Hub Bearing? - JeepForum.com
post #1 of 12 Old 08-13-2007, 09:25 AM Thread Starter
uncc09meet
uncc09meet's Avatar
1993 XJ Cherokee
Hub Bearing?
The Jeep Deel-uH says I need a new right front hub bearing. What are the symptoms of this. How can I verify this? Thanks
Chad
UNC Charlotte 09'
93' XJ Country 4X4
"if genuine parts were so good, we wouldn't need to replace them!"
uncc09meet is offline
post #2 of 12 Old 08-13-2007, 10:00 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Jack up the front end.
Grab the tire at the outermost edge with both hands and check for play.
Wheelin98TJ is offline
post #3 of 12 Old 08-13-2007, 12:58 PM
micifus
Original GC'er
micifus's Avatar
That could also mean ball joints I dont know if that is the best test.
- OME Springs - 30"x9.5" Yokohamma's A/T-S -RE Shocks - JKS Quicker Disconnects - FM70 - E-Fan Conversion - 249->242 Swap -
32"x11.5" BFG A/T
4" Lift
"For every one thing I fix two things break"
micifus is offline
post #4 of 12 Old 08-13-2007, 01:30 PM
Wheelin98TJ
JEEP FREAK
You watch where the play is being introduced while you do this. It will be obvious if its coming from the ball joint or the wheel bearing.
You can also rotate the tire by hand and listen for noise and feel for roughness.
post #5 of 12 Old 08-14-2007, 05:50 AM
micifus
Original GC'er
micifus's Avatar
How hard is it to replace the wheel bearing your self?
32"x11.5" BFG A/T
4" Lift
micifus is offline
post #6 of 12 Old 08-14-2007, 06:28 AM
Wheelin98TJ
JEEP FREAK
Its pretty easy, maybe a 1 hour job.
Below is a great write-up. Its for removing a D30 axle shaft, so just follow it to the point where the unit bearing is removed (about the end of page 2).
http://www.stu-offroad.com/axle/d30/axle-1.htm
And if you can't get the unit bearing off, here's a trick for how to do that:
http://www.stu-offroad.com/axle/unit...tbearing-1.htm
post #7 of 12 Old 08-14-2007, 07:02 AM
micifus
Original GC'er
micifus's Avatar
I have CV Joints will this differ at all?
32"x11.5" BFG A/T
4" Lift
micifus is offline
post #8 of 12 Old 08-14-2007, 07:28 AM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Nope...here is another writeup I did on this: http://www.jeepforum.com/forum/f310/how-replace-axle-shaft-wheel-hub-bearing-assembly-w-pics-377208/
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #9 of 12 Old 08-14-2007, 07:48 AM
micifus
Original GC'er
micifus's Avatar
So when I goto the store and ask for a new CV joint I will get this?
And this just slides in slides out? There is no other bearings or seals that are going to need to be replaced?
Im getting noise from my front wheels, the boots are intact but I am sure the CV joints are worn they have not been replaced since I have owned the jeep ~50k miles. Most likely more.
32"x11.5" BFG A/T
4" Lift
micifus is offline
post #10 of 12 Old 08-14-2007, 07:50 AM
ArloGuthroJeep
Mr. Hyde!
Correct.....
post #11 of 12 Old 08-14-2007, 09:26 AM
gomes512
1994 ZJ
Yeah the grab the tire and shake test works sometimes but not always. When I did that with mine I had no play at all but both hubs were toasted.
Just spin the tire when the Jeep is jacked up off the ground and listen/feel for rough spinning/grinding. I'm not sure about the rust content of your Jeep but a puller will greatly reduce the amount of cursing when trying to separate the hub from the axle.
gomes512 is offline
post #12 of 12 Old 08-14-2007, 09:30 AM
micifus
Original GC'er
micifus's Avatar
lots of rust maybe ill see if I can rent one.
32"x11.5" BFG A/T
4" Lift
micifus is offline
Sign of a Bad Wheel Bearing or Ring and Pinion Bearing? torchd ZJ Grand Cherokee Forum 28 02-15-2014 08:14 AM
Bad hub bearing? 97DCZJ ZJ Grand Cherokee Forum 9 12-10-2009 07:14 PM
TC bearing went out! RLWaderacin ZJ Grand Cherokee Forum 5 11-21-2009 12:31 PM
which bearing is right? siklas ZJ Grand Cherokee Forum 0 09-29-2009 10:37 AM
wheel bearing vs axle bearing. cifer6425 ZJ Grand Cherokee Forum 5 06-21-2007 01:04 PM
