How To Test a 247? - JeepForum.com
post #1 of 16 Old 11-03-2009, 09:58 PM Thread Starter
CanadianZed-J
How To Test a 247?
Long-story short, I'm looking to swap in a used 247 t-case I have.
Is it possible to test it while it's out of the vehicle?
While having the lever flipped in either high or low, I turned the input shaft and both the front and rear outputs turn. To me that seems like it works, but will it work when it's installed and there's resistance applied? There's also a little bit of slop when changing directions. Maybe 1/4". Is that alright?
Thanks,
CZJ.
So I installed the flux capacitor but the Jeep just won't do 88 mph.
-'99 WJ Limited, 4.7, Patriot Blue, 2" BB, 31" Mall-Terrains, Pavement Princess
-'97 TJ, Stone White, 4" Superlift, 33" SSRs, lunchboxed rear, 12K Titan winch, and 2.5 litres of exhillirating performance.
CanadianZed-J is offline
post #2 of 16 Old 11-04-2009, 12:46 AM
sandman
the slop is normal. the only way to test it is the way you did. just shift through the modes and spin to see if everything turns when its suposed to.
1993 Jeep ZJ. 4.0
sandman is offline
post #3 of 16 Old 11-04-2009, 07:11 AM
GraKee99
Rapist Wit
GraKee99's Avatar
Tie you jeep to a tree and see if both front and rear tires spin.
Brian
WJ, WK, CJ5
GraKee99 is offline
post #4 of 16 Old 11-04-2009, 07:30 AM Thread Starter
CanadianZed-J
And that will tell me if the t-case sitting on the floor of my garage works?
CZJ.
post #5 of 16 Old 11-04-2009, 07:43 AM
GraKee99
Rapist Wit
GraKee99's Avatar
Yep, just do it. Don't ask questions.
Brian
WJ, WK, CJ5
GraKee99 is offline
post #6 of 16 Old 11-04-2009, 08:58 AM
UltimatE
Resident Audio Guru
UltimatE's Avatar
Agreed, 1/4" slop is normal. Now if you have chain SLAP, that is bad. That is when you can hear the chain hitting the case.
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #7 of 16 Old 11-04-2009, 01:09 PM Thread Starter
CanadianZed-J
Alright, thanks guys. From my 10-second inspection the case seems to be ok. My plan was since it was already out and I was having a tranny shop do the swap (no time and it's a PITA job), I was going to have them crack it open, inspect it, replace anything it needed then install it. However, I'm a firm believer in not fixing it if it ain't broke. I don't want to turn a $150 job into a $600 job to make a working t-case still work. The 247 is generally a good horse so I think I'll try my odds installing it as-is.
CZJ.
PS. GraKee99, my neighbour is pissed about me pulling out his shrubs.
post #8 of 16 Old 11-04-2009, 03:15 PM
sandman
are you sure the input shafts are the same?
1993 Jeep ZJ. 4.0
sandman is offline
post #9 of 16 Old 11-04-2009, 03:23 PM Thread Starter
CanadianZed-J
You mean the same between the two t-cases?
This is the original t-case in the Jeep. Thinking it was pooched, I swapped it out with another only to find it was a differential problem that led to no 4x4.
CZJ.
post #10 of 16 Old 11-04-2009, 03:41 PM
sandman
ooh, i see
1993 Jeep ZJ. 4.0
sandman is offline
post #11 of 16 Old 11-04-2009, 05:59 PM
cmonson
I just did a 247 to 247 swap and it took a total of 2.5 hours on my back in the driveway.
Very easy to do and you do not require anything but basic hand tools.
I do see you are from up North, but if you have access to a garage it is an easy job.
cmonson is offline
post #12 of 16 Old 11-04-2009, 08:54 PM
jj99
Sorry to ask another question in this thread, but I might be making this swap myself. How much does the T-case weigh? Wondering if I need a transmission jack or if I can balance it on my floor jack to get it in.
jj99 is offline
post #13 of 16 Old 11-04-2009, 08:57 PM
sandman
you can lift it your self but by no means is it light. i didnt use a jack at all.
1993 Jeep ZJ. 4.0
sandman is offline
post #14 of 16 Old 11-04-2009, 09:17 PM Thread Starter
CanadianZed-J
I think I've read before it was around 80 lbs. I carried mine today and that seems about right.
LOL, yeah, I'm from up North where our Jeeps don't fit in our igloos and our tools are made from stone and caribou bones.
I have a heated garage and my dad has a heated garage with a hoist. What I don't have is time and yesterday I had it undercoated so I'm more interested in someone else going under there. After calling around, tonight I dropped off the Jeep at a reputable tranny shop who'll do the job for $200. For 200 bucks I'll have it swapped by pros during the day while I'm at work just down the street. Awesome.
(Last fall a buddy and I removed a 247 from my parts Jeeps outside, on sand, temps below freezing. Was a total PITA with squeezing our big hands on top of the t-case to get to those bolts with a lot of 1-click ratcheting. I do nearly all the work on all my Jeeps but for the jobs I don't like I contract out.)
CZJ.
post #15 of 16 Old 11-05-2009, 06:36 AM
cmonson
don't worry, I lived in Edmonton for 23 years.
cmonson is offline
How do you test the IAC Basscrazy51 ZJ Grand Cherokee Forum 5 12-03-2009 09:25 AM
Test LOCNROL WK Grand Cherokee & XK Commander Forum 0 08-30-2009 05:07 PM
How to test the VIC Desuxdecchi ZJ Grand Cherokee Forum 0 08-06-2009 03:09 PM
PCM test? liredneck ZJ Grand Cherokee Forum 3 03-03-2009 07:48 AM
IRO LA Kit test 10achik ZJ Grand Cherokee Forum 52 03-12-2007 09:29 PM
