How much would you pay for my Jeep, just curious - JeepForum.com
post #1 of 25 Old 02-14-2014, 10:15 PM Thread Starter
RoldGold
I've been considering the upgrade to a niner or 5.2, looking for a little more power, but I've got to justify it. I can't own both my 4.0 and another GC, however I don't have any interest in spending 5k on a niner and selling my 4.0 for 3k.
So just a quick "this is how much I think your Jeep is worth" answer would be great.
***Cons:
-Rust hole in driver side wheelwell, leads up into engine compartment underneath master cylinder area. http://www.jeepforum.com/forum/f13/h...-rust-1750378/
-Headliner is peeling, but that is on the to be fixed list
-Paint is peeling on the hood and passenger side panel, looks kinda bad
-Door panel vinyl is peeling on the rear doors (happens with all the 96's)
Maintenance record:
It's got a clean carfax, no accidents.
No other rust besides the wheelwell.
PO put in JKS front sway discos, aftermarket fog lights, Dodge Neon 703 injector swap.
Tires have probably 50-75% tread remaining.
Interior is spotless.
4.0 sounds and feels strong, and I don't race it or beat the hell out of it.
Trans feels pretty good, shifts hard into second when cold, but once it warms up it's nice.
T-case goes into 4 low with no grinding or trouble. Linkage is nice and smooth.
Note: any records listed below that do not mention a garage were done by me
11/24/2012 104900 Purchased Jeep for $3200
12/2/2012 Tires rotated, front to back
12/15/2012 New rear stabilizer bar links (Moog)
12/29/2012 New rear shock absorbers (Monroe Sensa-Tracs)
1/5/2013 New front shock absorbers (Monroe Sensa-Tracs), new hardware
1/9/2013 105053 ******* Garage installed Red Head Steering Gearbox, new power steering fluid reservoir & pressure hose
1/20/2013 New front track bar (Moog)
1/20/2013 Soldered fog light switch
1/20/2013 New downstream o2 sensor (Denso)
1/20/2013 New CEL bulb, reinstalled instrument cluster with dielectric grease
1/27/2013 Cleaned idle air controller
2/8/2013 New PSC Power Steering Gear Box
2/8/2013 Refilled power steering fluid reservoir, bled system
2/16/2013 1050xx New front & rear lower control arm bushings (Moog)
2/16/2013 1050xx New upstream o2 sensor (NTK)
2/16/2013 1050xx New steering damper (Monroe)
3/10/2013 105830 Changed rear differential fluid to Lucas 80w-90; New rear differential gasket (Fel-Pro)
3/27/2013 1060xx Aligned drag link
3/27/2013 1060xx Changed transfer case fluid (Advance Auto ATF+4)
4/9/2013 New front skid plate bolts (3x M10x1.5x35; 1x M10x1.5x25)
4/9/2013 New front driver side, and both rear door panel snaps
4/9/2013 Glued (contact cement) both rear door panel vinyl's
4/9/2013 Disconnected memory control unit from driver door
5/4/2013 1066xx Changed front differential fluid to Lucas 75w-140; New front differential gasket (Fel-Pro), Cleaned magnet
5/4/2013 1066xx Resoldered headlight switch and radio (all accessible contacts),cleaned potentiometers, reinstalled with dielectric grease
5/8/2013 1666xx Resoldered all points in the VIC, reinstalled with dielectric grease
5/18/2013 106860 Changed transmission fluid (Castrol ATF+4) and filter (Wix), New transmission pan gasket (Fel-Pro), Cleaned Magnet
6/1/2013 107107 Changed engine oil (Valvoline NextGen 10w-30 Conventional Motor Oil), Replaced oil filter (Mopar)
6/10/2013 1073xx Repainted front and rear wiper blade arms and roof rack with Rustoleum Flat Black and Rustoleum Gloss Clear Coat
6/10/2013 1073xx New rear hatch bump stops
6/13/2013 107340 New viscous coupler, with new transfer case fluid (Advance Auto ATF+4), reinstalled transfer case breather hose with a ziptie
6/13/2013 107340 Reinstalled transmission crossmember with new class 10.9 hardware, and retapped both passenger side nutserts because they were stripped while removing the old bolts
6/13/2013 107340 New headlight housings and bulbs (TYC), running light housings (TYC), and turn signal housings (TYC)
7/16/2013 107629 Shop removed broken bolt from frame at rear stabilizer bar bushing mounting point, retapped threads
7/16/2013 107629 ******* Garage replaced the front sway bar bushings (Moog), used new hardware
7/16/2013 107629 ******* Garage replaced the rear stabilizer bar bushings (Moog), used new hardware
7/18/2013 New radio (Pioneer DEHX3500UI)
7/24/2013 107656 Seafoamed the engine, through the air intake, did not stall out engine, used 1/3 can
8/3/2013 108153 Greased tie rod ends, front track bar, front sway bar endlinks, passenger ball joint (driver ball joint needs new zert)
8/3/2013 108153 Cleaned throttle body, installed with new gasket
9/5/2013 108341 New transmission mount with new class 10.9 hardware
9/7/2013 108370 New front brake rotors
9/8/2013 108403 New rear rotors
9/8/2013 108403 New rear brake pads
9/14/2013 108450 New rear calipers (old rear passenger caliper was sticking after brake pad replacement), Bled brake system and filled with new brake fluid (Prestone DOT3)
11/4/2013 109412 New running light bulbs
11/5/2013 109412 PA Inpsection & Emissions Passed (at ******* Automotive)
11/21/2013 109590 Seafoamed the gas tank, 2/3 can used
12/23/2013 110010 Flushed coolant from radiator and reservoir, replaced with new coolant (Advance Auto Parts). Bled system multiple times.
12/28/2013 110040 New tie rod ends and adjusting sleeves (Moog), lubricated front end components
12/28/2013 110040 Changed engine oil (Valvoline MaxLife High Mileage 10w-30 Synthetic Blend Motor Oil), Replaced oil filter (Purolator PureOne)
12/30/2013 110046 4 Wheel Alignment (Goodyear)
2/11/2014 Charged battery from 12.3 volts to 14.0 volts at 10 amps (when read cold)
1996 Grand Cherokee Limited 4.0L
PSC Steering Gear; NP249 w/ new VC; Moog TRE's, Track Bar, Stabilizer bar bushings and endlinks, control arm bushings
Still no lift, and almost no paint on the hood
RoldGold is offline
post #2 of 25 Old 02-14-2014, 10:27 PM
Myusername1674
That's a good list of work you've done there man. 2 questions. How many miles is on it? (If you listed it then my bad for missing it haha) annd do you have any pictures??
sent from, uh
95 FiveTwo ZJ, DD, Lifted, Locked on 35s,
(in progress)
Myusername1674 is offline
post #3 of 25 Old 02-14-2014, 11:44 PM
JasonStebbins
I would start at $2500.00 and go down from there.
Poop
JasonStebbins is offline
post #4 of 25 Old 02-15-2014, 06:31 AM Thread Starter
RoldGold
Really that low? Even with a relatively new viscous coupler and PSC steering gear, together more than $700 worth of parts?
RoldGold is offline
post #5 of 25 Old 02-15-2014, 06:34 AM Thread Starter
RoldGold
sent from, uh
Right around 110000 or so.
Note: The grill is now flat black, so this picture is kind of old.
Original resolution: http://farm8.staticflickr.com/7360/1...02f23482_o.jpg
RoldGold is offline
post #6 of 25 Old 02-15-2014, 07:20 AM
mrgimble
2015 JK Wrangler
You can't expect parts installed to keep a vehicle working properly to increase is value.
mrgimble is offline
post #7 of 25 Old 02-15-2014, 11:32 AM
zjosh93
I agree with Jason; start in the $2500-$3000 range and negotiate down. Any money spent on maintaining your Jeep up to the level of a running driving vehicle doesn't add any value to the Jeep. Your Jeep is probably more reliable now than comparable Jeeps but that is hard to quantify so it doesn't really factor into the cost. I'd rate your Jeep as "good" condition so it would get compared to other Jeeps in good condition. I'd negotiate harder because of all your work but your final price would depend a lot on what the market will bear.
zjosh93 is online now
post #8 of 25 Old 02-15-2014, 12:08 PM
PolkaPower
Depends largely on the area you are selling it in as well. You can ask a little more if you have repair records. If I were buying another one I would pay a little more knowing that a lot of stuff has been replaced or repaired. That's just less I have to do and it builds confidence that it's been well cared for. I would not add in the actual cost of the parts though. You will never get out of it what you put in but I would for sure try and get the most I could. List it high and if it doesn't sell then no skin off your back.
When I bought my 5.9 @127k in Vegas, the guy wanted 5000. That was down from 5500. Jeeps are more expensive there. It had been on the market for a little while. I talked him into 4500. He had ten years of maintenance records to go along with it and it was in great shape with no rust. I just added to those records and did all the major repairs. If I were to sell mine today I would start high like 5500 and go from there.
PolkaPower is offline
post #9 of 25 Old 02-16-2014, 11:33 PM
nicyousuckk
I kinda have the mindset that unless it's an orvis, 5.9, 5spd, ect... a clean well-maintained stock zj isn't worth more anything more than 3k. I agree with the 2.5k stated earlier.
nicyousuckk is offline
post #10 of 25 Old 02-17-2014, 09:01 AM
Dark_Sorrow
1994 ZJ
I bought my stock jeep with 135000 for 1600. Fully loaded with everything but a sunroof. And everything worked then and still works now.
Dark_Sorrow is offline
post #11 of 25 Old 02-17-2014, 09:24 AM
bigchieftaco
2005 WK
It's all about your location. I know I can pickup a very clean 96+ 5.2 for under 2k in my area. I was looking at one a couple weeks ago for $1800. Garage kept, no rust, 127k miles. 4.0s are even cheaper.
bigchieftaco is offline
post #12 of 25 Old 02-17-2014, 09:38 AM
McCloudsZJ
Because RaceJeep
McCloudsZJ's Avatar
I hate these feeler threads because I always feel bad throwing my $0.02 out there. Honestly, where I am, $2,000 is the MAX I'd pay for a 4.0, in good condition. I can find them all day for less than $1,000 in running condition.
I sold my last niner for $3,000 with almost $4,000 in receipts, and felt like I got a good deal.
In the garage: M1 4bbl
McCloudsZJ is offline
post #13 of 25 Old 02-17-2014, 10:04 AM Thread Starter
RoldGold
Don't feel bad! I appreciate the input everyone is giving me, it helps to make a decision on whether to sell or not.
I'm also trying to take into account I might be able to sell to less intelligent people who may be willing to pay lots just because of all the work done over the last year.
RoldGold is offline
post #14 of 25 Old 02-17-2014, 10:09 AM
newfieZJ
You put whatever price you want on it . The market will soon dictate the sale or no sale . It only takes one person to see what you have done and appreciate it .
Why the investment and now pull out ? You have a vehicle that should last a long time w/o issue . IMO , there's only 2 ways to get your money back , use it , or part it
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #15 of 25 Old 02-17-2014, 01:36 PM Thread Starter
RoldGold
I've been considering the upgrade to a 5.2 or 5.9 for more power. I've fixed everything that's been bothering me, except the paint on the hood and the rust hole in the wheelwell, because I don't know how to or can't afford to fix those two things. I'll have to borrow a friends welder this summer and figure out what I'm doing to fix the wheelwell, but I don't know what to do about the paint on the hood.
RoldGold is offline
