How remove front rotors? - JeepForum.com
post #1 of 13 Old 10-08-2005, 08:14 AM Thread Starter
hinchcliffe
hinchcliffe's Avatar
Replacing the rotors on my wife's '04. I've got the calipers all off and I'm trying to get the rotors off. Do I just bangon themfrom the backside to knock them off? I shouldn't have to take the axle nut off right?
Any ideas?
'06 XK Inferno Red Crystal Pearl/Gray Leather
hinchcliffe is offline
post #2 of 13 Old 10-08-2005, 08:33 AM
greasefingers
greasefingers's Avatar
1994 ZJ
The hub is slightly rusted on. It only takes a small amount on the back side (where you cannot see). Make sure there is no jesus clip on one of the lugs (the bolt threads). It will look like a funny lock washer. Then a large rubber mallet works best. Strike the rotor at many different places on the front side. Something like at the 12 o’clock 6, 3 & 9 positions. If it does not break free then try the back side. If you do not have a rubber mallet then use a hammer and a small piece of wood to protect the rotor surface.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #3 of 13 Old 10-08-2005, 08:39 AM Thread Starter
hinchcliffe
Thanks my man, that's what I figured. I sprayed some PB Blaster on there and thought I should check here while they soak. thanks again.
post #4 of 13 Old 10-08-2005, 08:44 AM
Turbonut
Place the lug nuts back onto the studs to protect the threads, then wack the rotor around the studs with a heavy metal hammer, not on the machined brake surface.
Turbonut is offline
post #5 of 13 Old 10-08-2005, 07:35 PM
zjay
If you live in a winter salt area, you'll need a good 3 lb hammer. Show it no mercy on the backside and it'll come off. If you're replacing them, the dents won't matter!
96 GC Limited V8 245,000 miles Scrapped
04 GC Limited 4.0 264,000 miles
96 GC 4.0 175,000
zjay is offline
post #6 of 13 Old 10-08-2005, 07:38 PM
///BHRpowered
///BHRpowered's Avatar
usually there slightly rusted on, btu nothing eles holds them on. When I replace rotors I general just get angry that I can't pull them off and either kick, or use a hammer to ge them off. I mean your just going to throw them away anyway right?
"A dark and bitter chill fills the air. once thriving life wallows away into ash as he slithers past, the very stars themselfs part to make way for his haunting, yet oddly claim arrival. Bhr approaches." - Hatter
"But i have to say, BHR's rants go hand in hand with moring coffee to get my day started - RXL"
Admin -
///BHRpowered is offline
post #7 of 13 Old 10-10-2005, 06:44 AM Thread Starter
hinchcliffe
I just kicked the s&*% out of them front and back until they finally came loose. the PB Blaster penetrating oil helped after it soaked in a bit. New rotors and pads and shes good to go. Thanks all.
post #8 of 13 Old 10-10-2005, 09:48 AM
RIJEEP26
Sorry - dont mean to hijack - but I'm about to do the same on mine - rotors/pads all around - are there any good DIY sites for procedure on this stuff? I find DIY's so much more helpful than the books....I've done this full job on my bimmer before - but I would imagine its not exactly the same (for example - my bimmer rotors had a single hex bolt that held them on - which was a pain in the a$$ because it would freeze up and strip) - anyway - if anyone knows of any good DIY's out there for Jeep GC's please let me know. Thanks!
-Ray
RIJEEP26 is offline
post #9 of 13 Old 10-10-2005, 02:14 PM
///BHRpowered
There really isn't a big difference as long as you have the basics. the only bimmer iv ever changed brakes on was an 02 m3 which took forever. On the jeep its just 2 bolts that hold the caliper on, remove them both, knock it off get rotors off, put new rotors on, pull pads out of caliper, put new ones in, reassembly
Admin -
post #10 of 13 Old 10-11-2005, 10:04 AM Thread Starter
hinchcliffe
RI, e-mail me for any questions, now that I've done it. Pretty easy. Yeah, none of those little strippable rotor screws. Pretty easy. I spent more time getting the car on jacks and the wheels off, then the actual job took, one I got the rotors off.
post #11 of 13 Old 10-18-2005, 12:38 PM
RIJEEP26
Thanks Hinch - I will, if I have any problems - is there any good websites where you guys buy your OEM parts???
RIJEEP26 is offline
post #12 of 13 Old 10-18-2005, 01:26 PM
Airborne Lee
Airborne Lee's Avatar
go to the parts store and buy a Hayes book on your Jeep. I used it to do mine.
please buy this NEW IN BOX:
3 Previous Jeeps - 01 WJ Ltd, QD & UC - 01 WJ Ltd, QT II - 98 XJ Ltd
Airborne Lee is offline
post #13 of 13 Old 10-18-2005, 01:38 PM
RIJEEP26
I am a big Bentley fan - I will probably pick up one of those soon - the thing is - most of these books often over-explain things - I've found that sharing ideas on these forums is usually the most helpful....
RIJEEP26 is offline
WJ stuck fron rotors trying to remove-Help Chandler ZJ Grand Cherokee Forum 7 12-21-2011 06:31 PM
Front Rotors UTChavok ZJ Grand Cherokee Forum 9 07-09-2008 10:13 AM
front zj rotors that won't warp BradMB2004 ZJ Grand Cherokee Forum 2 07-15-2007 06:54 AM
96 front rotors jeeptorino68 ZJ Grand Cherokee Forum 8 06-27-2006 07:20 PM
Front rotors alan111 ZJ Grand Cherokee Forum 2 05-24-2006 08:14 PM
