How much transmission fluid? - JeepForum.com
post #1 of 4 Old 05-02-2006, 10:22 PM Thread Starter
Tiamat-red
Hey yall.
I have a 95 ZJ I6.
According to my haynes manual it says to drain the transmission, then fill it back up with "about 2 quarts", run it, and fill to full.
Is 2 quarts all it's going to take?!
That seems a little low, at least relative to other vehicles I've owned...
So how much fluid should it need?
I just need to know how much to buy.
Tiamat-red is offline
post #2 of 4 Old 05-02-2006, 10:43 PM
GCherokee2001
When I drained and replaced the oil and filter last year in my girlfriend's 97 I6 Laredo, I believe I put in about 6 quarts. I also believe that's what my manual called for too.
2001 Grand Cherokee Laredo 4x4 (His)
-Stock
1997 Grand Cherokee Laredo 4x4 (Hers)
- Rancho RS9000's
- BFG All-Terrains 235/75 R-15
- Flowmaster Exhaust
- K&N Filter
GCherokee2001 is offline
post #3 of 4 Old 05-02-2006, 11:43 PM
Virmagicus
Virmagicus's Avatar
Just buy a barrel Actually it is 4 quarts.... after you add , get engine up to temp and recheck it .
Jeff
Virmagicus is offline
post #4 of 4 Old 05-03-2006, 06:59 AM
greasefingers
greasefingers's Avatar
1994 ZJ
Drain it first then and measure how much came out. Then go out and buy that amount plus one more.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
Which Transmission Fluid Do I Use for my AW-4? CrazyIvan888 ZJ Grand Cherokee Forum 19 11-13-2009 12:56 PM
Transmission Fluid home1028 ZJ Grand Cherokee Forum 5 07-06-2009 02:37 PM
how much transmission fluid? random155 ZJ Grand Cherokee Forum 4 03-02-2009 08:03 PM
is it ok to mix transmission fluid ?? crazydude2500 ZJ Grand Cherokee Forum 1 03-02-2009 02:12 PM
What transmission fluid should i use ? speedbullet2 ZJ Grand Cherokee Forum 22 07-12-2008 02:41 PM
