How much does a water pump cost? - JeepForum.com
post #1 of 12 Old 08-16-2005, 01:53 PM Thread Starter
coolest_Stan
I think that replacing the water pump by myself is a little too hard of a task, since I don't even have any tools and whatnot, so I let the car dude do it. He said it will cost around $300.
Is this a good price?
Also, how much does just a water pump cost? (without laborfees and stuff liek that)
Thanks
93' Grand Cherokee Limited 4.0 L 190 hp 4x4
235x75 BFG Goodrich A/Ts
K&N Drop In Filter
New Coolant Resevoir Cap
Current Projects:
coolest_Stan is offline
post #2 of 12 Old 08-16-2005, 02:01 PM
Meerkat
A new one from Advance Auto Parts is $39.99, a remanufactured one from the same place is $29.98.
HTH
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
post #3 of 12 Old 08-16-2005, 02:12 PM
CajunWon
$300? it took me <3hrs to replace mine on the 4oh -& this was my first water pump replacement. Most of the time was spent finding the right bolts during reassembly.
I used a 3/8 socket set, a set of small crescent wrenches, 3/8 torque wrench & 2'x2' cardboard.
The Autozone ~$35 pump has worked great for nearly a year now.
CajunWon is offline
post #4 of 12 Old 08-16-2005, 11:28 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Did you mean for the Jeep or other types? Submersible, gas-operated, electric, solar?
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #5 of 12 Old 08-17-2005, 09:22 AM
PlatinumZJ
Senior Moment Member
PlatinumZJ's Avatar
Stan,
Replacing the water pump is one of the easier tasks in car repair. I did one once (on a '67 Rambler Rebel) on the side of the road, at night, with only a pair of vise grips (man was that a PITA); I was a pooooor collage kid at the time. Didn't you invest in a metric sockets set a while ago? So go down to the auto parts place get some penetration oil, a Haynes manual, a new water pump, thermostat and radiator cap and DYI. We know you can.
Then send us the $$s you saved
Doug
When all is said and done, more is said than done.
Platinum '97 ZJ LTD, I6 (see profile) Paid for!
Links:
for ZJ & WJ stuff,
for performance stuff. I6 performance info at
Other stuff: Kevin's Roof Rack. KOR sliders, Bored 62mm TB, Blaupunkt Bermuda w/ ipod, Brembo Slotted rotors,
OME steering stabilizer, H4 headlight upgrade...
PlatinumZJ is offline
post #6 of 12 Old 08-17-2005, 09:43 AM
jadams68
jadams68's Avatar
Ummm...what did u do with the original bolts?
[QUOTE=CajunWon]Most of the time was spent finding the right bolts during reassembly.
I used to own two CJ's...Perhaps a 3rd is in the future?
jadams68 is offline
post #7 of 12 Old 08-17-2005, 10:26 AM
CajunWon
[QUOTE=jadams68]Ummm...what did u do with the original bolts?
"Most of the time" < should have said "Most of the frustration"
I just put them all into a bucket -unsorted. PS bracket bolts are various sizes. oh, & had to go back in to further tighten the belt after a test drive. It's still a smidgeon loose as occasionally the A/C squeals during the 1st minute of driving (BFD).
CajunWon is offline
post #8 of 12 Old 08-17-2005, 01:48 PM Thread Starter
coolest_Stan
So is $300 expenseive for a water pump repair or not? (not comparing to me doing it by myself)
Just want to know
Thanks
K&N Drop In Filter
Current Projects:
post #9 of 12 Old 08-17-2005, 02:10 PM
jadams68
jadams68's Avatar
It's about right... PepBoys may do it cheaper.
jadams68 is offline
post #10 of 12 Old 08-17-2005, 06:50 PM
CajunWon
If $80/hr is reasonable in your area then $300 is a fair price.
CajunWon is offline
post #11 of 12 Old 08-18-2005, 01:05 PM Thread Starter
coolest_Stan
alright thanks guys
K&N Drop In Filter
Current Projects:
post #12 of 12 Old 08-19-2005, 04:33 PM
turk
I just replaced my water pump Wednesday in about 3.5 hours. I was actually taking my sweet old time and it all went smoothly. Water pump at autozone... $35.00, 2 gallons of antifreeze... $14.00, a tube of RTV high temp silicone... $5.00,
Spending quality time with your JEEP... PRICELESS!!
If you do it yourself, check your serpentine belt to see if it needs replaced... It is a perfect time to do it!
Turk
It doesn't matter what you drive as long as it is a JEEP.
98 JGC Laredo 4.0, 3" lift, Rustys adjustable UCA's & LCA's, Custom K&N intake, high flow exhaust, Jet chip Stage 2 and 32x11.5 BFG TA's
turk is offline
water pump + power steering pump z rated ZJ Grand Cherokee Forum 3 09-16-2014 06:50 AM
Water Pump $$$$ Tbauer44 ZJ Grand Cherokee Forum 4 10-27-2009 10:16 PM
another water pump JackStraw ZJ Grand Cherokee Forum 11 06-06-2008 10:50 AM
R.I.P Water pump... dcvance87 ZJ Grand Cherokee Forum 5 05-12-2008 01:16 AM
Water Pump MaineZJ ZJ Grand Cherokee Forum 2 09-05-2003 09:17 AM
