how well can a zj REALLY wheel? - Page 2 - JeepForum.com
post #16 of 21 Old 09-22-2003, 04:22 PM
KillerZJ
KillerZJ's Avatar
Originally Posted by Big Dumb White Guy
correction - AW4 is a transmission and from what i am told, it is one of the better stock transmissions on Jeep GC's....
go to www.NAGCA.com and do a search for a video on AlaskaZJ and see what he has done and what he does with his ZJ.... you'd be very surprised....
well, your really not a big dumb white guy because your right. the AW4 is basically "bombproof" It is verry strong.
Looking for E36 325i(s) 5 speed only. Jeep is for sale $3,000 takes it. E-mail only.
*Sale Pending*
Wow no pictures in sig? F*cking gay.
KillerZJ is offline
post #17 of 21 Old 09-22-2003, 06:24 PM
Ross
I have heard the tcase is what has the problem with the clutches wearing out.
01 TJ, 34 Super Swaper 34x10.5 bias, Winch, locked, belly up, some armor, 4.0, 5spd
Ross is offline
post #18 of 21 Old 09-22-2003, 07:34 PM
iroc22
iroc22's Avatar
Originally Posted by Ross
I believe the all wheel drive system in the eights and some of the sixes use clutches that will wear faster than the chain and gears that are in the jeeps with a selctable Tcase.
I would avoid, actually I did avoid, gettint he tcase that keeps you in 4wheel drive all the time. The clutches will wear out evetually.
No.
All 249 all wheel drive transfer cases use chains and gears just like the rest. They just incorporate a viscous coupling unit that can wear out if exposed to extreme heat (ex. difference in tire tread depth front - rear). They dont use clutches.
Besides a 242 or 231 transfer case is a direct bolt in.
As far as off road ability, either one will do well, it is a Jeep.
Can't argue with that.
iroc22 is offline
post #19 of 21 Old 09-22-2003, 08:55 PM
JAURS
Hey Swampboy, I just wanted to say that I love the pictures. They really show the true capabilities of a Grand Cherokee. I went wheeling this weekend and thought I was in some mud and tricky situations, but it's nothing compared to what you were in. I'll have to buy myself a digital camera or something so I can post pics of my rig. In the meantime, keep up the good work with the pictures and truck, they look really good.
JAURS is offline
post #20 of 21 Old 09-22-2003, 09:00 PM
Swamp Boy
Swamp Boy's Avatar
Thank you .. I never leave home without my Digi cam.. YOu never know when a photo op will arise.. LIke the Freightliner..
I was coming home from work one day and there is a semi over the curb. ( hi centered) So I whip out the trusty strap and pull him out.. ( Obviously couldnt see the curb because of the flood ..
Its huricane season here..
Noone would believe me if I said I did it.. So I took a picture ..
My strap is clearly visible in the pic...
Just another soccer moms Grocery getter....
Swamp Boy is offline
post #21 of 21 Old 09-22-2003, 09:40 PM
Ross
Originally Posted by iroc22
No.
Clutches maybe are not best wayto decsribe them. I think of anything that can engage or disengage as a clutch. Basically, if I understand it when you loose traction the "pads" swell with trans fluid "viscous coupling". These pads will wear out eventually. Just depens on the use.
Ross is offline
Wheel stud broke, cant get wheel off MurdaJs Grand Cherokee General Discussion 23 05-19-2010 01:24 PM
had 4 wheel aligment twice i past week, and steering wheel is still off center..Help HD-ZJ ZJ Grand Cherokee Forum 4 11-24-2009 02:54 PM
how can i make a all time 4 wheel drive Cherokee in to an optional 4 or 2 wheel drive Harp90 ZJ Grand Cherokee Forum 16 09-09-2009 02:09 PM
Front tire to wheel wheel gap... gman1322 ZJ Grand Cherokee Forum 12 07-06-2009 12:31 PM
1999 Grand Cher Limited - Convert from FT 4 Wheel to Selectable 2 or 4 Wheel? cabaynes ZJ Grand Cherokee Forum 12 12-21-2008 08:30 AM
