how much fluid for tranny filter change? - JeepForum.com
post #1 of 8 Old 07-21-2009, 02:57 PM Thread Starter
npray
i have a 96 GC with 4.0l and i have been having some issues with the tranny not wanting to shift.. the fluid is dark and was low but i have no leaks i can see... I have a b&m super cooler, new filter, fluid and some lucas additive i'm going to put on this week , but need to know how much fluid i'm going to need?i bought six quarts plus the lucas and need to know if it will be enough??
npray is offline
post #2 of 8 Old 07-21-2009, 04:44 PM
cpudoc6
I did mine this weekend and used 6 qrt's
There are only 2 tools needed, Duct Tape and WD 40. If moves and isnt supposed to use the duct tape. If it dosn't move and is supposed to, use the WD 40!
cpudoc6 is offline
post #3 of 8 Old 07-21-2009, 04:49 PM
ZeeJay1997
I let mine sit overnight with the pan off and replaced 8 quarts
Be sure to use ATF+4
ZeeJay1997 is offline
post #4 of 8 Old 07-21-2009, 05:01 PM
WhiteOut
WhiteOut's Avatar
9 quarts, front end jacked up overnight
WhiteOut is offline
post #5 of 8 Old 07-21-2009, 06:12 PM
jeepemt
I used 6 quarts but only let it drain for about 30min. It was messier than hell though.
jeepemt is offline
post #6 of 8 Old 07-21-2009, 06:50 PM
ZeeJay1997
That was the reason i let mine sit overnight. It wouldnt stop dripping so I decided to wait a while, forgot about it, and drained 2 more quarts overnight. There's method to my madness.
post #7 of 8 Old 07-21-2009, 06:57 PM
Greeeeenberg
Question should you use RTV to seal it back up along with the gasket? I have heard yes and no.
97 ZJ Orvis 5.2 108K.
Member #1
Greeeeenberg is offline
post #8 of 8 Old 07-21-2009, 11:03 PM
WhiteOut
WhiteOut's Avatar
I used the gasket and a thin film of RTV around the bolt holes
WhiteOut is offline
Fluid change on 42re-filter gets replaced? my2monkeys ZJ Grand Cherokee Forum 8 09-25-2009 07:29 AM
tran fluid/filter change snooked321 ZJ Grand Cherokee Forum 2 09-19-2009 08:31 PM
Transmission fluid/filter change question RyanSBenson ZJ Grand Cherokee Forum 4 06-09-2009 01:48 PM
transmission filter and fluid change mesallem ZJ Grand Cherokee Forum 4 08-01-2006 02:54 PM
46RH Transmission Fluid / Filter Change wmchurch ZJ Grand Cherokee Forum 1 06-29-2006 04:08 PM
