i dont know what to do - Page 3 - JeepForum.com
post #31 of 39 Old 09-19-2013, 11:42 PM Thread Starter
dnuccio
Originally Posted by Smokey1r View Post
Did you flush the engine block prior to connecting the hoses to the radiator?, just to get all the loose particles you can out and assure there's proper pump flow?
i did, not much came out as far as foreign materials
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #32 of 39 Old 09-20-2013, 01:53 AM
98GCLimited
I know you have a 5.2 so its a little different animal than my 4.0 but I live in Havasu and its even a little hotter here than in Phoenix and my temp never goes over 210 in even 120 degree heat with AC OFF but when I turn the AC on with temps outside of 95 degrees or higher, if the engine is under a constant load like driving uphill for a few miles towards my house the temp gauge gets up to close to the next line after 210 and I just shut my AC off then since I am almost home within a couple miles anyway. I never really wanted to see how high the temp would go lol.
Hopefully you can get something figured out. Im at 144k miles still on stock radiator for sure and thermostat too as far as I know. Reman water pump replaced about 26k miles ago. Our factory cooling systems suck in high temps...
98GCLimited is offline
post #33 of 39 Old 09-20-2013, 06:33 AM
V65Ozzie
Silly question....is the fan installed the correct way?.....I've seen it happen......
Retreat? Hell, we just got here......
V65Ozzie is offline
post #34 of 39 Old 09-20-2013, 08:14 AM Thread Starter
dnuccio
as far as i can tell...the side of the fan blade marked "engine side" is facing the engine...
R.I.P. Ratmonkey
dnuccio is offline
post #35 of 39 Old 09-20-2013, 06:13 PM
ZeeJay1997
Originally Posted by Uniblurb View Post
Don't know if you've seen this video before Zee
yup, that's what i had in mind. i knew i had seen sumpthin about it
ZeeJay1997 is offline
post #36 of 39 Old 09-22-2013, 10:25 AM Thread Starter
dnuccio
so i disconnected the down pipes (well, the passenger side one, i couldnt get the exhaust to drop low enough to disconnect the drivers side) to release backpressure and ran it for about 30 miles at highway speeds. temp never went above 200*!
time to PM Kolak about a cat
R.I.P. Ratmonkey
dnuccio is offline
post #37 of 39 Old 09-22-2013, 10:57 AM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Try bypassing the AC compressor with a shorter belt. The compressor can put a lot of drag on the motor when the system ain't right.
Edit
I see you solved the problem, clogged cat.
HighLonesome is offline
post #38 of 39 Old 09-22-2013, 01:58 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
I might have guessed right,lol.
Originally Posted by HighLonesome
coralman is offline
post #39 of 39 Old 09-22-2013, 09:16 PM Thread Starter
dnuccio
for the time being, ive knocked a big hole in the bottom of the cat
R.I.P. Ratmonkey
dnuccio is offline
