post #1 of Old 12-04-2011, 10:34 AM Thread Starter
MilanJeep
MilanJeep's Avatar
HP D30 + Thorley headers on my 5.9...will there be problems?
Well I'm planning on doing some more lift, long arms, and was also kicking around the idea of doing a HP D30 in the process as well.
I remember back in the day the Mike Leach headers would not work with people running HP D30's in their ZJ's.
Does anyone know if I will run into the same problems with the Thorley headers if I try to swap in a HP D30 in my 5.9? What about long arm interference? I was planning on doing IRO's setup
98 5.9 ZJ - 4.5" lift, 33x12.50 MT/R Kevlars
02 Z06 - Supercharged, E85, lots of rwhp, built and tuned by me
Milan
MilanJeep is offline
post #2 of Old 12-04-2011, 11:26 AM
blackjack12982
1994 ZJ
I remember seeing a thread about this on one of the forums I was on. Try searching the "internetz" for it. I checked my links, and I don't have it. I even owned the ZJ Thorley headers, but never got around to installing them.
Check
thespeedfreaks.net
I'd have to assume someone there would know the answer, or would have heard of someone who's done it.
blackjack12982 is offline
post #3 of Old 12-08-2011, 09:27 AM
zjgr
I don't know, but I have dana 30hp and I have already ordered the headers.
I thought that there wouldn't be a problem since I have at least 3.5'' lift.
97 ZJ 5.9 (swap), Doug Thorley headers, bosch injectors, 242tc, 4.56rp, dana 30 hp ox locker, 44a aussie locker, snorkel, WJ brake/steering upgrade, 3.5" Rubicon SF, Bilstein 5150 shocks, F/R ACOS, F/R Addcos, Ramsey winch, Icelandoffroad fenders, hid projector headlights, carputer, 33" mud on Procomp 16X8 4.5 bs
zjgr is offline
post #4 of Old 12-08-2011, 10:55 AM
LordHobbit
There should be no problem with the lift. IIRC the problem was with stock height and hpd30 axle.
93 red ZJ 190k 4.0. Spent more money than I should have ...
Isn't red the only color a vehicle should be?
If at first you don't succeed, use more speed.
LordHobbit is offline
post #5 of Old 12-08-2011, 11:01 AM
Technohead
Old School
Technohead's Avatar
I can't imagine how the HP axle would interfere with headers.
Technohead is offline
post #6 of Old 12-08-2011, 11:02 AM
PolkaPower
The best thing to do would be to send me the headers so I can test fit them for you. I may need to keep them for a while to make sure they will fit for you. But don't worry, it's for the best.
PolkaPower is online now
post #7 of Old 12-08-2011, 01:26 PM
LordHobbit
I think it is more to do with driveline angles
post #8 of Old 12-08-2011, 09:05 PM
corndogduff
You could always sell me the headers if it doesn't work
Duff.
(broken)98 ZJ 5.9
UT Jeepcrew #13
NIGHTCREW
corndogduff is offline
post #9 of Old 12-09-2011, 03:25 AM
ZJ5point2GCL
it'll be fine with a lift, probably fine with out too.
98 Deep Slate Niner- 6''s on 35's ---11 F150 Platinum Pearl White- Modded Tiny V6 with Two Turbos. ---93 Black 5.2 limited- Slowly dying in my Parents Driveway
ZJ5point2GCL is offline
Doug Thorley 93 zj cat back exhaust ninjastar ZJ Grand Cherokee Forum 33 09-12-2011 11:15 PM
Edelbrock or Thorley ? Blown5pnt4 ZJ Grand Cherokee Forum 10 05-16-2011 08:04 PM
Those of you running Doug thorley headers Greengc4x4 ZJ Grand Cherokee Forum 11 06-26-2009 11:03 PM
Doug Thorley Header Gaskets... LaCeS OuT ZJ Grand Cherokee Forum 7 02-22-2008 01:29 PM
Thorley headers questions eagleknight ZJ Grand Cherokee Forum 1 06-21-2006 08:57 PM
You may not post new threads
You may not post replies
