how many miles does your zj have, and whats wrong with it? - JeepForum.com
post #1 of 320 Old 05-12-2012, 02:59 PM Thread Starter
Chrisgary
mines a 98 grand cherokee laredo with 165000. head gaskets no good, but runs, and sudden hole in my tank. rotted I guess, but only at full so I guess its the seal
Chrisgary is offline
post #2 of 320 Old 05-12-2012, 04:48 PM
DickDickle
Your tank can't be rotted since it is plastic but I have a 96 zj with 280,000+ and I only have minor front end problems from weekly wheeling and my only other major issue is that my rear axel is starting to go because the housing It's self is bent. I have on the other hand put 3 transmissions in since I bought it along with the large among of money spent on rubber and suspension parts. Original motor though. Still running strong
DickDickle is offline
post #3 of 320 Old 05-12-2012, 05:22 PM
Sarjam
2003 WJ
95 ZJ 4.0 with 137k, need exhaust manifold and exhaust. Going in Wed to be all fixed up.
I Just
Sarjam is offline
post #4 of 320 Old 05-12-2012, 05:23 PM
DNFJ
134k, needs windshield, front hubs and bearings
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
post #5 of 320 Old 05-12-2012, 06:07 PM
Benja
40k (yes, 40k) she needs new front, headlights, dashboard, airbags and fix the ABS light
97' Grand Cherokee Limited V8 41K
STOCK
Benja is offline
post #6 of 320 Old 05-12-2012, 06:09 PM Thread Starter
Chrisgary
plastic?! I haven't even taken the cover off! That's awesome! I've only ever had metal tanks, first zj ya know
post #7 of 320 Old 05-12-2012, 06:47 PM
949702jeeps
130000 no major problems. Knock on wood
949702jeeps is offline
post #8 of 320 Old 05-12-2012, 06:56 PM
TheHalfWit
I wouldn't call it a good thing, let alone awesome. Those plastic tanks are famous for leaking, and I personally prefer my all metal aftermarket radiator.
Lemme think, mines got 165k miles and its a few bolts short of complete. Off the top of my head its missing one of the throttle bracket bolts, the manifold itself it actually cracked where the bolt used to go so I'll need a new intake manifold to fix that. The TV cable is attached to the throttle with 3 zip ties. I'm missing a motor mount bolt, (What I get for paying somebody else to deal with them.) And I'm missing a puke tank bolt, I don't know where it went but it disappeared when I replaced my front brake lines. (One runs next to the computer **** on the passenger side.)
Also my exhaust manifold is leaking, my oil filter adapter rounded out when I tried going at it with a T-60 and a 3 foot pipe, and the parking brakes need replacement.
I ordered a doug thorley header from kolak as well as his 2.5 inch exhaust but the header is MIA since I ordered it back in december and I'm still waiting in may. When it finally shows up I'll probably go junkyard hopping to find a 99 intake manifold.
If anyone has a clue about the status on the most recent batch of 4.0 headers from doug thorley I'd love to hear it.
Calm. C.
If a week goes by without needing to replace something, pinch me because I must be dreaming.
TheHalfWit is offline
post #9 of 320 Old 05-12-2012, 07:06 PM
9859limited
300925 and leaking anti freeze, and leaky transmission front seal.(thats all currently *knocks on wood*) Getting fixed next week. And yes it's the niner.
9859limited is offline
post #10 of 320 Old 05-12-2012, 07:16 PM Thread Starter
Chrisgary
its awesome because I can just throw a patch kit on it, not permanent but it'll be good for a little bit I hope.
and update, rear diff is leaking as of today. had to get winched from a hole and drug my axles across the center. this rig is gonna run 40in tires soon I don't care what it costs.
post #11 of 320 Old 05-12-2012, 07:30 PM
TheHalfWit
You know I can't think of a single guy on the boards who actually has 40" tires on their zj, and I can't help but wonder why. Even IRO only says that their lift can fit 37" tires but recommend running 35" tires with a 7" long arm kit.
Calm. C.
post #12 of 320 Old 05-12-2012, 07:37 PM
Glued2aPost
170,000. Headliner needs replacing, I need to re-solder some contacts in the sunroof module (I'll do those two things together), cruise control light bulb in the dash is burned out, the switch for my high beams and the driver's side seat warmer needs some trouble shooting.
My ZJ has never been stuck, it was just taking a break from being so awesome!
Glued2aPost is offline
post #13 of 320 Old 05-12-2012, 08:51 PM
jaguarjoe
Bought a 95 from a "friend" for $500 with 155k. He said it only had 3 problems, it's up to 25 so far Little by little its getting straight. I've got 3 pick and pulls nearby each with many ZJ's so the cost has been sorta low. Some friend.
Once I thought that drinking beer was bad so I just stopped thinking
jaguarjoe is offline
post #14 of 320 Old 05-12-2012, 09:40 PM
Pattywagon92
205,070 miles with the 5.2 and couple plastic interior pieces are cracked. DDS(dings, dents, and scratches).
Pattywagon92 is offline
post #15 of 320 Old 05-12-2012, 09:47 PM
BrandonLong
169k Needs some shocks and a power steering adjustment! A tuneup is on the way and maybe an Alternator
-Brandon
BrandonLong is offline
