How to successfully search this forum - JeepForum.com
post #1 of 13 Old 08-13-2012, 05:41 PM Thread Starter
jgrantham
I don't know if many other people have had issues searching through old posts like i have, but I thought i would share the method that i have been using. It seems to work pretty well.
The trick is to not use the built in function, but to use Google. Below is a couple of examples of using the "site:" search feature to only search the ZJ forum (f13):
site:http://www.jeepforum.com/forum/f13/ u joint cv swap
site:http://www.jeepforum.com/forum/f13/ 46RH transmission fluid filter change
Hope this helps somebody!
jgrantham is offline
post #2 of 13 Old 08-13-2012, 06:02 PM
SDHarleydad
1994 ZJ
I couldn't agree more... the search functions of these forums are lousy. Using goole is much easier
Casper
1994 JGC Laredo
SDHarleydad is offline
post #3 of 13 Old 08-13-2012, 06:18 PM
PolkaPower
I use google.
PolkaPower is online now
post #4 of 13 Old 08-13-2012, 06:21 PM
Yardman Harry
O
Yardman Harry's Avatar
If you can't use the search feature correctly the PEBKAC is the root cause...
Oh, and this information already exists... in a FAQ for newbs
http://www.jeepforum.com/forum/f35/f...nction-738716/
1996 Jeep Grand Cherokee. V8 - 5.2 litre 242 SelecTrac. SURCO Safari Roof Rack
Hunter Green
1997 Jeep Wrangler Sahara Ed. I6 - 4.0 litre, 4" SL, D44 rear, 4:56 Gears, AA SYE with double cardon custom rear Drive Shaft, IRO Adj CAs, Kevins Rear Adj TB with JOHNNY JOINT end
1999 Mazda Miata MX5 - Jet Black
1990 Jeep Cherokee Sport I6 - 4.0 litre
White
~Junked~
Yardman Harry is offline
post #5 of 13 Old 08-13-2012, 06:58 PM
MJ14
Yeah, I always have trouble using this search function, but google works well. Especially if you put whatever you're searching for in "" it really narrows it down a lot.
MJ14 is offline
post #6 of 13 Old 08-13-2012, 07:25 PM
RazorbackZJ
1994 ZJ
Like it says in the sticky the search function for non-paying members does not work quite as well.
RazorbackZJ is offline
post #7 of 13 Old 08-13-2012, 07:33 PM
PolkaPower
It doesn't matter paying or not it's not nearly as good as google is.
post #8 of 13 Old 08-13-2012, 07:47 PM
sevenscrew
I find the reason that google works better is because it gives you so much more results , where as if you search it on the jeepforum, it doesnt give you exactly what youre looking for most of the time. but i try the search before google usually lol. i will be a paying member one day, but right now i am constantly needing things to keep my zj driving lolol
1997 Limited 5.2L - SOLD
2016 2DR JK
sevenscrew is offline
post #9 of 13 Old 08-13-2012, 08:00 PM
CrzyMtnMan
Not to be a kiss butt, however most Google searches will come back to this forum. Hard times have left a reminder to add my token to the site currently, however an issue with my Jeep was easily solved with one search here, upon purchase and just tonight. I found this home from a beginner Google search years ago upon purchase, and still use the forum today. I will throw my nickle in the hat this week though, as finally have some extra funds to help a great resource. This by no means is a guilt inspired post, when I take info I leave info, or at least support JeepForum. Props to the OP, as a Jeepforum search or a standard internet search will bring you here, if you enjoy your vehicle, try to offer something in return for the information you find.
My 2 cents.
1996 ZJ - That 2nd Oxygen sensor, yeah some serious butt connectors and heat shrink there, how is that for off road modification! - Still stock.
CrzyMtnMan is offline
post #10 of 13 Old 08-14-2012, 06:11 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Polka can't spell SEARCH.
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #11 of 13 Old 08-14-2012, 09:18 AM
PR1AWRet
2002 KJ Liberty
You are trying to access a webpage that is only accessible to Premium Members.
So no it won't work for us. Thanks for the Google info. Out of the 4-5 other sites I go to as a non member, this is the only forum where I can't access the Advanced Search. Again, maybe just a web problem.
PR1AWRet is offline
post #12 of 13 Old 08-14-2012, 09:26 AM Thread Starter
jgrantham
i agree
My 2 cents.
I totally agree, this site has given me the confidence to work on my Jeep with excellent help and for the most part a great community. When people are able they should definitely get a membership they can afford (I will when I get another job...)
post #13 of 13 Old 08-14-2012, 09:41 AM
PolkaPower
Originally Posted by texas zj1 View Post
polka can't spell search.
cerch!
search , tips
search search search and can't find..... bnw WK Grand Cherokee & XK Commander Forum 2 02-05-2012 07:27 AM
Auto Dim Side view mirror successfully added! HokieBrett ZJ Grand Cherokee Forum 8 01-12-2012 04:39 PM
The WK to search for Highway 4x4 WK Grand Cherokee & XK Commander Forum 37 08-08-2010 10:45 PM
search? Arkansas_WJ ZJ Grand Cherokee Forum 6 08-29-2006 08:37 PM
Longest You've Successfully Gone Without A Transmission Fluid Change? Briandl ZJ Grand Cherokee Forum 7 08-27-2006 05:30 AM
