how to remove the electrical rail - JeepForum.com
post #1 of 2 Old 09-07-2013, 09:35 PM Thread Starter
tacozappy
im not sure what the proper term is but basically where it has the cables that connect to the fuel rail. Im not sure how to remove the electrical rail off those threads, do you just yank it off?
tacozappy is offline
post #2 of 2 Old 09-07-2013, 11:08 PM
AVR2
Yes, you pull it gently but firmly off the studs. Once you've got it loose, be careful - some people are able to pivot it 90 degrees away from the rail, but mine starts resisting more than a few degrees of movement, and the last thing I want to to is break anything inside the injector harness.
AVR2 is offline
