how many miles does your zj have, and whats wrong with it? - Page 5 - JeepForum.com
post #61 of 320 Old 05-23-2012, 06:02 PM
whiteylovesbeer
140,000 96 GC with 4.0.. Bad VC and some front end components that the VC has made go bad ball joints,tie rod ends etc.. transmission is going out and it leaks a drop of antifreeze a day, havent really looked to see where its coming from. other than those it runs great just cant stomp on it in 1-2. Looking for a junk yard dog i can get with decent tranny and TC to swap in and possibly a extra tire/rim since mine didnt come with a spare
96 ZJ I6 MudBug- Sold
04 WJ v8 Wifes... :(
whiteylovesbeer is offline
post #62 of 320 Old 05-23-2012, 06:36 PM
NewtoZJ
'98 4.0 ZJ with 144,731 miles. Small exhaust leak, and a few fixer upper projects worth less than 100 bucks DIY style.
NewtoZJ is offline
post #63 of 320 Old 05-23-2012, 06:54 PM
iflypa28
98 5.9 with 198k, what's wrong with it... Well let's talk about what's good, the engine and trans. That's it every thing else is %$#@! But it will be pretty much new when I'm done.
iflypa28 is offline
post #64 of 320 Old 05-23-2012, 07:27 PM
pinstripefan90
1994 ZJ
94 4.SLOW w 170,000...i have done a lot but as of right now just oil pan & gasket, rear main, transoutput seal, t-case input seal, trans diptube seal and upper & lower balljoints, like I said I have done a lot but couldnt ask for a better Jeep, thing is great
pinstripefan90 is offline
post #65 of 320 Old 05-23-2012, 08:53 PM
thathubcapguy
just bought mine, 96 4.0 with 153k already fixed the busted lights and blown random bulbs. biggest hurdle now is the front end work that needs to be done. otherwise a trooper no real leaks (small exhaust that will stay for now) just wish i was driving it yesterday and not my brand new car when a woman decided to rear end me. not because i don't like it but because it would have held its own much better unlike my ford fusion. but that being said i have a 2012 fusion SEL with every option available. but some days i rather the ZJ
thathubcapguy is offline
post #66 of 320 Old 05-23-2012, 09:34 PM
JasonStebbins
208,550 miles
Both rear wheel seals
Rear pinion seal
Transmission output seal
Front/rear track bar bushings
Steering box on it's way out
Front/rear upper control arm bushings
Transmission temperamental
Oil filter adapter/rear main seal
Even with all these needed repairs, the ZJ has never left me stranded/broken down in the two years of ownership. I go wheeling every other weekend, submerging it in water and beating the hell out of it. And it's still more reliable then most of my friends $15,000 vehicles.
One more - I haven't been able to open my rear driver's door since I bought it. The PO said it was something to do with the child lock. That would be a nice fix!
Poop
JasonStebbins is offline
post #67 of 320 Old 05-23-2012, 09:43 PM
jeepgal2k12
Lets see...
Cracked exhaust manifold (gulp!)
needs to new tie rods, pitman arm, and shocks all around
225,200 miles
1996 jeep grand cherokee laredo 2wd
240,xxx miles 4.0L i6
jeepgal2k12 is offline
post #68 of 320 Old 05-23-2012, 09:49 PM
joeyb629
116,000, doing front control arms this weekend along with painting the cladding(if its nice out), also eventually needs an exhaust manifold but waiting for a 99+ intake on Ebay so i can do them at the same time.
joeyb629 is offline
post #69 of 320 Old 05-23-2012, 10:00 PM
lilsinister
anyone on here with 100k miles or less i envy you. but i have 203k and it leaks oil and a lil tranny fluid has unibody issues and my amp just went a week ago. luckily thats it hah. oh and it takes lots of cash to get up to 40s. a shop nearby has one on 45s or 54s with huge *** axles under it and a lift outta this world he said he had 10 grand just in the front end.
lilsinister is offline
post #70 of 320 Old 05-24-2012, 10:36 AM
Dluenz
1993 with 235,300 as of today. Nothings wrong with it.
1998 ZJ Limited 5.9
Dluenz is offline
post #71 of 320 Old 05-24-2012, 10:40 AM
stageninja
That Rigger Guy
stageninja's Avatar
165,000 and after a recent heater core replacement and some modules with good lights in the dash everything is great. Runs well and still no front end hop from the 249. I wonder if the PO replaced the TC or VC sometime before trading it in. Have done a great deal of work since I got it. Radiator, water pump, diff bearings and axle seals, brakes, swapped carpet and regular fluid changes.
Mine '97 White, ZJ Ltd, 5.2, Up-Country Suspension, Kolak ignition, Kolak/Magnaflow Exhaust
Her's '98 Chargold ZJ Ltd. 4.0 2wd
Our 1st '97 White, ZJ Ltd, 5.2, The parts Jeep for 5 years...R.I.P. Sent to Pic-A-Part 5/17/2013
stageninja is offline
post #72 of 320 Old 05-24-2012, 03:02 PM
BigJohn96ZJ
96 5.2 235,000 as of today. transmission slips going into OD. Bad u joint in the rear somwhere.needs cv axles, front brakes, and cv joint for front ds. Dome lights dont work had to pull fuse cuz they wont turn off. No defrost. Battery, alt., and starter all replaced in 2012. original engine runs like a beast and showing no signs of letting up.
BigJohn96ZJ is offline
post #73 of 320 Old 05-24-2012, 04:58 PM
715racing
1994 Grand Cherokee 5 speed stick with 216000 miles. Original clutch, water pump, front and rear gears, head gasket, the only thing replaced other than normal maintenance
has been the power steering pump...twice. The Jeep runs perfectly, doesn't leak (!), and isn't the least bit rusty.
The only thing wrong now is the drivers seat is worn out. Gonna go to a junk yard this weekend and try to find a match.
715racing is offline
post #74 of 320 Old 05-24-2012, 10:28 PM
jeepgoonie
2008 XK Commander
166k miles
leaking exhaust manifold
Heater core
Downstream o2 sensor
u joints
Oil leak
Fuel sending unit is sketchy at times
Infamous saggy headliner
All in all. It's what makes it a Jeep lol
Just Empty Every Pocket
jeepgoonie is offline
post #75 of 320 Old 05-24-2012, 11:59 PM
98GCLimited
140k I6
Trans output seal is bad
no reverse lights
98GCLimited is offline
