I can't really make sense of the thermostat temp argument - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > I can't really make sense of the thermostat temp argument
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 05-10-2013, 04:05 PM   #16
BuzzZJ9er
Originally Posted by PolkaPower
You get like 50 hp if you put a 180* stat in though.
I'm on it! :lmbo:
BuzzZJ9er is offline   Reply With Quote Quick reply to this message
Unread 05-10-2013, 04:16 PM   #17
Foundrydude
Originally Posted by PolkaPower View Post
I think they run hotter than they need to because of emissions laws.
They definitely run hotter because of emission laws.
Hotter is harder on gaskets, harder on oil, harder on the transmission, and harder on every underhood component. Heck everything non metal, from the paint on the hood to wire insulation is aging/curing at a rate determined by time and temperature.
I don't think it makes my engines last any longer, but always go to 180/190 stats to extend the life of everything within 2 feet of the engine.
However ratmonkey's comment about all engines ultimately reaching the same temp is true with mechanical fans or smallish electric fans. But with a killer pair of electric fans and a robust cooling system you can often keep an engine close to thermostat point for hours on end, even with a cool stat.
Foundrydude is offline   Reply With Quote Quick reply to this message
Unread 05-10-2013, 04:23 PM   #18
PolkaPower
This winter my motor would eventually get near operating temp but on the highway it was pretty low like 160* sometimes. Now that it has warmed up it's right around 190-200. I have a 180* stat in there and the trans is bypassed so it doesn't get heat from that. I think I am going to try a better brand stat though. I have a fail crap I think.
PolkaPower is offline   Reply With Quote Quick reply to this message
thermostat
