How to wire fog lights so they come on with highbeams? - Page 2 - JeepForum.com
post #16 of 22 Old 11-02-2008, 03:52 PM
dxmedia
http://photos.imageevent.com/denviks...t%20wiring.JPG
The supply wants to come from the live wire on the headlights when full beam is on. With a multimeter of indicator lamp have someone flash the headlamps and work out which wire it is, take this as a feed to trigger the relay.
DON'T just piggyback off the headlight wiring, if you overload it it will catch fire. 3mm (sorry don't know imperial for that) wire is a good starting point for running off the relays.
1 12v 35amp relay is good enough for 420W of lights.
dxmedia is offline
post #17 of 22 Old 11-02-2008, 06:45 PM
xJoshxx
2012 WK
Inline Fuse would be cool 2 i put a 40amp fuse on it.
xJoshxx is offline
post #18 of 22 Old 11-02-2008, 07:45 PM
TX-WJ
TX-WJ's Avatar
If you're in foggy weather and turn the fogs, the beam is directed to the ground just under the fog, lighting the foreground and increasing visibility; if you were to turn your high beams, the beam will hit the fog and reflect back in your eyes blinding you and decreasing visibility. That is the reason why they are set to not run at the same time.
I know you asked how to wire them, but this may help if your looking to run fogs and highs for short periods of time, just how I do it if running late in the trail. I'm going to give you my 2 cents.....well, actually my 1 cent.
For the TJ guys, you can bend a leg on the fog relay to allow them to run with the highs. This does not work on our grands (WJ), I already tried. What I do:
All it takes its a penny, If you have your lows and fogs on, and you flash your highs, you will notice if you hold the lever before it "clicks", the high beam will come on and the fogs are still lit; if you place a penny at the base of the lever, it will hold it in that spot allowing you to have all three on at the same time; now it's that el cheapo mod or what?
As I said, I do this ONLY while offroad, do this at your own risk, do not place other drivers in danger by shining all this light on the freeway.
David.
(steel blue pearlcoat)
4.7, 242 HD swap, 6" Clayton's, 35" BFG KM2s, F/R chromo'd JK Rubi D44s
TX-WJ is online now
post #19 of 22 Old 11-02-2008, 11:26 PM Thread Starter
superarmen
i dont use my high beams during foggy condidtions becasue of the glare...the only time i really use it is when im going home and highbeams help me see much easier since there arent too many street lights in the area. I have had a couple close encounters with our local deers and i want to make sure that i dont hit them because they jump out last minute.... i have two lights mounted to my bumper in adition to the stock fog lights but since i got a ticket for driving with those on, i wanted to see what a better alternative would be.
99 WJ in BLUE
94 YJ in BLACK
superarmen is offline
post #20 of 22 Old 11-02-2008, 11:38 PM
TX-WJ
TX-WJ's Avatar
Oh, no, don't get me wrong, I did not mean to say you did, that is just a general statement.
I have to drive 150 mi to and back from my favorite wheeling spot and on the way back, on a dark sunday night I drive with my fogs on on this farm roads and when I get a chance will turn the highs, that is why I learned this trick. A simple flick on the lever and your back to low beams again.
David.
TX-WJ is online now
post #21 of 22 Old 11-03-2008, 01:15 AM Thread Starter
superarmen
so by putting a coin in between the lever and the space that is there, it will hold itself and i can let go of the lever? is that what u mean? i mean if its that simple then forget fooling around with the wiring. This sounds like a cool idea because i only use it for a short period of time anyway...thanks for tip...i will try it next time i drive
99 WJ in BLUE
94 YJ in BLACK
post #22 of 22 Old 11-03-2008, 09:32 AM
ezrider327
There was/is a guy on Ebay that was selling a "module" to just this, keep the FL on with the HB for like $16
Don't know if it will work on a 99 but I found it - http://cgi.ebay.com/ebaymotors/93-95...spagenameZWDVW
price went up since I last saw it, but so has everything else lol
If you are reading this, THANK a teacher. If you are reading this in ENGLISH, THANK a soldier!!! ESSAYONS
97 F350 Dually CC Powerstroke- - 65 Mustang - 74 Super Beetle - 93 Harley Sportster
97 ZJ 4.0 4x4 Auto : Rusty's BB lift & Rusty's K&N intake
235 75 15 Toyo Open Contry AT's 15x8.5 Eagle alloy's
Flowmaster exhaust, custom winch bumper, Ramsey 9000lb, THULE MOAB roof rack
ezrider327 is offline
How to wire Fog lights up in a WJ that didn't already have factory Fogs? PS_Jeep ZJ Grand Cherokee Forum 5 08-20-2015 04:06 PM
routing wire for lights.....on roof rack ironmammoth ZJ Grand Cherokee Forum 7 08-12-2008 07:31 PM
Engine harness wire to coil pack wire is frayed dustindu4 ZJ Grand Cherokee Forum 1 06-26-2008 01:18 PM
Highbeams Mikey2 ZJ Grand Cherokee Forum 6 08-31-2006 12:39 AM
Highbeams ALWAYS on! 93AccordCoupe ZJ Grand Cherokee Forum 10 07-24-2005 07:03 PM
