how many miles does your zj have, and whats wrong with it? - Page 2 - JeepForum.com
post #16 of 320 Old 05-12-2012, 10:49 PM
pincheburro956
94 with 160XXX, broken front pinion. thats about it....its in good cond...
"Not a single **** shall be given."
99 WJ, 2" BB, 245/75/16 Falken Rocky Mountain ATS.
pincheburro956 is offline
post #17 of 320 Old 05-12-2012, 10:53 PM
zander21510
95 4.0 w 193k, goin on 194. Leaky transmission pan, either leaks or burns about a quart of oil every 2-3 months, not sure. Also I think the front differential is leaking where it connects to the driveshaft, and possibly my transfer case again. When I get back from college this summer, hopefully I can get it all sorted out...but nothing else major (knock on wood!)
zander21510 is offline
post #18 of 320 Old 05-12-2012, 11:21 PM
Cmense
96 4.0 laredo 170000. rusty unibody is the main issue. Leaky valve cover, front wheel bearing shot. (had to beat on it to replace ujoint) so the abs started going crazy. Pulled the fuse and no issues with it since. Besides the abs light and that just gives the jeep charisma.
Cmense is offline
post #19 of 320 Old 05-12-2012, 11:22 PM
ZjRW
60000 miles problem with fuel sending unit
ZjRW is offline
post #20 of 320 Old 05-13-2012, 12:53 AM
zachjf
205,354 tranny started acting up a little bit lately, quick up shifting then back down again at part throttle and feels like its "unlocking" when coasting. I can take off and be moving then let off and a few seconds later its like its releasing. Hoping a new governor sensor and solenoid will fix it.
Needs parts?
PM
or
zachjf is offline
post #21 of 320 Old 05-13-2012, 01:22 AM
AmishFury
161888
needs headliner, shocks, and brakes
dimmer for dash lights occasionally needs to be smacked to make it stop randomly dimming
sometimes i have to wiggle the switch on my AC to make it properly select the mode or turn off
AmishFury is offline
post #22 of 320 Old 05-13-2012, 01:32 AM
Oldfrog
2007 WK
231K, (4.0)....headliner ( one day ...fairly soon), rear main leak, ( in the next 2 months), valve cover leak ( I already have the gasket), I dont like my shocks, ( maybe next month), pittman arm seal leak ( I have the new seals in hand right now), might need a new front hub soon ( I have new ones in the back of the Jeep already) and the fuel tank is down to 1/4 tank. ( dreading that fill up tomorrow). Just got done with new tires, new trackbar, swaybar bushings and end links...so now it doesnt make any noise and the front end feels good and tight.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #23 of 320 Old 05-13-2012, 02:00 AM
nicklopic
98' laredo 4.0 with 165,000
rear diff leaks (slow)
rear diff issues (i think bearings)
TC leaks (also very slow)
CA bushings are shot
shocks are shot
afew interior panels missing clips and screws (SO ANNOYING! IDK WTF THE PO DID BUY THERE ARE SCREWS MISSING EVERYWHERE )
rear wiper motor went last week
i feel like im missing stuff... oh well i guess.
working a minimum wage job kind of makes it difficult to make repair (or mod it)
little by little i guess
98' ZJ 4.0
4.5" short arm, 33" Courser MXTs, custom stubby bumper, skids, someother stuff
nicklopic is offline
post #24 of 320 Old 05-13-2012, 02:07 AM
nicklopic
OH!
headliner too
one of my hellas is cracked because of a friend deciding to back his wj into mine on a trail
and one of my fog lights is broken (lens and bulb)
this makes me realize just how much i need to do... well this sucks
98' ZJ 4.0
post #25 of 320 Old 05-13-2012, 02:35 AM
rozco
Originally Posted by TheHalfWit View Post
You know I can't think of a single guy on the boards who actually has 40" tires on their zj, and I can't help but wonder why. Even IRO only says that their lift can fit 37" tires but recommend running 35" tires with a 7" long arm kit.
this guy ran 40's. a lot of custom work but its definitely possible. i think hes only at around 5.5" of lift too
93' ZJ - 5.2L. 4.5" IRO lift. front long arms rear short adjustables. bilsteins. daystar bumps. 33" KM2's. rancho ss. rc quick discos. flowmaster 10 series.
rozco is offline
post #26 of 320 Old 05-13-2012, 02:40 AM
rozco
and to keep on topic mine has 160k. a slight heat issue and typical electric problems like my overhead console and vic not working properly. my engine and transmission have been pretty good to me tho and ive beat them down pretty bad too
rozco is offline
post #27 of 320 Old 05-13-2012, 09:32 AM
jimmyznutz
1994 ZJ
94' 5.2 with 171k. Have a bad VC, some broken interior plastics, need a new driver side door. Lost my front bumper cover and crushed the driver's side front fender in New Mexico desert snow storm when a big rig clipped my front bumper, spun me out and slid into a ditch and rolled the ZJ onto the driver's side. It also popped my 31s off bead. Had a tow truck flip us upright, jacked it up and re-inflated the tires. Drove home (around 600 miles) immediately afterwards. There are a few other small issues I will eventually take care of. Engine is still running strong though. No problems there so far...#knockonwood#
jimmyznutz is offline
post #28 of 320 Old 05-13-2012, 09:50 AM
96zjeep
1996 ZJ Laredo
I have a 96 zj Laredo 140k and my only problem that I have or have ever had with it...mthe headliner is falling. That's it.
96zjeep is offline
post #29 of 320 Old 05-13-2012, 09:53 AM
DeejayZeejay
1994 ZJ
94 5.2 180k and counting. Bumper cover gone, VC bad, rear end bad, tie rods need replacing as well as shocks, rocker panels rusted, passenger fender badly bent, radiator bad, exhaust manifolds... Engine and trans great though. Needs tlc.
Jeeps 4 Life!
DeejayZeejay is offline
post #30 of 320 Old 05-13-2012, 10:45 AM
grego
1994 ZJ
94 4.0 ZJ It has 292 000 Kilometers on it. So that is around the 180 K mile mark
As far as I know it is original engine and tranny, but I only bought it as a winter toy / something to get me through storm weather and cold in Canada here, so I have only driven it the last 15 K of its life.
It has the basic thing of the driver window wire is cracked right where the boot meets the door and I haven't fixed that yet since I don't really need it down much in winter other than having to open doors at a drive thru
Other then that the tranny loses some fluid right now. I will look at that some time soon. it would be too much if I drove it all the time to handle, but for winter driving I top it up a bottle or 2 through a winter.
Front UJoints are going to need repair
Other then that it is a great jeep and I love it. The other day I had to move it in the yard from where I parked it, and I had to take the jeep for a small spin around our town because I miss driving it so much
grego is offline
