How Much For A New Head Gasket? - JeepForum.com
post #1 of 9 Old 05-22-2007, 03:36 PM Thread Starter
Briandl
So I have a blown head gasket, 2002 WJ V8, does anyone have any idea how much it costs to have both gaskets replaced, and how many hours the job runs?
TIA
Briandl is offline
post #2 of 9 Old 05-22-2007, 04:29 PM
cmonson
why would you replace BOTH head gaskets.
Why wouldn't you just replace one of the head gaskets?
THat being said I would expect about 5 hours of labor/gasket. The gasket is about $40 I believe.
cmonson is offline
post #3 of 9 Old 05-22-2007, 05:27 PM
SpeedyCat3
Survivor
SpeedyCat3's Avatar
My impression was always that when changing a headgasket that has leaked on an engine that might have overheated, it was always better to resurface the head. Now resurfacing the head could change a bit the compression, so that would be the reason to do both sides.
Again, I have done only one side, and had no problems, but my engine had not overheated and I used new headbolts.
_o o o o_
|_Jeep_|
(OlllllllO)
[] ---o-[]
SpeedyCat3 is offline
post #4 of 9 Old 05-22-2007, 05:27 PM
cyberbrain
might as well do both since you will have the engine down to a long block anyway. it depends on how easy things go for the mechanic. if it all comes right off, then 5hrs is resonable. If not the mech could reach 8hrs. So it depends on what your mech charges. my personal mech charges me 68.90 a hr.
Ha, you can't get there.....hrm, watch me.
2008 Wrangler Unlimited X. 4dr, 4x4, 3.8 V6, 3.73 D44 LSD.
93 Grand Cherokee Laredo. SOLD. Sad to see it go.
cyberbrain is offline
post #5 of 9 Old 05-22-2007, 06:13 PM
cmonson
I would NOT bother changing both head gaskets. Take the head off that has the bad gasket and have the shop check it for straightness. If it checks out OK, then throw a gasket down and bolt it back up.
If you had a rig with 200K miles on it I would say go ahead and do both, but seeing you have a 2002 there can't be that many miles.
I
cmonson is offline
post #6 of 9 Old 05-22-2007, 07:01 PM Thread Starter
Briandl
I've heard it's a good idea to replace both because it doesn't cost twice as much, and this has been such a bad experience that I hope to not ever have to deal with it again.
But I'll certainly consider just doing one side.
96500 miles...
Oh and by the way, the engine didn't over heat before the headgasket blew, it actually over heated after because it was burning coolant and got low, but I noticed it and never got into the red zone...
Briandl is offline
post #7 of 9 Old 05-22-2007, 07:44 PM
cmonson
A head gasket is a fairly common item to go.
It really isn't going to save you that much money doing it now.
THe only thing it is going to save you is taking off and re-installing the intake. It really is NOT that big of a deal. 1 hour to take off, 1 hour to put on.
If you are going to put on a new head gasket on the side that is 100% fine, then you still are going to have to take off all of the accessories on that side off.
But hey it's your money. I will say this though. If you are taking both heads off, you might as well do a cam upgrade, and replace the timing components while you there. WOn't cost you that much more but the parts. You also might as well take both heads in to be rebuilt or at min checked out.
cmonson is offline
post #8 of 9 Old 05-22-2007, 10:52 PM
PumaZJ
Where are you located?
If you're in NC, bring it to me. I'll take care of it.
1998 ZJ - 36's & bent unibody - RIP
2004 WJ - Expedition build
2011 A4 - DD
PumaZJ is offline
post #9 of 9 Old 05-22-2007, 11:18 PM Thread Starter
Briandl
I wish, in San Antonio, TX...
Briandl is offline
4.7l oill fill spout gunk! Head Gasket? Cracked Head? kc8ztw ZJ Grand Cherokee Forum 10 10-29-2009 10:49 AM
head gasket careed ZJ Grand Cherokee Forum 4 07-08-2009 10:36 PM
Will a cracked head or head gasket...... jpl ZJ Grand Cherokee Forum 2 03-04-2009 08:35 AM
head gasket gone? darrenharris1@s ZJ Grand Cherokee Forum 7 01-07-2008 05:48 PM
5.2L head gasket job... Jose's Limited ZJ Grand Cherokee Forum 4 02-01-2006 07:49 PM
