How Much Coolant Needed to Flush Radiator and Overflow? - JeepForum.com
post #1 of 10 Old 10-01-2009, 07:38 AM Thread Starter
CobraSpdRH
Just stopped by NAPA and at $15 a gallon that Zerex G-05 stuff is expensive! I just want to flush my radiator and overflow tank, not planning on emptying out the block. According to WJJeeps.com my 99 takes 13 quarts total, so at 50/50 that would be 6.5 quarts. How much will I need for just flushing the radiator and overflow? A gallon of coolant and the same of distilled water?
EDIT: I am an idiot who cannot read and/or do conversions...I've corrected my math
CobraSpdRH is offline
post #2 of 10 Old 10-01-2009, 12:08 PM
vosevichs
That's Quarts, not Gallons. 13 guarts = 3 gal. 1 guart. 1.5 gallon of anti-freeze and 1 .75 gal, of water will be fine.
Scott Vosevich
vosevichs is offline
post #3 of 10 Old 10-01-2009, 12:16 PM
LordHobbit
Wait wait wait, do you have G-05 in there now? Or is it just regular boring coolant. Make sure this is important they do NOT mix. Chrysler didn't convert to G-05 until 2001 model year: http://www.valvoline.com/pdf/Zerex_CoolantChart.pdf Make sure you do not mix the coolants. And use distilled water.
93 red ZJ 190k 4.0. Spent more money than I should have ...
Isn't red the only color a vehicle should be?
If at first you don't succeed, use more speed.
LordHobbit is offline
post #4 of 10 Old 10-01-2009, 12:20 PM
vosevichs
Good Point lordhobit. I switched to HOAT when I flushed my system last time.
4.0L engine - Adding additional coolant
The use of aluminum cylinder blocks, cylinder heads and water pumps requires special corrosion protection. Only Mopart Antifreeze/Coolant, 5 Year/100,000 Mile Formula (glycol base coolant with corrosion inhibitors called HOAT, for Hybrid Organic Additive Technology) is recommended. This coolant offers the best engine cooling without corrosion when mixed with 50% distilled water to obtain to obtain a freeze point of -35F (-37C). If it loses color or becomes contaminated, drain, flush, and replace with fresh properly mixed coolant solution.
CAUTION: Do not use coolant additives that are claimed to improve engine cooling.
Scott Vosevich
post #5 of 10 Old 10-01-2009, 01:27 PM Thread Starter
CobraSpdRH
Originally Posted by vosevichs View Post
That's Quarts, not Gallons. 13 guarts = 2 gal. 1 guart. 1 gallon of anti-freeze and 1 gal, 1 gt. of water will be fine.
Man, I knew somehow that didn't add up to me lol. Thanks for the clarification.
post #6 of 10 Old 10-01-2009, 01:30 PM Thread Starter
CobraSpdRH
I knew about the distilled, but even my owners manual says to use the EthyleneGlycol. Funny b/c the NAPA guy told me his system said the regular old stuff, but I told him my owners manul said otherwise.
So is it hard to get to that bolt on the block to drain the whole thing? I read it is under teh exhaust manifold right? I just want to be sure, and the safest way to do that would be to flush everything I guess, start from scratch.
post #7 of 10 Old 10-01-2009, 02:13 PM
LordHobbit
flush it all would be the safest. Getting to the block drain isn't hard, it's getting the thing out. It might not be too hard, but the last one I did (an old 1966 dodge pickup, probably never been out before) took a bit of effort.
post #8 of 10 Old 10-01-2009, 03:41 PM
vosevichs
Brain fart, It's 4 guarts to a gallon. 1.5 gal. of anti freeze and 1.75 gal. of distilled water
Scott Vosevich
post #9 of 10 Old 10-01-2009, 07:22 PM
rm2001wj
rm2001wj's Avatar
That's about what you need (actually 6.5 qts of water and that same amount antifreeze for a 50/50 mix)) if the cooling system is completely empty. Simply draining the radiator will leave close 1/2 of the old coolant in the engine and heater hoses and core. That old coolant would be a 50/50 mix so only about 6.5 qts of new 50/50 mix would be needed to fill up the system. That requires only a little more that 3 qts of antifreeze and the same mount of water.
If you do a normal flush, which still leaves the engine and heater full of water, not coolant, then it would take the addition of about 6.5 qts of undiluted antifreeze to give a 50/50 mix for the entire cooling system.
rm2001wj is offline
post #10 of 10 Old 10-01-2009, 07:40 PM Thread Starter
CobraSpdRH
So I was just up underneath there making sure I could take care of everything and I couldn't see anywhere where the block drain plug could be. Do I get at it from underneath? I can see the ex. manifold but I don't see how I could get in there to get out a bolt. Might have to invest in a Chiltons on Saturday lol.
Gas in the coolant overflow jepraner ZJ Grand Cherokee Forum 1 06-27-2008 02:33 PM
Radiator overflow bottle full lma1973 ZJ Grand Cherokee Forum 3 07-12-2007 07:41 AM
need coolant overflow bottle!! nate438 ZJ Grand Cherokee Forum 2 08-04-2005 09:34 PM
Evaporation from coolant overflow reservoir... O Holy P ZJ Grand Cherokee Forum 6 03-31-2005 01:59 PM
Coolant pumps out of overflow tank BJ93 ZJ Grand Cherokee Forum 3 08-05-2004 02:04 PM
