HUB Bearing bolts - any suggestions are much welcome - JeepForum.com
post #1 of 19 Old 01-30-2006, 09:28 AM Thread Starter
Maciej
I mentioned problem in another post but really need advice!
I could not unscrew my 2 bolts at hub bearing. I damaged rusty heads and with help of one guy I cut the heads:-( I thought will remove hub bearing together with bolts but it seems I was wrong. Hub bearing is still not loose and I wonder if can do it .
What should I do now? except welding something to it?
________________
96 ZJ 5,2
2,5'' BB, DTs3000, 31 BFG MT
LPG
Maciej is offline
post #2 of 19 Old 01-30-2006, 10:36 AM
Yardman Harry
O
Yardman Harry's Avatar
can you put a pic up?
1996 Jeep Grand Cherokee. V8 - 5.2 litre 242 SelecTrac. SURCO Safari Roof Rack
Hunter Green
1997 Jeep Wrangler Sahara Ed. I6 - 4.0 litre, 4" SL, D44 rear, 4:56 Gears, AA SYE with double cardon custom rear Drive Shaft, IRO Adj CAs, Kevins Rear Adj TB with JOHNNY JOINT end
1999 Mazda Miata MX5 - Jet Black
1990 Jeep Cherokee Sport I6 - 4.0 litre
White
~Junked~
Yardman Harry is offline
post #3 of 19 Old 01-30-2006, 10:59 AM
EMTimZJ
GSMW!
EMTimZJ's Avatar
1994 ZJ
I think you are talking about the three 12pt 13mm bolts on the inside of the knuckle right? You tried cutting off the head and it wouldn't come out?
Well even when those bolts are removed, that hub can be rusted on there pretty good. If the hub is what you are trying to replace, just show it who is boss with a mallet, or sledge hammer. Order some new bolts from the dealer or grab some off of a junk yard vehicle. Any Jeep will have them. XJ / YJ / TJ / ZJ ... not sure on the WJ or SJ's.
HTH
-Tim
KD8EBC
'94 ZJ 5.2 LTD
JCR Rock Sliders
EMTimZJ is offline
post #4 of 19 Old 01-30-2006, 12:51 PM
zjay
BFH. They're somewhat seized in, I bet, and with the bolts still in the knuckle, now it will need to come out a little more straight than it would with no bolts. Big hammer should do it, maybe use some penetrating oil, too.
*****You mentioned 2 bolts.There should be 3!!!
96 GC Limited V8 245,000 miles Scrapped
04 GC Limited 4.0 264,000 miles
96 GC 4.0 175,000
zjay is offline
post #5 of 19 Old 01-30-2006, 01:34 PM
CNY
Penetrating oil around where the hub seats in.
If you've already cut the heads off, this might be a little tricky. If you can back the bolts out a couple of turns, then take a BFH to them (with a socket over them for protection).
Also, what I did.... Not the best choice, but it works.....
Back out the bolts (or whatever bolts you have remaining) a couple of turns. Start with the idea from above, then put the tires back on.
First just try working the steering wheel all the way back and forth. That may do the trick. If not, take it up a notch.
Bolts still loose, drive a few feet and jam on the brakes while cutting the whhel hard to one side. That should pop that hub loose.
CNY is offline
post #6 of 19 Old 01-30-2006, 03:02 PM
Phil Gerard
Former Mod
Phil Gerard's Avatar
Since you cut 2 bolts, you might as well cut the 3rd because they just pass through the knuckle. Then wack the hell out of it with a BFH straight out.
Phil
'95 ZJ Ltd. White 4.0L
TW DC DS; ARB Bull Bar, F&R Air Lockers; Superior Axles; Warn Winch; 4.56 gears; ACOS, Addco F&R Sw Bar, JKS Discos, Rr Track Bar & Nerfs, 249>242 Swap, Stillen rotors+Kolak pads, 3 pc. Armor, RE 4.5 Kit + 2.5"BB, Adj. UCAs&LCAs, OME SS, Bilstein 5150s, 15x8 AR Diamond Backs, 33 Truxus MTs, K&N FIPK, RE 62mm TB, Perf. Distr. 4.0L Kit, Exhaust: 2.5" Kolak exhaust FM 70: Optima Yellow, Mean Grn Alt., PIAA 520s, 540s, Kevins Rack, & TB Conversion
Phil Gerard is offline
post #7 of 19 Old 01-30-2006, 06:57 PM
Turbonut
I've always had great luck with a sharp chiesel. Get the chiesel behind the hub and start tapping at various areas. After I move it away slightly, I have a small wedge I insert behind the housing, and tap that in farther, to bring it out the rest of the way.
Turbonut is offline
post #8 of 19 Old 01-30-2006, 07:51 PM
Phil Gerard
Former Mod
Just don't jam or bend those bolts too much or they may never come out!
post #9 of 19 Old 01-30-2006, 08:29 PM
gunthagunth
gunthagunth's Avatar
go to town on that hub with a mini sledge. i just did like 4 of them and believe me new england rust is no joke. i was hitting that thing quicker than a jackhammer. took like 15 mins to budge em. the broken bolts are no prob due to no threads in the knuckle. drop the tierod . good luck
gunthagunth is offline
post #10 of 19 Old 01-30-2006, 09:17 PM
EMTimZJ
GSMW!
EMTimZJ's Avatar
1994 ZJ
To piggy back the air chisle comment (good idea) you could also get a blunt tip and use the air-hammer to punch the bolts out from the back (since you cut the heads off).
-Tim
KD8EBC
'94 ZJ 5.2 LTD
JCR Rock Sliders
EMTimZJ is offline
post #11 of 19 Old 01-31-2006, 08:31 AM
oct7brian
oct7brian's Avatar
Just a offer but if you get the old one off and are interested I'll give you a hub along with the bolts (you pay shipping). The bearings are good and it is from a jeep I parted. PM me if interested and good luck
1998 Grand Cherokee 5.9 Limited Edition, Upcountry Suspension for Now, Infinity Sound, NP 242 Swap
2002 Jeep Liberty Sport 4x4 3.7L Auto
1998 TJ 4.0 Auto Sahara Package 4" Suspension Lift 33 BFG Hard & Soft Top
oct7brian is offline
post #12 of 19 Old 01-31-2006, 08:35 AM
godplayer
Pop off your rotor and cut the tabs off the hub bearing right down the center of the bolt. Cut about 90% of the way and use a chisel and a hammer to finish the cut so you don't cut into the knuckle. Then beat the hub off. Now all three bolts are exposed and then you can try using vise grips to turn them. If that doesn't work then weld a nut to what is left of the bolt and turn it out.
92 Jeep Cherokee 2Dr Sport - 3 inch BDS springs, 2 inch homebrew coil spacer, 1 inch homebrew block, 1.5" RE Boomerang Shackles, Rustys Upper and Lower Adjustable Control Arms, Rustys Adjustable Trac-bar w/ Frame Mount, Rear Waggy D44 w/ Lockright, Front Waggy D44 w/ Full Spool, 4.88 Yukon Gears, PORC SYE, 140lb Homebrew Rocker Panels, 33x13.5LT15 Pitbull Rockers on 15x10 Black Steelies.
96 Jeep Cherokee 4Dr Sport - Daily Driver
65 Jeep CJ5 - Project, Wanted Prelude seats
godplayer is offline
post #13 of 19 Old 01-31-2006, 05:36 PM
Yardman Harry
O
yeah, those things can be a pain! i ended up hitting the crap out of it, i was worried that i was going to break something, but it came off after a bunch of really good hits and about 20 min of pb rust blaster. good luck!
Hunter Green
White
~Junked~
post #14 of 19 Old 02-03-2006, 08:14 AM Thread Starter
Maciej
Thanks a lot!!!!!!!!!!!!!
Sorry I did not respond!
I was looking one week for special tools and I bought a few but bolt threads are so rusty I can't move them . I am trying with a lot of WD 40 , pepsi cola etc. I bought better pliers (heavy ones) but does not help still. I was was trying to hold end of bolt (close to thread) by pliers and screw it out. But nothing happens.
I just read all the posts and it seems it is possible to use hammer and remove whole hub bearing together with two bolts in (pins already since heads are cut off).
I was so lucky and I removed one bolt (it was hard but done) that is why I am talking about two bolts.
I have not much time to do it so it takes already one week (half half hour per two days :-) ) to remove HUB bearing. My goal is to replace half axle.
I will try heating the hub. Question was if it is possible due to bolt pin diameter move in other direction together with hub bearing
many thanks for help, appreciate this
________________
96 ZJ 5,2
LPG
Maciej is offline
post #15 of 19 Old 02-03-2006, 08:23 AM Thread Starter
Maciej
Thanks for proposal. It is interesting but I live in Europe so I do not know what could be shipping cost?
________________
96 ZJ 5,2
LPG
Maciej is offline
Sign of a Bad Wheel Bearing or Ring and Pinion Bearing? torchd ZJ Grand Cherokee Forum 28 02-15-2014 08:14 AM
Bad hub bearing? 97DCZJ ZJ Grand Cherokee Forum 9 12-10-2009 07:14 PM
broke sway bar link bolts at axel, need new bolts 2tone93zj ZJ Grand Cherokee Forum 2 10-28-2009 04:57 PM
Bolts holding unit bearing to knuckle ajmorell ZJ Grand Cherokee Forum 16 04-02-2008 08:16 PM
wheel bearing vs axle bearing. cifer6425 ZJ Grand Cherokee Forum 5 06-21-2007 01:04 PM
