Quantcast I accidently topped off my coolant with Dex cool *pic* - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > I accidently topped off my coolant with Dex cool *pic*
Old 05-02-2007, 09:57 PM   #1
nitrox28
I wasn't paying attention and I topped off the coolant reservoir my Jeep with the coolant (diluted) I use in my Firebird. I don't think this will hurt anything but I want to make sure. Here's a pic of what I used. I guess I poured 3 or 4 cups in the tank.
-2002 WJ Laredo. 4..7, selec-trac, leather and loaded. Other than a Flowmaster Super 40 series muffler, it's all stock.
-1998 Green Laredo 4.0, Rusty's 2" BB, Skyjacker 3" softride w/SS, Nitro shocks, ARB Bullbar, KC's, 180 degree t-stat, Flowmaster 40 series, no cat, no rear swaybar, 31x10.50xSwamper SSR's, Eagle rims, K&N filter, Alpine system, bunch of other crap.
nitrox28 is offline   Reply With Quote
Old 05-02-2007, 09:57 PM   #2
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Did you mix colors?
ArloGuthroJeep is offline   Reply With Quote
Old 05-02-2007, 10:01 PM   #3
nitrox28
Yep. Green was in it. I just grabbed the wrong jug. But, the reservoir was almost empty so I guess it will mix with the green in the radiator.
Old 05-02-2007, 10:01 PM   #4
dooboy2112
2000 Grand Cherokee Limited
2000 Wranger Sport SOLD
1979 Wagoneer SOLD
http://www.oclakerfans.com/
dooboy2112 is offline   Reply With Quote
Old 05-02-2007, 10:05 PM   #5
gomes512
1994 ZJ
I don't know how it is now, but roughly two years ago there where many problems with dex-cool forming sludge when contaminated. Meaning that it was mixed with regular antifreeze or mineralized water.
You can probably thank Jiffy lube for that.
How much did you add? Might be better to just dump the radiator and pump out the reservoir then refill. Takes like 40 minutes of your time anyhow
gomes512 is offline   Reply With Quote
Old 05-02-2007, 10:08 PM   #6
K-Pax
K-Pax's Avatar
you may consider doing a flush/fill if the 2 are mixed....
Graphic Design student at NWACC (Northwest Arkansas Community College).
Kevin's rig:
94 Grand Cherokee Laredo
I-6 4.0L, Quadra-Trac on demand
2" budget lift
pro-comp steelies
kevin's radiator support bar
JKS quick discos
e-mail me
K-Pax is offline   Reply With Quote
Old 05-02-2007, 10:13 PM   #7
Briandl
Just pull out the reservoir and empty it...
Briandl is offline   Reply With Quote
Old 05-02-2007, 11:14 PM   #8
CallMe"Mcgyver"
you can take the reservoir out with just a couple of screws.
and if you think it got in the radiator, just twist the plug at the bottom and flush it.
Better safe then sorry.
--Paul
Integrity is who you are when no one is looking.
It's a stock WJ, but give me time. ...Maybe some money too?
A sketch of what I'm kinda building towards
CallMe"Mcgyver" is offline   Reply With Quote
Old 05-03-2007, 07:20 AM   #9
1BADDROP
Yes def change the fluid... It will sludge up... just did a motor in my buddies car he mixed coolant in the old motor and when we pulled the heads off there was sludge in the coolant passages!
1998 ZJ SE I-6 w/ 42RE & 242, D30 & D35 axles 4"+ suspension , Moabs with 33" Bighorns, Borla Header, Magnaflow Muffler
1BADDROP is offline   Reply With Quote
Old 05-03-2007, 08:18 AM   #10
micifus
Original GC'er
micifus's Avatar
look into prestones flush kit, its allows for your garden hose to be "plugged" into your coolant system doing an awesome job of flushing everything out.
1993 Jeep Grand Cherokee Limited 4.0L I6
- OME Springs - 30"x9.5" Yokohamma's A/T-S -RE Shocks - JKS Quicker Disconnects - FM70 - E-Fan Conversion - 249->242 Swap -
1970 Jeepster Commando 225 V6
32"x11.5" BFG A/T
4" Lift
1987 Suzuki LT230S Quadsport
1996 Artic Cat ZR580 EFI
2005 Honda TRX450R
"For every one thing I fix two things break"
micifus is offline   Reply With Quote
Old 05-03-2007, 08:29 AM   #11
QuadraTokn
1930 WJ
so this doesnt happen again just use the prestone or wally world stuff that mixes w/ any color antifreeze, you'll never grab the wrong one again!
I have a modified 1999 WJ and a stock 2001 WJ
Tread Lightly
Pictures
PARTED OUT 8 WJ Grand Cherokees ! ! ! ! ! !
QuadraTokn is offline   Reply With Quote
Old 05-03-2007, 12:54 PM   #12
cmonson
just siphon it out, or buy a pump.
cmonson is offline   Reply With Quote
Old 05-03-2007, 01:18 PM   #13
stageninja
That Rigger Guy
stageninja's Avatar
I don't use the stuff in my GM vehicle. It reportedly eats intake gaskets as it appeared to do in a buddy's Suburban. Which then needed a valve job.
stageninja is offline   Reply With Quote
Old 05-03-2007, 04:31 PM   #14
LeroyJMC
1994 ZJ
Ditto.........Deffinite ditto.
2009 Red Rock JK Unlimited Rubi
2006 Scion xA
1999 WJ Limited Quadradrive V8
1997 Chevrolet Z71
1994 ZJ Laredo 4.0 - Sold
Thanks for the IR Remote Smokinbk.
LeroyJMC is offline   Reply With Quote
Old 05-04-2007, 12:58 PM   #15
Dregan
If you already ran the engine (cycling the Dex Cool through and mixing it up) DEFINATELY do a full flush. If you didn't run the engine, pull the resevoir and drain/flush/fill it, and you should be fine.
The problem with the Dex is that it crystalizes and coagulates when you mix it with the green stuff. My dad has a 95 Olds Aurora, which uses the old green stuff, and my mother has a 97 Aurora, which uses the orange. Dad accidentally put the orange stuff in once, and it was like lumpy brown gravy when we flushed it out.
Dregan is offline   Reply With Quote
Glock Forum
