-   -   How to: Remove ZJ Cladding Molding w/ pics (http://www.jeepforum.com/forum/f13/how-remove-zj-cladding-molding-w-pics-915501/)
joburocks 12-02-2009 03:15 PM
How To: Remove side cladding moulding molding from door body etc..
Difficulty: easy
Tools: flat screwdriver or plastic puddy knife, custom bent tool (optional for better results)
What will my ZJ look like without cladding?
Before:
http://img163.imageshack.us/img163/9808/clad1.jpg
After:
http://img121.imageshack.us/img121/2350/clad2f.jpg
Paint underneath the cladding may be scratched
http://img3.imageshack.us/img3/5498/clad3j.jpg
There will also be tiny nubs and holes left behind that the cladding clips mount to
http://img14.imageshack.us/img14/7683/clad4.jpg
Mounting Explained:
There are 4 pieces per side not including bumpers.
From front to back
Piece #1 is held on by 3 screws in the wheel well and one white clip.
Piece #2 is held on by about 5-6 clips
Piece #3 is held on by 3-5 clips and a plastic nut that is inside the door
Piece #4 is held on by 3 screws in rear wheel well.
White clips are used to hold the cladding to the body of the truck. The top of the cladding sits in the top lip between the body and the clip. See picture 1 top of clip (ignore arrows for now)
Pic 1
http://img3.imageshack.us/img3/7391/clad6.jpg
The bottom of the cladding snaps into the clip. See picture 2
Pic 2
http://img121.imageshack.us/img121/1584/clad8.jpg
The clip is held on the truck with a sliding lock system. See picture 1. Blue arrows point in direction to remove clip from body.
Procedure For Removal:
The trick to the whole game is getting the cladding off the body without breaking the clips. See picture 3.
Pic 3
http://img121.imageshack.us/img121/7992/clad7.jpg
The problem is that the clips tend to break at the body's metal nub as in picture 3 rather than release from the thick plastic nub on the cladding.
If you look at picture 2 in the bottom right hand corner in blue, it depicts the shape of tool that would be necessary to get behind the clip on the cladding side and pop the cladding off, leaving the clip attached to the truck.
The procedure should always be.
  1. Remove any screws holding the piece (piece 1 and 2) or the nut for piece 3 (see picture 4 for door nut on piece #3)
  2. Pop the clips at the bottom of the cladding all the way down the piece your working on. Pulling away from the truck body out towards your body. Trying not to break the clips off of the body by using a special tool to separate them only from the cladding. Be careful not to pull the cladding to far away from the body or you will crack the cladding or clips at the top.
  3. Once the piece is free at the bottom, lift the piece upwards towards the roof of the car, sliding it free of the clips, or if the clip is still on the cladding sliding it free from the body. Always up.
  4. Remove the clip from the body of the car.
* EDIT: Opening the doors and laying under the door while looking up and prying the clips will give you greater success. I used a bent brake tool and removed all clips without breaking.
Pic 4
http://img121.imageshack.us/img121/5120/clad5.jpg
Hopefully that will clear things up for first timers.
EMTFFNJ 07-22-2010 03:06 PM
I know this has been here for a while, and a little bit of a resurrection here, but from anyone thats done this, Does it matter if the clips break? Im taking my cladding and everything off to sand down the area and repaint it with a truck Bed liner.
KJK 07-22-2010 03:39 PM
If you aren't planning on reusing them then it won't matter.
testify 08-02-2010 07:57 PM
I just want to get a second clarification- It is possible get replacement clips then. Is that correct? I'm removing mine for paint prep this week, and I tend to break thing when I take them apart.
Thanks-
ZJ98 12-01-2010 11:13 AM
Hi there I was looking for the cladding or molding the goes under the dorr cladding anyone know where I can get them???
ZJJAMES 12-01-2010 11:52 AM
Junk yards have tons of zjs to take the clips from.
bigbossd1030 12-01-2010 04:11 PM
I wish I was in your area, the closest JY around here has one (If I'm lucky) every 8 months or so.
merkovd 11-09-2012 10:29 AM
cladding removal
Good stuff on how to get the cladding off. I am going to prep a 96 for paint so need to pull the cladding. Is there any way to get the pictures back up? I can only see the before and after photo, but not Pictures 2, 3, 4. I would like to see the tool mentioned.
joburocks 11-10-2012 07:48 AM
Unfortunately I removed the pics from my computer about 8 months ago. Will have to use photobucket next time.
B93 11-10-2012 09:03 AM
All you need to do is slide your Jeep in to a tree, they'll fly right off!
merkovd 11-12-2012 08:32 AM
parts
If you have any of the white clips, I would be interested in getting them in case I break mine. I think I will pass on the "hitting the tree" method. Just does not seem like the best way to go, although it could save some bucks since I would not have to paint it.....
merkovd 12-11-2012 01:38 PM
cladding off, new paint on
3 Attachment(s)
Got the cladding off. fixed some hail dents, got the fender straightened, and the new paint is on. Here are some pics after painting. Too bad is was an overcast day, you can't appreciate how bright it is. It was painted with a Sherwin Williams commercial urethane paint (I am told it is the same as used by Peterbuilt on new trucks). Cladding and pin strips are next. Would really like to do a lift, can't spend the bucks on an old Jeep though.
riot1987 12-11-2012 02:00 PM
Believe me even on overcast days yo can see you bright it is.. Looks pretty good. Did you paint it yourself? It has a boo boo, how cute:hahaha:
jeepjeep523 05-30-2013 04:41 PM
this jeep is sick!!
zRoxxah 06-01-2013 02:59 AM
It looks so much better gone and freshly painted. Check mine out!
http://i431.photobucket.com/albums/q...ps9c9d99ee.jpg
http://i431.photobucket.com/albums/q...ps43508ec5.jpg
http://i431.photobucket.com/albums/q...ps4b0d4d91.jpg
http://i431.photobucket.com/albums/q...ps5ab61c88.jpg
The time now is 10:06 PM.
