how many miles does your zj have, and whats wrong with it? - Page 18 - JeepForum.com
post #256 of 320 Old 08-27-2013, 09:28 PM
EndIsNear
100,500 miles. Has some residual oil leaks. Not enough to "use" oil though. Just enough to make the engine look dirty.
Needs:
Bushings
Shocks
Brakes
Headliner
Driver Seat
Repainted Driver Door
And quite a bit more.
Still not bad considering shes been rode hard and hung up wet by the previous owner...
EndIsNear is offline
post #257 of 320 Old 08-28-2013, 02:26 AM
nekolin
95 230k and as of today a squeky belt cause i keep breaking the collar bolt so i dont want to tighten it all the way
nekolin is offline
post #258 of 320 Old 08-28-2013, 09:36 AM
jeep93GCL
1993 jeep grand cherokee limited 4.0
Miles 145,700
Just change the front suspension no more death wobble..
Now need front brakes maybe next week it will get done.
Transfer case is leak need to fix that soon....
Front drive shaft missing
Differntial bad
Need transmission mounts to be replace
Leaking oil a bit maybe next year to rebuilt the motor
Got it from a friends that want to junk it I told him I give you 200 bucks for it when I got her she only had 94,000 miles she drive strong and never giving up on me
jeep93GCL is offline
post #259 of 320 Old 08-28-2013, 11:21 AM
bearfighter13
1993 grand Wagoneer zj. (Yes a woody) 231,000 miles. Trans went out twice but I still kept fixing it. The best seats I've sat myself in. They're comparable to sitting on a tray of biscuits. I'm keeping it forever and eventually replacing that crappy fake wood with some real marine grade wood!
bearfighter13 is offline
post #260 of 320 Old 08-28-2013, 01:00 PM
Kingr98
Have you actually sat in a tray of biscuits??
Kingr98 is offline
post #261 of 320 Old 08-28-2013, 01:06 PM
jeepycreepy96
My zj has 121k front axles need to be changed due to ripped cv joint boots. Ac won't blow unless on high
jeepycreepy96 is offline
post #262 of 320 Old 08-29-2013, 01:51 PM
technophat
'97 4.0
212,000mi
Other than things broken on trail: the PCM, shocks, bushings, tracbar and steering gearbox
1997 ZJ Laredo, 4.0, 42re trans, 242 T-case
1994 ZJ Laredo, 4.0, 42re trans, NP231 T-case
technophat is offline
post #263 of 320 Old 08-30-2013, 08:18 AM
89arkansasxj
95, 169,000. Just hit it on the way to work. Only thing wrong is the rear main has a slight leak for the 5th time in it's life and the stupid flickering check engine light with no codes thrown. I fix things instantly.
89arkansasxj is offline
post #264 of 320 Old 09-01-2013, 08:30 PM
Red-ZJ
201,900 miles. It did have the sagging driver's door, but fix that today. Has what I would call a class 1 leak (wet with oil. but no drop formation and no drops on ground) at the back of the engine. Suspiciously shiny transmission and x-fer case for an 18 year old vehicle. Couple of tears in the seats... a scratch on the door.
I'd say I've gotten off lucky thus far.
Red-ZJ is offline
post #265 of 320 Old 11-11-2013, 10:13 AM
bigray122
1993 XJ Cherokee
93 4.0, 226000+, going around right turns there seems to be some rubbing (not tire) metal sound from drivers side. Ordered and have new front struts, replaced rear shocks. Missing lug passenger side rear. Replaced muffler, valve cover gasket, RF steering knuckle, track bar replaced. A/C doesn't work, fills up, gets ice cold, by end of the day its all leaked out from somewhere. No idea how to fix. Steering is very loose, no play, just very loose and ride is like riding in a shopping cart. Also speedo doesn't work. It goes backwards and kinda hovers @ 80 miles phr. Replaced plastic track slides in drivers window with sliding door teflon rollers (EXCELLENT FIX). Also needs Pitman arm I think. I'd guess (hope not) ball joints replaced, upper/lower control arm bushings. Oh, oil filter adapter leaks like a pig. Bought T60, gasket and seal, replaced gasket and fill plug on rear diff and Trans oil and filter replaced. Vehicle smokes like a blue-ish (oil burning smell) when running... No clue what that could be.
Also, rear bumper came off when someone drug me out of a snow bank. Now I notice the brackets aren't bolted on with a "regular bolt" I suppose some PB blast and a pair of vice grips will get the brackets off. Still need a bumper and brackets.
If anyone cares to address this Daily Driver (not lifted or used as off road at all).
bigray122 is offline
post #266 of 320 Old 07-30-2014, 05:26 PM
seabee69m
1995 FSJ Cherokee
95 zj 268,000 plus almost 10 yrs majority items normal tires,brakes,tuneups, fluid changes,waterpump, two ecm,6 yr,s apart. i must say this vechicle has been the most dependable i have ever owned. seabee69m@hotmail.com be 70 9/14/14 hope to get a few more yr's out of both of us.
seabee69m is offline
post #267 of 320 Old 07-30-2014, 06:01 PM
underpowered
Bouncin' on a Budget
underpowered's Avatar
183k on mine. needs front pinion bearing, rear pinion seal leaks a bit, head lights no longer work on auto, dash lights Dim on their own, rattles, headliner is falling, drivers door panel is broken, rear hatch is rusting, has dents, dings and scratches everywhere.
pinion bearing will be fixed shortly with the addition of a HP30, and rear pinion seal will be replaces soon as well, but the rest i live with, and as long as it still gets me from point A to B it will continue to.
1998 ZJ-- lowered a touch
2005 GMC 2500HD 496 C.I.
Fat Amy-1989 K5 blazer. Linked, lifted, 38.5's on won tons. Big Girls can play in the woods too.
underpowered is offline
post #268 of 320 Old 07-30-2014, 06:15 PM
PTECH
99,000 on my 98 limited. Only had it a month but I've put over 1000 miles on it. Since I've owned it I've done sway bar bushings, tie rod ends, track bar bushings and drag link ends. Replaced a leaking transmission pan and gasket but found i have a small leak from the fitting for the ATF cooler lines. Still needs a belt tensioner and a belt. Center console lid is broken off. I have some kind of roaring noise from the front end, hoping its wheel bearings and not the pinion bearing. If it needs a pinion bearing its gonna get a hi pinion dana 30 swap. Also needs the control arm bushings but they're just a bit clunky, no DW yet. Really loving it though. Saving up for WJ steering/brakes and some nicer shocks.
PTECH is offline
post #269 of 320 Old 07-30-2014, 08:38 PM
riot1987
I think I posted in here before but, my **** has 146k and runs like a god damn champ.
Build thread^^
riot1987 is offline
post #270 of 320 Old 07-30-2014, 08:46 PM
mudwaller88
98 limited 5.2. 1655xx on it. Vc is bad, Trans shifts funny somtimes but rarely slips only in the morning very rarely if I don't let it warm up some. Squeaky belt, had replace driver side power seat, drivers side heated seat doesn't work. Think it was a solenoid for the converter lockup that went bad when my brother drove it to ga. More less nothing that bothers me other than not having a properly functioning transfer case and no lift lol.
JEEPIN AINT EASY, BUT IT SURE IS FUN
mudwaller88 is offline
