How To remove rear quarter vents?? - JeepForum.com
post #1 of 8 Old 05-20-2012, 01:03 PM Thread Starter
rainman19154
I don't remember what thread I saw but they discussed the rear vents (between hatch and side window - vertical slats) and they had removed them for painting.
Here is a pic of the vents.. this was linked into another thread:
http://www.jeepforum.com/gallery/dat...jeep_vents.JPG
I made an attempt on mine but the sheet metal is thin and I didn't want to distort them out of shape.
With the hatch open, do they just pull straight rearward?
Are there safe pry points that won't tweak the pieces out of shape?
Here is the thread:
http://www.jeepforum.com/forum/f13/b...glass-1276531/
rainman19154 is offline
post #2 of 8 Old 05-20-2012, 01:42 PM
sevenscrew
i opened the hatchet, stuck a flat head behind the back of them, and pried gently outwards, look in the vents with a flash light youll see the fasteners screws or something, those just pop out so pry as close as you can next to all of them with a flat head evenly and evenutally itll pop right off. the slides back
1997 Limited 5.2L - SOLD
2016 2DR JK
sevenscrew is offline
post #3 of 8 Old 05-20-2012, 03:06 PM Thread Starter
rainman19154
Thanks... you walked me right through it.
Am adding a pic to help out whoever may come up against this later.
There is only one of the pins showing in this photo. This is the center; there is one near the top and another near the bottom. Pry it straight away from the body,
AND FWIW, I didn't have any issue with gasket that overlaps the leading edge. The rubber has some flex left in it, I guess.
post #4 of 8 Old 05-20-2012, 03:14 PM
sevenscrew
Glad to see it worked out good
2016 2DR JK
post #5 of 8 Old 05-20-2012, 07:13 PM
jtackerman28
What is that vent for?
3.5 re lift, double sheer front tb, 31" wrangler duratecs
jtackerman28 is offline
post #6 of 8 Old 05-20-2012, 07:29 PM
RazorbackZJ
1994 ZJ
Its just trim.
RazorbackZJ is offline
post #7 of 8 Old 05-20-2012, 07:43 PM
jtackerman28
Originally Posted by RazorbackZJ
Its just trim.
I mean the black vent under the one that he removed.
post #8 of 8 Old 05-21-2012, 01:37 AM
CatSplat
1994 ZJ
Air circulation. When your heater/AC blows air from outside the vehicle into it, air flows out those vents.
1994 5.9L ZJ, retrofitted UC package, NP242 swap, 17" JK Moabs with 32" BFG MT KM's.
The Jeep of Theseus
CatSplat is offline
Best way to repaint the fins by rear quarter glass Shadowless127 ZJ Grand Cherokee Forum 13 05-20-2012 01:08 PM
ZJ Rear Quarter Panel Covers - covering some wrinkles irispearl ZJ Grand Cherokee Forum 13 04-28-2012 01:03 PM
Rear quarter panel Trim Amerikozi ZJ Grand Cherokee Forum 6 02-06-2011 10:01 AM
Replacement Rear Quarter Window Blows Out on Freeway... ddruker ZJ Grand Cherokee Forum 9 05-08-2009 10:05 AM
How do you remove the vents on the rear sides? JackAysJake ZJ Grand Cherokee Forum 10 04-01-2009 05:09 PM
