how to remove 5.2L oil pan - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > how to remove 5.2L oil pan
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRockridge 4WD IS Taking Zone Offroad Suspension Lift Kits Northridge4x4 - Superchip Flashcal In Stock
Unread 08-26-2012, 09:37 PM   #1
mackcs212
1994 ZJ
i have been spending the past few hours trying to drop my oil pan on my 94 5.2L ZJ. i removed all the bolts to the pan, dropped the exhaust, starter, removed engine mount bolts and raised the engine up a bit but still feels like it is getting caught up on something at the back end. My oil pan does not have the low oil sensor. the pan is hanging about 3 inches down but just can weasel it all the way off... any advice or tips??? Thanks
mackcs212 is offline   Reply With Quote
Unread 08-26-2012, 09:39 PM   #2
Mickey_D
I think the sump filter hangs down low enough that it's not going to come out while the engine is still in the Jeep. That wonderful cross member is going to screw you.
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
Mickey_D is offline   Reply With Quote
Unread 08-26-2012, 09:50 PM   #3
94unlimited52zj
1994 ZJ
I ended up dropping my trans cross member to get the oil pan out when I did rear main and oil pump. But I still had to drop the front suspension to get the pan out.
94unlimited52zj is offline   Reply With Quote
Unread 08-26-2012, 10:10 PM   #4
mackcs212
1994 ZJ
I also dropped the trans cross member and jacked up the jeep so the suspension is hanging. the pan drops about 3 inches then gets caught up on something, still has an inch and a half before it hits the front axel. and it seems like it is the sump pump that it is caught up on... looks like i may have to try to replace the gasket without fully removing the pan.... sucks, i wanted to clean the pan out real good.
Unread 08-26-2012, 10:26 PM   #5
CatSplat
Derp.
CatSplat's Avatar
1994 ZJ
It is possible but it's a real PITA. IIRC I dropped the exhaust and trans crossmember and jacked up the Jeep to full droop and managed to wiggle it out. It took many, many different attempts to find the perfect way to wriggle it free.
1994 5.9L ZJ, retrofitted UC package, NP242 swap, 17" JK Moabs with 32" BFG MT KM's.
Junkyard Jeeper
CatSplat is offline   Reply With Quote
