How to: Remove ZJ Cladding Molding, Details/W Pics - JeepForum.com
post #1 of 10 Old 04-14-2012, 09:36 PM Thread Starter
hdrocknroll
There is a good write up in the facts section, on this forum on how to remove your cladding, see here, How to remove cladding on 93-98 ZJ's
I thought it would be a good idea to add a few more details to this.
I am getting ready to paint my cladding and bumpers.
Until today I didn't know exactly how the cladding snapped into the clips.
The first one I popped off, I broke the clip, because I just stuck the tool in and pried it out, the rest of them. I put the tool in and twisted the handle back and forth a little on each side of the tab, to loosen it up a bit, then I put the tool in the middle and twisted it the same way until the clips popped off.
In the first picture (below) is the tool, I used to remove the cladding, and all the clips and cladding, I removed from the donor Jeep.
. I only needed one piece of replacement cladding, but just went ahead and pulled them all.
This picture shows two broken clips and one good clip.
The one on the left you can clearly see where it is broken, the one in the middle you must look close to see the little bit that is broken, so it won't hold under the pin that is on the door. The third one on the right with my blood on it ( The 93 I got them from was rusted out and got me good) is a good non-broken clip.
This picture shows (top) a partial view of the inside of the cladding I got from the donor Jeep, with the tabs still intact.
My cladding (bottom) you can see ( full view) the tabs inside the cladding are broken right off,, which is why I had to replace that piece of cladding.
The Tabs were broken when I got the Jeep.
This picture is just a close-up of the tabs inside the cladding that snap into the clips.
This picture is a close-up of the tabs broken off.
This picture shows a clip snapped onto the tab on the inside the cladding,. This may give a better idea of how to go about getting them off.
This picture kinda,shows, the position of the tool, to get it up in there.
The tool needs to be between the white clip and the cladding itself.
Of course you could also use a screwdriver.
If taking off your cladding is mysterious, and you're worried about breaking stuff, maybe this will help..
But , you must look at the write up in the facts section.
Always !! Keep A Firm Grip On Your Tool !!
Watch Out For The Air Hose Gone Wild!! Or Wear A Cup,: True Story
Originally Posted by rooster51 View Post
Whats the worse that can happen? Your jeeps already broke.
hdrocknroll is offline
post #2 of 10 Old 04-15-2012, 06:53 PM
fljeepney
Just took mine off before it got dark.Didn't care how it came off,but it sure looks alot better when I cleaned all the dirt from underneath it.
fljeepney is offline
post #3 of 10 Old 05-06-2012, 10:17 PM
billfish16
Attachment 381044
Attachment 381069
Thx! Your post and the post you referenced were a huge help when I pulled off my cladding. I only cracked one clip, about a third of the way through. I broke the pin/rivet holding part on four of the clips. Rather than try to find replacement clips I just put a dab of Silicon caulk on the back of the clip where the pin/rivet seats, placed the clip over the pin/rivet and held it in place on the door with masking tape. I let the caulk sit overnight and it was holding solid the next day.
One other thing I did was place a dab of petroleum jelly on the tab on the back of the cladding to help it slide into the brittle clip without snapping it.
billfish16 is offline
post #4 of 10 Old 05-07-2012, 01:16 AM Thread Starter
hdrocknroll
I saw your pics, after U painted, looks great.much better than gray IMO
post #5 of 10 Old 03-31-2014, 05:31 PM
rmckinnie
When you have the cladding off, what do you fill the holes with or does it matter?
rmckinnie is offline
post #6 of 10 Old 03-31-2014, 05:57 PM
PolkaPower
There aren't any holes. There are little metal pegs that stick out where the cladding attaches at the top.
PolkaPower is offline
post #7 of 10 Old 03-31-2014, 05:58 PM
PolkaPower
There aren't any holes. There are little metal pegs that stick out where the clips hook on to.
post #8 of 10 Old 04-01-2014, 12:45 AM
xcaliber81
there's 4 holes actually two on the front fenders and 1 or 2 on the rear doors.
xcaliber81 is offline
post #9 of 10 Old 04-01-2014, 08:00 AM
PolkaPower
Darn. I don't remember holes on my 95. I took the cladding off totally. Must be getting old.
post #10 of 10 Old 04-01-2014, 11:49 AM
xcaliber81
Lol so did I.
cladding
How to: Remove ZJ Cladding Molding w/ pics joburocks ZJ Grand Cherokee Forum 26 03-20-2016 07:21 PM
HOW TO: Remove the side cladding on a zj Tim7 ZJ Grand Cherokee Forum 7 07-20-2011 10:39 PM
Any ZJ PICS without cladding??? -cAcHe- ZJ Grand Cherokee Forum 21 04-15-2008 08:40 PM
Some more pics of my ZJ without the cladding. nitrox28 ZJ Grand Cherokee Forum 13 05-22-2007 02:34 PM
How do you remove the cladding fiy123 ZJ Grand Cherokee Forum 14 12-24-2004 12:16 PM
