Howling Sound from Front End - CV? - JeepForum.com
post #1 of 12 Old 09-28-2009, 06:38 PM Thread Starter
01Limited45324
I've known for a little bit that my CV boot on my passenger front is torn to shreds. I didn't have the money or the time to really worry about it but I've now got a howling sound when I let off the gas. Related? I'm thinking it is, I just want some opinions on it. Only happens above 30 mph or so.
-Tom
2001 Grand Cherokee Limited
2002 BMW 530i
01Limited45324 is offline
post #2 of 12 Old 09-29-2009, 11:30 AM
PA 5.9
Howling sound when you let off the gas sounds more like carrier bearings to me or at least something differential related. Ive never heard anything like that connected to a bad CV joint.
PA 5.9 is offline
post #3 of 12 Old 09-29-2009, 11:31 AM
iluvtruenos
Wheel bearing.
I had the same exact problem.
It's a cylic sound, going up and down in pitch, correct?
My Jeep is a chick magnet with reverse polarity.
2000 WJ, 4.5l, AX15, 242 D60/14b, 5.5" lift front, 7.5" rear. Ford Expedition rear coils, Ram 350 shocks, JKS, IRO Long Arms, cool Badlands flag thingy.
1987 XJ - Gone but not forgotten
iluvtruenos is offline
post #4 of 12 Old 09-29-2009, 11:35 AM Thread Starter
01Limited45324
Originally Posted by iluvtruenos View Post
Wheel bearing.
Sounds about right. I had it in the rear when I bought the Jeep and it turned out to be bad axle seals. $500 later I was back on the road.
-Tom
2002 BMW 530i
post #5 of 12 Old 09-29-2009, 12:16 PM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
does the noise change in turns?
NEW Dana 44a Axle Truss and Skid !
WJ Grand Cherokee Tube Doors For Sale !
ZJ Grand Cherokee Tube Doors For Sale !
PARTS FOR SALE from 10 WJ Grand Cherokees ! !
QuadraTokn is offline
post #6 of 12 Old 09-29-2009, 12:18 PM Thread Starter
01Limited45324
That's a negative.
-Tom
2002 BMW 530i
post #7 of 12 Old 09-29-2009, 12:30 PM
99avant
Front drive shaft?
yup
|94 XJ|4.0|NP231|AW4|8.25 Trac Lock|Lotsa miles - SOLD
|99 WJ|4.7|242HD|Vari-lok|Upcountry+BB|DT8000|Dead as of 10/29/2009
If it aint broke, fix it till it is.
99avant is offline
post #8 of 12 Old 09-29-2009, 12:37 PM Thread Starter
01Limited45324
Originally Posted by 99avant View Post
Front drive shaft?
yup
I contemplated it but it's weird... It didn't start until about 300 miles after I saw my busted CV boot. I just feel that they're connected, but I'm not too sure. Guess not...?
-Tom
2002 BMW 530i
post #9 of 12 Old 09-29-2009, 01:56 PM
NOCARRIER
I'd recommend upgrading your stock prop shaft to a double cardan ujoint style. much better than the stock 99 wjs have. the 02s have it i believe or you can go the best route with a Tom Woods drive shaft (tomwoods.com i think).
The "whining" noise sounds like it could be a viscous coupler or somethign in the tc maybe. the propshaft wear would be a clicking or grinding sound.
--shawn
NOCARRIER is offline
post #10 of 12 Old 09-29-2009, 02:04 PM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
Take off your front DS, and see if the noise goes away. You may be surprised.
post #11 of 12 Old 09-29-2009, 03:56 PM
iluvtruenos
Go 30mph down an empty road where you can swerve from side to side from lane to lane.
If when you swerve one way the noise goes away, then it's your wheel bearings.
Best place to do it is on a highway on/off ramp, if you've got one that shoots to the right and left.
post #12 of 12 Old 09-29-2009, 05:15 PM
ZeJokee
Probably your pinion bearing in the front diff. I have the exact same noise and that is what is causing it for me.
99 WJ Ltd, Blacked out, 4.7L, 242j Swap, 2'' BB, 245/75/16 Kuhmo Venture AT KL78, Flow Master Super 40, MagnaFlow high flow Cat, Akebono caliper upgrade, Addco rear swaybar, Westin brush guard, Moog Super Trail Boss, Rancho RS5000, Rola roof rack with dual kayak J hooks, PAC-AOEM-CHR, Sony Xplod 1200w amp, 2 Sony Xplod 12'' subs, 118,XXX miles (SOLD)
93 ZJ Ltd, Blacked out, 5.2L, Reman 46RH, Reman 242 Swap, 3.5'' IRO + 2" BB, 33x12.50r15 Mud Claw MTX radials, Bushwacker Flares, 216,XXX miles (Still parked in NC)
04 F-350 SD Crew Cab FX4 Lariat, 6.0 PSD SRW, Head studs, AFE Stage 2 SI Pro Guard 7 intake, Blue Spring mod, 150,XXX Miles
ZeJokee is offline
noticed howling sound from back end lance70 WK Grand Cherokee & XK Commander Forum 30 05-28-2013 10:23 AM
Howling sound when shifting into drive vtxkc WK Grand Cherokee & XK Commander Forum 4 10-27-2009 09:17 PM
howling noise front front of 01 WJ aquafresshness ZJ Grand Cherokee Forum 7 05-25-2009 11:50 AM
Howling noise coming from front end.... atwrk ZJ Grand Cherokee Forum 16 04-03-2009 10:31 PM
Howling sound from front end...help rollerbones ZJ Grand Cherokee Forum 16 04-08-2004 07:18 PM
