Quantcast HP Dana 30 find today - possible to keep anti lock brakes? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > HP Dana 30 find today - possible to keep anti lock brakes?
Front and rear Drive shafts @ free shippingPoison Spyder February Special: FREE Rubber Liners when yoSlappin' on 61,510 Rigid Industries Lumens for Big Red
Old 10-08-2009, 07:54 PM   #1
IronMaiden
Hallowed be thy name....
IronMaiden's Avatar
1982 CJ8
I just got back from the junkyard a little while ago with a HP Dana 30 sticking out of the back of my Neon for $90 out the gate. I had to pull it and lift it into the back of the Neon myself but it was worth it. I also grabbed a NP242 last week for my rig from the same yard for $45.
I still need a trans for my Jeep so no crap about driving a Neon please.
I'm moving up to 33's next week (they are on their way) and figured the HP and 4.10's would be a good move while I'm at it. Plans are to install an 8.8 as well out back and I was wondering if there was any way I could keep the anti lock brake system? What do you guys do about the tone rings?
If not, is it just a matter of pulling the relay? Anything else that needs to be done to disable the anti lock brakes?
Brand new nutmeg rear CJ/YJ seat, new AX5 clutch kit, 5.9 louvers, etc.
Click Here - For Sale
79' CJ7
82' CJ8
94' YJ
96' ZJ
IronMaiden is online now   Reply With Quote
Old 10-08-2009, 08:07 PM   #2
StellaTheZJ
You can certainly keep the front ABS. Swap the knuckles from your LP D30 onto the HP D30 - it's a straight swap. Then, put in your ABS axles, and you're done.
I don't know about the 8.8 though. I think if you search for this, you'll find people simply pull the relay and forget about it.
StellaTheZJ is offline   Reply With Quote
Old 10-08-2009, 08:26 PM   #3
IronMaiden
IronMaiden's Avatar
1982 CJ8
Yeah, the only problem is my ABS axles are CV which I'd like to get rid of in favor of the stronger U Joint axles that are already in the HPD30. I guess I could pull a set of ZJ axles that are U Joint and have tone rings and use those.
Either that, or ditch the ABS all together and just forget about it. It may be more trouble than it's worth.
79' CJ7
82' CJ8
94' YJ
96' ZJ
Old 10-08-2009, 08:29 PM   #4
Travis873o
i believe all ZJs use the cv style axles
Travis873o is offline   Reply With Quote
Old 10-08-2009, 08:57 PM   #5
highlyuncntered
Not quite. Quadra-Trac ZJs are the only ones that came with the CV front axles. The ZJs equipped with the 242 came wit the 297X series front shafts. I got lucky enough to go pull the 297X style front shafts from pullapart for $35. Also any front shafts out of a TJ or later XJ will work. I would recommend the TJ shafts as they are about 20% stronger(bigger U-Joint.) Hope this helps. Oh, and buy a breaker bar and WD-40 to take the wheel bearings off. The JY ZJ was rusted to sh*t and it bent the heck out of the wrench i was using.
EDIT: The wheel bearing bolts are 13mm 12-point. Be careful.
"Si Vis Pacem, Para Bellum"
'98 ZJ Limited V8 "Daisy"
highlyuncntered is offline   Reply With Quote
Old 10-08-2009, 09:38 PM   #6
IronMaiden
IronMaiden's Avatar
1982 CJ8
I'm just going to reuse the XJ shafts that I got with the axle.
It looks like it's not worth the trouble to keep the ABS.
79' CJ7
82' CJ8
94' YJ
96' ZJ
Old 10-08-2009, 10:01 PM   #7
highlyuncntered
what year XJ???
Old 10-08-2009, 10:42 PM   #8
ratmonkey
Living dead mod
ratmonkey's Avatar
Won't be able to keep it. In the zj if one sensor isn't working the whole system stops working.
The 8.8 will eliminate your ability to use rear abs.
No need to pull a fuse or anything.
ratmonkey is offline   Reply With Quote
Old 10-09-2009, 02:00 AM   #9
Colorado 5.9
The 8.8 can be modified to use ABS. It's a pain thought.
ZJ 98 5.9 LTD. Lots of mods. 7" T&T's Long Arm Lift ,BFG KM2"s,35X12.50x16's,4:56's, Vanco brake upgrade, M1intake,Holley52mmTB,MikeLeach Headers,, Arb'ed HP D30,Aussie Locked rear,Procomp MX6 Shocks,Arb front,RearTR bumpers,ECT.ECT.
Latest Pics
Colorado 5.9 is offline   Reply With Quote
Old 10-09-2009, 07:25 AM   #10
IronMaiden
IronMaiden's Avatar
1982 CJ8
Originally Posted by highlyuncntered View Post
what year XJ???
I didn't take the time to look at the production year.
I was just happy to find one that had 4.10's. There was another one there (older) as well, but it had the passenger side vacuum disconnect.
They don't last long in the Pick and Pulls around here.
Stumbled across a couple NP231's and a few more NP242's too. They were laying on the ground from someone taking the transmissions out.
79' CJ7
82' CJ8
94' YJ
96' ZJ
Glock Forum
