in yes .... the only problem you may encounter is the input shaft lengths. All of the ZJ 242's have the .840" exposed input which is about 7/8" Pull yours and you should be happy.
Jeff
Virmagicus is offline
post #6 of 29 Old 05-07-2009, 06:49 PM
Greengc4x4
It WILL bolt directly in. the input shaft is the exact same on all 96-98 242's and 249'2
Greengc4x4 is offline
post #7 of 29 Old 05-07-2009, 07:10 PM
crazymjb
Are there any durability differences between the 242 out of an I6 or V8? I know there are 242HDs out there, but if I have a 5.9 is that absolutely necessary?
Mike
crazymjb is offline
post #8 of 29 Old 05-07-2009, 07:16 PM
BlingBlingZJ
That transfer case is known to have a lot of problems so I am going to do you a favor and give you my 249 and $50 can you bring it over to the LA area?
2002 Grand Cherokee Limited-22's-HID Projector Headlights-40 Series FlowMaster-Airaid Intake-
BlingBlingZJ is offline
post #9 of 29 Old 05-07-2009, 07:22 PM
Virmagicus
Virmagicus's Avatar
Zero difference. The 242 can handle anything the 5.9 can throw.
Jeff
post #10 of 29 Old 05-07-2009, 07:29 PM
Virmagicus
Virmagicus's Avatar
I have an extra .... i'll be in Compton tomorrow.
Jeff
post #11 of 29 Old 05-07-2009, 07:33 PM
crazymjb
Is there a mileage ceiling one should be looking at when searching for these?
By the way guys, I'd recommend car-parts.com when searching for stuff at junk/salvage yards. There are TONS of 242s listed, some only a couple hundred bucks at our around 100K.
I know it is a direct bolt in, will the existing linkage need to be changed, or just the bezel?
Also, I have the center console computer which illuminates all four wheels when in 4hi, and none when in N, and all in 4Lo with a LOW light. Will the computer only display the rear wheels when in RWD, etc, or was the setup designed around the 249?
Mike
crazymjb is offline
post #12 of 29 Old 05-07-2009, 07:51 PM
coopdc
wow, a couple hundred bucks, and I cant get ne one to buy mine for 70 bucks with 120000 miles on it... wtf!
coopdc is offline
post #13 of 29 Old 05-07-2009, 08:17 PM
BlingBlingZJ
aww man I don't live in the ghetto no more, now I live in long beach
post #14 of 29 Old 05-07-2009, 08:21 PM
crazymjb
I'll give you 70 bucks for it, where in NY are you? I have a buddy up at school in Morrisville. I don't know if you are along the route back to MA but I could ask him if he would mind picking it up.
Mike
crazymjb is offline
post #15 of 29 Old 05-07-2009, 08:33 PM
Virmagicus
Virmagicus's Avatar
Haha ! Moving up are we ? Ready for that lift yet ?
Jeff
I Think i Found the Right One Mr Q X ZJ Grand Cherokee Forum 3 10-31-2006 05:12 PM
Found My 8.8!!!! randyszj94 ZJ Grand Cherokee Forum 41 10-02-2006 08:50 AM
Found It!!!!! ynotyj ZJ Grand Cherokee Forum 8 03-10-2006 11:32 AM
Look what I found 10achik ZJ Grand Cherokee Forum 21 03-07-2006 01:46 PM
I found mud jeepholic ZJ Grand Cherokee Forum 4 12-17-2004 07:32 PM
