How long will my 4.0L last?? - JeepForum.com
post #1 of 12 Old 10-24-2003, 04:16 PM Thread Starter
jlr69s
I have just under 95k miles on her. How long should I expect this engine to run with proper care?
Joe Riley
1985 CJ7 258ci
T-176 tranny with the Dana 300 transfer case
Dana 30 & AMC 20 differentials, one piece axles
32x11.50 Bridgestone Dueller A/T
jlr69s is offline
post #2 of 12 Old 10-24-2003, 05:36 PM
Bighaeb
Bighaeb's Avatar
Provided that it really does get taken care of and driven normally, It is safe to say around 150000, but you can expect more than that in MOST cases. I personally have a 93 YJ with the 4.0 in it and its kickin along great at 135000 miles. She will most likely be one that will see well over 200000, but I'm a freakazoid when it comes to preventive maintenance. People who buy my used vehicles shouldn't have a thing to worry about. And I drive like a granny on road.
"Rigged for her pleasure"
Jeepless for now
Bighaeb is offline
post #3 of 12 Old 10-24-2003, 06:30 PM
KsZJ
I got 210K on mine and it sill runs great. Just take care of the motor. I have seen the 4.0 last well into the 300's with no problem. I have only had to replace little things like the water pump... nothing major.
-J
: 7" LA's... 33's and stuff.
KsZJ is offline
post #4 of 12 Old 10-24-2003, 10:22 PM
lunar rover
I think the question is mis-stated. It's very broad & you can realistically only expect guesses for answers. How about those w/ 4.0 post your mileage & WHAT (specifically) you DO for maintenance (regular, preventative, & repair) This, although it could be a rather lengthy project, maybe needing a database eve, would give you a truer account of WHAT ppl are doing to prolong the life of their motor, WHEN they are doing it, & WHICH parts can be expected to fail, so that they can be closely monitored, so that when their estimated time is due, they can be taken care of before they become a repair. Just my .02.
lunar rover is offline
post #5 of 12 Old 10-25-2003, 12:21 AM
imnotu
imnotu's Avatar
lunar has a point. my jeep is a 95 that just hit 110 k today. since i started reading this site in march i have seen posts where people have had there 4.0 hit 250k or higher. i expect mine to do the same.
I6 w/ Selec-Trac, Plush Leather Seats (powered in front), JVC MP3 deck (STOLEN),
(Insurance messed up and gave me this instead),
, Remote Start, Optima Red Top, 180 Thermostat, Kolak Performance 2.5" exhaust components: (Car Sound high flow converter, Magnaflow large case muffler, mandrel bent tailpipe), 16x8 Rubicon Rims with 245/70 Bridgestone Dueler A/T Revo Tires, Rancho SS, Mopar Skids all around, Tow hooks front and back, Bilstein Heavy Duty Shocks and Clear Corners. [B]149/B], and still going stro... OK My transfer case can a small leak... damnit!.
imnotu is offline
post #6 of 12 Old 10-25-2003, 01:50 AM
91XJLimited
91XJLimited's Avatar
My 4.0HO is at 190,xxx with only a VERY small oil leak, and I've had to replace the water pump. I regularly change the oil, but my priority in "Preventive Maintenance" isn't as high as it should be.
91 XJ Limited - RE 5.5" XD, 32x9.50 TSL's, 4.0 HO, disconnects, other good stuff
94 ZJ 5.2 Limited - 6.5" Teraflex lift, Clayton Long Arms, disconnects, 37x12.50 SSR's, Hummer Beadlocks, and more good stuff
91XJLimited is offline
post #7 of 12 Old 10-25-2003, 08:22 AM Thread Starter
jlr69s
Very true, thank you! I have only had to replace my water pump, just barely leaking, replace the cat, and my expensive... $800, AC evaporator core. But thats it other than the regular maintainance stuff. Keep em commin everyone!! -Joey
Joe Riley
1985 CJ7 258ci
jlr69s is offline
post #8 of 12 Old 10-25-2003, 08:34 AM
BenSampZJ
Mine has 179,000 miles and the only major repair that I had to do was the fuel pump--$700. The ZJ's fuel pumps are screwy and come in one big assembly that's why it's so much. Other than that I've had a leak in the rear main seal...that wasn't too expensive. Then other small stuff. Nothing to worry about.
Good luck,
Ben
BenSampZJ is offline
post #9 of 12 Old 10-25-2003, 02:00 PM
demtjcj
173k and still going. change oil regurlarly. it does consume alittle oil but nothing major.
2004- Wrangler X stock
1977 full size cherokee-401 v8, quadratrac dana 44s
prev. jeeps: 98TJ on 33s, 00TJ on 35s, 01TJ on 35s, 78CJ on 31s, 85XJ stock, 94ZJ stock, 97 TJ on 35s, 03 on 35s, 93 GC on 33s
demtjcj is offline
post #10 of 12 Old 10-25-2003, 03:08 PM
RockPaws
RockPaws's Avatar
As everyone has said, thes engines will run a long time with proper maintenance. Just keep the oil changed, maybe some of the high mileage oils could be used. I run synthetic in all of min, with no problems.
One of my customers Jeeps (89' XJ) has over 235K and still runs great. I have replaced many other parts on the vehicle. But the engine keeps going and going.
01' Jeep TJ (Jeep #5)
3.5 RE Custom SuperFlex, Raingler, Kilby, Currie, Banks, Borla, American Racing, Custom mods, Always more in the works.
RockPaws is offline
post #11 of 12 Old 10-25-2003, 11:13 PM
jeepilot
jeepilot's Avatar
The 4.0 has a reputation of being an engine to last longer than the vehicle it's in. My 4.0 has 143,000mi. There have been a few hiccups but nothing major. At 110,000 the Crankshaft Position sensor went out, about $100 repair. At 138,000 the cracked exhaust maniforld had to be replaced, $400 w/ upgrade to full header. Oil change about every 4000 mi, runnin synthetic. it's not the engine that usually fails, but everything around it.
jeepilot is offline
post #12 of 12 Old 10-28-2003, 09:30 AM
KillerZJ
KillerZJ's Avatar
however long you own your jeep if you take good care of it
Looking for E36 325i(s) 5 speed only. Jeep is for sale $3,000 takes it. E-mail only.
*Sale Pending*
Wow no pictures in sig? F*cking gay.
KillerZJ is offline
How long does a code stay in memory *LONG* Death-Mobile ZJ Grand Cherokee Forum 8 07-20-2009 06:47 AM
Going Long Arm tsconver ZJ Grand Cherokee Forum 12 05-20-2009 07:25 AM
kor long arm/or clayton long arm crazydude2500 ZJ Grand Cherokee Forum 7 07-02-2008 12:26 PM
Long Long Long Starting Darthteddy ZJ Grand Cherokee Forum 0 03-15-2008 01:32 PM
How long does a ZJ last? parnell5150 ZJ Grand Cherokee Forum 19 08-15-2006 09:29 PM
