hub nut size? - JeepForum.com
post #1 of 10 Old 07-06-2009, 10:20 AM Thread Starter
Sontizzle
hub nut size?
i have to replace a torn CV boot on my drivers side and i need to know what size the nut it on the hub to get it off. and any other things i should know when replacing the boot
Sontizzle is offline
post #2 of 10 Old 07-06-2009, 10:22 AM
DHRFX Joe
2015 JK Wrangler
36mm socket for the axle nut, 12pt 13mm socket for the 3 unit bearing-to-knuckle bolts IIRC.
92 XJ -> 96 ZJ -> 04 WJ -> 15 JK
DHRFX Joe is offline
post #3 of 10 Old 07-06-2009, 10:24 AM
little_Jeep
What Jeep - WJ? 36MM. The axle shafts will come out without having to remove this nut or the hub......... HOWEVER, depending upon your axle, the CV joint may not be servicable and you will have to remove the hub as you will have to replace the entire axle shaft as a unit.
little_Jeep is offline
post #4 of 10 Old 07-06-2009, 11:01 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
just replace the whole axle, after the boot is torn most cv's are already dead.
ratmonkey is offline
post #5 of 10 Old 07-06-2009, 09:40 PM Thread Starter
Sontizzle
the axle is only a year or so old, the boot just ripped when i was off road
post #6 of 10 Old 07-06-2009, 09:45 PM
the88thpianoman
2003 WJ
Which means the joint is going to blow up sooner than later. You can wait till it does, or you can be proactive, but the joint probably can't be saved.
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here:
the88thpianoman is offline
post #7 of 10 Old 07-06-2009, 09:49 PM
StrokedWJ
StrokedWJ's Avatar
Where'd you get the axle from? Most aftermarket shafts i.e. Autozone, Advance Auto, O'Reilly's come with a "lifetime warranty". See if you can return it and get a new one (you can forget to tell them you ripped it while offroad)
2000 WJ 4.5L - Stroked, Locked, & Long-Armed
Looking for 6" WJ springs!
StrokedWJ is offline
post #8 of 10 Old 02-08-2015, 10:41 AM
NarleyBurritos
1994 ZJ
I'd replace the axle, and if they won't warranty it, keep it as a spare incase u snap one on the trail.
NarleyBurritos is offline
post #9 of 10 Old 02-08-2015, 11:02 AM
Pierre_r
1989 XJ Cherokee
I think he has, the thread is 6 years old.
Jeep Cherokee XJ 4.0 -89
Jeep Cherokee XJ 4.0 -90 (partsjeep)
Jeep Grand Cherokee 5.2 -93
Chevrolet Silverado 2500 6.5TD -94
Chevrolet C20 6.2 -82
Pierre_r is offline
post #10 of 10 Old 02-08-2015, 11:38 AM
Mickey_D
Also, for future reference - the original Chrysler shafts use a 36mm, the modern replacements sometimes use a 35mm.
Ask me how I know. I bought the 35mm socket along with the replacement shaft. Went to go pull the original and of course the socket didn't fit. So I said screw it and got a replacement bearing assembly as well and the shaft is still in the old bearing...
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
which size rim 2GRND4U ZJ Grand Cherokee Forum 2 12-10-2009 05:42 PM
rustys tir-rod jam nut size? Can't fine what size they said to get. bjl95mustang ZJ Grand Cherokee Forum 2 07-14-2007 08:41 AM
what size TravisL1213 ZJ Grand Cherokee Forum 34 02-28-2007 09:41 PM
Tire size match to lift size zjeepin ZJ Grand Cherokee Forum 5 09-04-2005 12:26 PM
Tire Size v. Lift Size Chart Meerkat ZJ Grand Cherokee Forum 10 02-01-2005 04:56 AM
