hp30 vs. d30...etc - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > hp30 vs. d30...etc
New Knuckles Skid Plate at JeepHutIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineNorthridge4x4 - Free ARB Air Compressor with Locker Purcha
Unread 01-26-2010, 10:32 AM   #1
96liftedzj
hp30 vs. d30...etc
hey everyone,
im looking to re-gear my axles and I am running a d30 and d35 setup on my 96 ZJ...i planned on getting a HP30 from a Xj but am wondering if there is a difference between the HP and reg. 30 gears? isnt it just placement of the pinion in the housing?
also with the rear d35 how many different variations are there? I saw c-clip and non c-clip..how would I know which I have? Also which axle shafts are interchangeable between models? YJ/TJ/XJ/ZJ??
thanks guys....
96liftedzj is offline   Reply With Quote
Unread 01-26-2010, 11:23 AM   #2
Area.3.Fiftyone
Never mind.
[COLOR="Black"][CENTER][SIZE="4"][FONT="Showcard Gothic"][COLOR="Black"][URL="http://groups.jeepforum.com/built-not-bought/"][COLOR="Black"]Built Not Bought #666[/COLOR][/URL][/FONT][/SIZE][/COLOR][/COLOR]
[/CENTER]
79' CJ7
82' CJ8
94' YJ
96' ZJ
[i]Diagonally parked in a parallel universe........[/I]
Area.3.Fiftyone is offline   Reply With Quote
Unread 01-26-2010, 12:23 PM   #3
StrokedWJ
Originally Posted by 96liftedzj View Post
hey everyone,
The ring and pinion in a high pinion axle are "reverse cut". They are different than those in a low pinion axle. High pinion axles are stronger when used in a front differential because the drive force is exerted on the correct side of the ring gear.
I believe the D35's from 93+ are the same (The WJ D35 is an exception though). They're all 27 spline and c-clipped. Someone correct me if I'm wrong...
What size tires are you regearing for? It might be a better idea to look for a HP30 and 8.8 that are the correct ratio and can be swapped in. The HP30's and 8.8's were available with 4.10 gearing from the factory.
2000 WJ 4.5L - Stroked, Locked, & Long-Armed
Click this -->Think you can beat me?
StrokedWJ is offline   Reply With Quote
Unread 01-26-2010, 12:24 PM   #4
rugermack
HP d30 has reverse cut gears, won't work in a LP d30.
95' Jeep Grand Cherokee Laredo, 148k, 5.2, NP242, 46RH, 4" RC lift, all new adjustable ca's(2 IRO front uppers and the rest RC adjustables), nitro shocks, JKS TB's, Jet Chip, Dynamax cat back, Magnaflow cat, GTP hood vents. 31" Pro Comps with Rock Krawler "D"s. Westin brush/grill guard with Hella 500s, 411's, Solid diff covers, detroit locker rear, power lock in front, SYE and Tom Wood's front/rear shafts, RE discos, BPE's, d-rings front and back, factory tc and rad skid, hitch, Sliders next.
03' Jeep Grand Cherokee Laredo, (wifes Jeep) 99k, 4.7 5 speed auto, K&N, KYB shocks, drilled-slotted rotors, All the toys.
2000' Ford Superduty, F250, 7.3, 198K, 37's, too much to list.
Built Not Bought #257
Parts for sale d30 and d35 parts http://www.jeepforum.com/forum/f126/...-parts-1004499
rugermack is offline   Reply With Quote
Unread 01-26-2010, 12:45 PM   #5
96liftedzj
ok so i got the answers for my gear interchange questions as the HP is reverse cut...i have 33's on there now with the stock 3.55 gears...Its my DD and i wheel it at most 5x a year locally and at rausch creek...so crazy gearing isnt necessary but I do want to move this beast...i was thinking about 4.56's but I just did my friends XJ and he has the HP30 and the chry. 8.25 and I put in detroit tru-trac's and 4.10s and hes running 33 baja claws...
what gear recommendations you suggest? IF i could get a 8.8 and a HP30 in both 4.10 ratio that would be a home-run...but are 4.10's suitable..or would the 4.56 be better?
Unread 01-26-2010, 12:57 PM   #6
rugermack
Most would say 456's with the 4.0, I'm going to run 410's but I have the 5.2, and I'm only running 31's maybe 32's someday. I'd lean towards 456's.
Unread 01-26-2010, 01:03 PM   #7
StrokedWJ
Either ratio will be much better than what you currently have. If you have thoughts about going to 35's anytime in the future, go with 4.56's. If 33's are the biggest you'll ever get, 4.10's would be ok and should save some $ since you wouldn't have to regear.
Unread 01-26-2010, 01:08 PM   #8
96liftedzj
yeah thats what I was thinking...i just did a search of local scrap yards...found a 8.8 with 4.10's etc..for 450 and 350 at two different yards...whats a decent price for that axle complete?? and the HP30 I can get for 3-$400...
Unread 01-26-2010, 01:23 PM   #9
BLACKzj52
im going with 4.56s and will be running 33s on my 5.2
My Build Thead
Facebook
BLACKzj52 is offline   Reply With Quote
Unread 01-26-2010, 01:40 PM   #10
96liftedzj
i would like the 4.56's but for ease of swapping and everything it would probably benefit me to swap the HP30 and the 8.8 straight up with the 4.10 ratios...
Unread 01-26-2010, 02:07 PM   #11
rugermack
That's definitely best for your wallet.
Unread 01-26-2010, 02:28 PM   #12
92rslt1
what type of rpm's is he going to run on the highway with 4.10s vrs 4.56?
02 overland, bone stock
92rslt1 is offline   Reply With Quote
Unread 01-26-2010, 02:36 PM   #13
96liftedzj
yeah i already found a local yard that has both axles and has them from all different trucks so the picking is plentiful...hope I can work out a package deal for the two...im figuring i will eliminate my ABS so it doesnt matter if i get the ABS axles or not...hopefully I will locate two axles later this week and pick them up when i get my tax return!
Unread 01-26-2010, 02:39 PM   #14
StrokedWJ
According to the gear calculator here its would be around around 2100 RPM's at 65 with the 4.56's and around 1900 with the 4.10's.
Gear Ratio Calculator
Unread 04-06-2010, 08:05 PM   #15
ZJJAMES
I have a hp30 and a 8.8 on 33s I went with 4.88s and I love the power it gives my 4.0. if you spend the money do it right and go with 4.88s.
96 ZJ V8, HP44, Ultimate 8.8, 242tc swap, Tom woods shafts, long arms, 33s...
ZJJAMES is offline   Reply With Quote
  • Will a TJ hp30 fit a ZJ? - ZJ Grand Cherokee Forum (5 replies)
  • 4.88s in hp30 - ZJ Grand Cherokee Forum (14 replies)
  • Hp30 - ZJ Grand Cherokee Forum (12 replies)
  • Hp30 - ZJ Grand Cherokee Forum (10 replies)
  • Hp30 - ZJ Grand Cherokee Forum (7 replies)
