how much of the tie rod linkage to replace? - JeepForum.com
post #1 of 4 Old 07-12-2011, 05:15 PM Thread Starter
badkelly
2005 WK
i'm back with a 97 grand cherokee for the wife (dave ramsey car). long story short, i'm going to redo the front steering on it. i've done other makes (like camaros) but never a jeep. how much to replace on it? it pulls a little to the left and i'm going to do shocks and sway bars in the future for better handling, but i wanted to renew the front end now before the alignment. i figured:
tie rod ball joints,tie rod ends, steering damper, and drag link.
is this too much or not enough or is there something else i should consider while i'm in the immediate area?
badkelly is offline
post #2 of 4 Old 07-12-2011, 06:00 PM
sebian
Track bar, and control arm bushings (upper and lowers) would be well worth replacing. Also the steering stabilizer if it looks shoddy.
1995 ZJ 5.2L V8 318. 230,000 miles and still rollin.
List of parts not replaced yet:
sebian is offline
post #3 of 4 Old 07-12-2011, 06:34 PM Thread Starter
badkelly
2005 WK
does the pitman arm have a soft end on it? also, the whole track bar or just the bushings?
edit: also, i haven't pulled a wheel off yet.....are the main ball joints riveted in or are they bolted from the factory?
edit2: nevermind, the manual says they are pressed in. guess i'll have the shop do that with the alignment
badkelly is offline
post #4 of 4 Old 07-12-2011, 08:34 PM
sebian
If I recall correctly, the pitman arm just has a hole in it where the tie rod end connects.
Replace the whole track bar, save yourself the time, effort and knuckles of trying to press new bushings in.
re: edit 2: Borrow a ball joint press from a parts store. Auto Zone has like a $100 deposit for it, but you get it back when you return it. Makes easy work of the ball joints, and you can do each side in about an hour.
sebian is offline
242 linkage fix. ZJ5point2GCL ZJ Grand Cherokee Forum 3 06-10-2011 08:26 PM
Have to replace AC evap what else should I replace? crashcraddock ZJ Grand Cherokee Forum 17 06-28-2009 07:55 AM
Anyone using this TC linkage ... 1sportsdoc ZJ Grand Cherokee Forum 14 05-27-2009 04:20 PM
Wiper Linkage replace on 98GC NoreasterPlus2 ZJ Grand Cherokee Forum 0 10-05-2007 08:30 AM
Which Linkage?? GCJeeper1993 ZJ Grand Cherokee Forum 10 09-07-2006 02:21 PM
