How to remove wheel bearing hub.. - JeepForum.com
post #1 of 18 Old 07-26-2012, 01:49 PM Thread Starter
Candymancan
Posted this an hour ago in my other post, but i need an answer now cause my car is apart in the parking lot so yea..
I got the axle nut off, the 3 bearing bolts out... i cannot get the hub to budge tho.. I tried a hammer and chisle i tried smacking the corner where the bolts go in with a hammer and it wont budge it.. Its a CV axle so there is no way to put a tool in a wedge and move the steering wheel to push it out like i've seen..
Only way i can think to remove it get my sledge hammer out and ruin the hub.. But the hub is good and I dont want to spend $100 on another one
Candymancan is offline
post #2 of 18 Old 07-26-2012, 02:16 PM
jtackerman28
Hit it till it comes there's no other way
3.5 re lift, double sheer front tb, 31" wrangler duratecs
jtackerman28 is offline
post #3 of 18 Old 07-26-2012, 02:25 PM
Technohead
If you have been hitting the hub (i.e. unit bearing) with the axle nut removed then you probably already ruined it.
I normally use a slide hammer in such situations. Beating on something with a hammer is bad form.
P.S. When you do put it back together, apply Never-Seez first.
-Eric
Technohead is offline
post #4 of 18 Old 07-26-2012, 03:10 PM
1SASjeepster
Stop using the damn hammer! On most things, if you resort to that you will break it. It takes a slide hammer and a hub remover tool THAT CAN GENERALLY BE PICKED UP AT ANY AUTO PARTS STORE. IT MUST BE PULLED OFF, NOT HIT OFF! Now the good news is the hub assembly isn't too expensive NOR IT THE CHILTON'S MANUAL FROM THE SAME AUTO PARTS STORE. Come on...
Take care,
Check out "YJ V6 Conversion" if you want to see a frame up restoration of my 1992 YJ.
Check out "WWII Jeep Photos AND Restoration of..." if you want to see the original JEEP in action...
1SASjeepster is offline
post #5 of 18 Old 07-26-2012, 05:13 PM Thread Starter
Candymancan
I wasnt hitting the bearing part itself. I was hitting the points that stick out where the bolts go in, that doesnt affect the bearing at all.... you guys think im stupid ?
I managed to get it off by screwing in 2 different bolts a little bit and hammering the bolts and it pushed it out enough to where i could use a flat tip screw drive and hammer to chizle it out lol
Only took me an hour ina half to get the freaking thing off.., Pulled the old axle out put the new one in gently and re-assembled it all.. I put some grease where the hub fits into.. I didnt have anti sieze on me.. Torqued all the bolts back to 75lbs and 175 for the axle nut, put the cotter pin and crown back on and test drove it.. Drives fine..
I tried to attempt the other side but I couldnt get the axle nut to budge even with my 28 inch breaker bar.. The other one was easy this one meh... So i sprayed some pb blaster on and put the tire back on I'll mess with the other side when it cools down in the next few days... Took me like 4 hours to do one side lol.. Mainly because it was 104 outside, i had no shade,took like 10 breaks lol and my disk in my lower back is bad i could barely stand up today let alone work on the Jeep lol.. What a PITA changing axles is on rusted out parts..
This Job was worse then doing my viscous coupler with the TC still attached to the tranny... much much worse, but hey i saved myself like $200 in labor charges lol..
post #6 of 18 Old 07-26-2012, 06:09 PM
1SASjeepster
Candymancan,
I am glad you were successful with your hub. God I hate to work on a vehicle in 100+ degree weather. I hope the other one comes for you a lot easier. Good luck with your back.
Take care,
post #7 of 18 Old 07-26-2012, 06:25 PM
gearheadnick
Get a 5 foot steel pipe that fits on the handle of your breaker bar to give yourself extra leverage. I've always used a long pipe to remove the axle nut on many different types of vehicles. I don't like to struggle if I don't have to.
My cylinder head overhaul:
My transmission overhaul: http://www.jeepforum.com/forum/f13/how-change-transmission-electronics-1560948/
gearheadnick is offline
post #8 of 18 Old 07-26-2012, 06:30 PM Thread Starter
Candymancan
I'll try to find one at like home depot or something
post #9 of 18 Old 07-26-2012, 07:10 PM
jtackerman28
Let the weight of the Jeep do the work. Lower it on the wrench.
post #10 of 18 Old 07-26-2012, 07:16 PM Thread Starter
Candymancan
Oh i see... thats a fantastic idea.. !!! I'll try it tomorrow thanks... Hopefully it works and doesnt break my breaker bar lol that thing was seriously bending weird when my 300 lbs *** was jumping on it
post #11 of 18 Old 07-26-2012, 07:25 PM
1skrewsloose
you've most likely done this, but a good soak down with wd-40 or whatever, and beats with a hammer every few hours to set vibration to get in will help.
1skrewsloose is offline
post #12 of 18 Old 07-26-2012, 07:37 PM Thread Starter
Candymancan
Yea i did that, its soaking tonight and tomorrow probly because I'll be busy and my back is shot i need to rest..
I'll upload pics when my damn photobucket works
post #13 of 18 Old 07-27-2012, 02:47 PM
thrashin
How To Install Replace Front Wheel Hub Bearing Jeep Grand Cherokee
If the link doesnt work you can do a search on youtube. Its for a wj but I think its about the same.
thrashin is offline
post #14 of 18 Old 07-27-2012, 02:57 PM
Canyon411
I read something once about backing the 3 bolts out almost all the way and then somehow putting a socket on them and then starting the jeep and letting the powersteering push the socket as it wedges againt something while the steering wheel is turned. Anyone know what I am referensing to here? I don't remember the exact process.
Canyon411 is offline
post #15 of 18 Old 07-27-2012, 09:16 PM
hdrocknroll
Replacing Front Wheel Bearing Assembly/How To
Always !! Keep A Firm Grip On Your Tool !!
Watch Out For The Air Hose Gone Wild!! Or Wear A Cup,: True Story
Originally Posted by rooster51 View Post
Whats the worse that can happen? Your jeeps already broke.
hdrocknroll is offline
Sign of a Bad Wheel Bearing or Ring and Pinion Bearing? torchd ZJ Grand Cherokee Forum 28 02-15-2014 08:14 AM
Wheel bearing pop? 98gczj ZJ Grand Cherokee Forum 5 06-28-2011 07:06 PM
242 bearing bad, Can i remove front drive shaft? ZJcrawler45 ZJ Grand Cherokee Forum 7 08-22-2008 01:02 PM
wheel bearing vs axle bearing. cifer6425 ZJ Grand Cherokee Forum 5 06-21-2007 01:04 PM
95 zj wheel bearing....CAN'T GET OUT! bigshow609 ZJ Grand Cherokee Forum 6 11-01-2005 12:39 PM
