how tight is too tight for a serpentine belt? - JeepForum.com
post #1 of 11 Old 12-19-2012, 11:27 PM Thread Starter
WJ_BEAST
93 zj 4.0
I keep getting a random squeal so I tightened my belt and it was fine for a day, then realized when my ac pump kicked on it seamed to come from there.but then today when I drove it it sqealed a few randon times without the defrost kicking on the ac pump.so do I keep tighting my belt or do I assume I need a new fan cluctch assembly or whatever that part of the pump is called.it has a newer gator back belt.
WJ_BEAST is offline
post #2 of 11 Old 12-20-2012, 01:50 AM
AVR2
The rule of thumb I use for manually-tightened serp belts (and which I learned about here) is that you should be able to twist them no more and no less than 90 degrees at the tension test point. I've no idea how well that relates to the actual tightness spec, but it's worked for me for years
AVR2 is offline
post #3 of 11 Old 12-20-2012, 04:59 AM
KoreaZJ
1994 ZJ
Where is the "tension test point"...?
KoreaZJ is offline
post #4 of 11 Old 12-20-2012, 05:44 AM
AVR2
Halfway between the upper idler pulley and the PS pump pulley :
AVR2 is offline
post #5 of 11 Old 12-20-2012, 05:48 AM
jomps
i assume there is a torque spec,do you have a haynes or chilton?
jomps is offline
post #6 of 11 Old 12-20-2012, 05:57 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Theres a gauge for belt deflection. His method is close enough.
ratmonkey is offline
post #7 of 11 Old 12-20-2012, 06:15 AM
AVR2
The tension spec is in the FSM and Haynes, but accurate tension gauges are expensive and even most of the auto shops around here don't have them, since most engines have had automatic tensioners for so many years now. The twist test, or the thumb deflection test, will work fine in most cases. I certainly have no problems with belt slippage and it doesn't seem to be over-tight either.
AVR2 is offline
post #8 of 11 Old 12-20-2012, 09:02 AM Thread Starter
WJ_BEAST
How would I tell if its the ac clutch/bearing or not. I ve only been able to make it to the front that one time when it was doing it for a few seconds.otherwise I cant seem to make it do it .it just likes to randomly do it at embarrassing moments lol
WJ_BEAST is offline
post #9 of 11 Old 12-20-2012, 07:01 PM
jeepinbassist
Mine's been doing the same thing. It only happens when it is really cold out and the engine is still warming up. My squeal is coming from the AC. I know the clutch froze up and had to be replaced about a year before I got it, and i know that is was a JY compressor. So it seems like it is starting to do it again. I'm not sure if replacing the bearing could save it or if the whole thing is shot.
jeepinbassist is offline
post #10 of 11 Old 12-20-2012, 09:24 PM
jtackerman28
Chances are its isnt the ac pump its the alternator
3.5 re lift, double sheer front tb, 31" wrangler duratecs
jtackerman28 is offline
post #11 of 11 Old 12-20-2012, 10:55 PM
ZJMTL
Try cleaning your belt on both sides with a small wire brush/cleaning brush while the motor is on (be careful of the clutch fan, and watch your fingers in general).
Then when you're done that, rub a 1'' wide dab of dialectic grease on both sides of the belt in one spot.
I read this somewhere else on JF. Apparently dirt on the belt + cold days usually results in a squeak. In my case it has worked and cured squeal for long periods of time.
'96 Laredo Build Thread - http://www.jeepforum.com/forum/f197/zjmtls-project-thread-daily-driver-weekend-getaway-vehicle-1360544/
ZJMTL is offline
