How long before i need to fix knocking lifter? - JeepForum.com
post #1 of 13 Old 12-18-2012, 05:17 AM Thread Starter
streetzj
I have a lifter or tappet or whatever ticking/knocking -- how long can I drive on it before fixing it?
I think this is a common problem with the 4.0? How difficult is it to fix?
streetzj is offline
post #2 of 13 Old 12-18-2012, 06:06 AM
AVR2
I need to do this too. AFAIK it's a relatively straightforward fix, just time-consuming. Pull the head, remove old lifters (a special lifter removal tool is supposed to make this a LOT easier), install new ones, replace head.
I replaced my manifold gasket earlier this year so stripping down that side of the engine holds no mysteries for me any more, but it's just a bunch of work I don't want to have to re-do any time soon, which is one of the reasons I'm putting off replacing the lifters...
AVR2 is offline
post #3 of 13 Old 12-18-2012, 06:12 AM Thread Starter
streetzj
How long have you been driving it with the noisy lifter?
streetzj is offline
post #4 of 13 Old 12-18-2012, 07:06 AM
AVR2
Probably well over a year.
AVR2 is offline
post #5 of 13 Old 12-18-2012, 07:30 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Lifters don't knock. A knock is much different noise than a lifter tick.
ratmonkey is offline
post #6 of 13 Old 12-18-2012, 07:44 AM Thread Starter
streetzj
It is a tick and not a knock. I listened to it more closely and realized that.
streetzj is offline
post #7 of 13 Old 12-18-2012, 12:02 PM
LunaMoona
Replace them now and take proper care of your engine.
LunaMoona is offline
post #8 of 13 Old 12-18-2012, 03:39 PM
Foundrydude
Depends on how bad it's ticking and how high you rev it. Might last 5 years, might last 5 months.
Typically with ticky lifters you can drive them gently til the engine dies from other problems. But if you do stuff like get stuck in mudholes, then start WOT runs at 230 on the temp gauge, the tick is going to turn into more serious things like bent pushrods & valves.
Foundrydude is offline
post #9 of 13 Old 12-19-2012, 04:28 AM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
Engine rebuilding is a gray area to me so don't laugh . How would it make sense to put lifters on a worn camshaft, cam bearings, and most likely gears and chain? Mine needs this I think but I need a stethescope and probaly pulling the valve cover before I'm sure.
Just seems like new stuff on top of worn stuff might be counterproductive.
Originally Posted by HighLonesome
coralman is offline
post #10 of 13 Old 12-19-2012, 04:35 AM
AVR2
I've seen it said on this very forum that as long as you have decent oil pressure, new lifters on an old camshaft are fine.
AVR2 is offline
post #11 of 13 Old 12-19-2012, 04:36 AM
Foundrydude
It might be counterproductive but it's also $1800 less than a full rebuild, and buys a couple years of engine life
post #12 of 13 Old 12-19-2012, 04:44 AM
AVR2
This
AVR2 is offline
post #13 of 13 Old 12-19-2012, 04:06 PM
coralman
coralman's Avatar
I just didn't know.
coralman is offline
