How to install 8in sub - JeepForum.com
post #1 of 10 Old 08-02-2009, 04:38 PM Thread Starter
grandneuman
I am in need of some instructions on how to install an 8 in sub in my 98 jeep grand cherokee. Anything will help. thanks
grandneuman is offline
post #2 of 10 Old 08-02-2009, 04:42 PM
gbauer
It would help to know what kind of sub you have. Is it just a bare sub or do you have a box and amp? not enough info here...
gbauer is offline
post #3 of 10 Old 08-02-2009, 04:42 PM
rustynail
You need to be a lot more specific
- Russ
5.9 ORVIS 33x12.5 MTR-Kevlar, 7" fr adj IR LA's, 7" rr adj RE SF SA's, adj JKS TB's, RE SB disc, RE Springs, JKS ACOS, 13" RS9000XL's, OME SS, NP231, Durango box, IR Sliders, IR Skid, 3" Flowmaster 70, K&N, Superwinch EPi9.0, Optima Yel, 2 air comp, Alpine, Garmin, Sunroof
rustynail is offline
post #4 of 10 Old 08-02-2009, 04:50 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
Buy a box for it. Screw it to the floor in back. Run wires to it.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #5 of 10 Old 08-02-2009, 04:54 PM
gbauer
You forgot to say "turn on stereo".
gbauer is offline
post #6 of 10 Old 08-02-2009, 07:52 PM
Chris93zj
^and get some wire nuts, duct tape, and other electrical-gemlin causing things on that order...
Seriously tho, you'll need an amplifier, power/ground wires (size varying on your amp size), a Line output converter if you're running from a factory radio, RCA's to connect to the amp input, a box, some speaker wire, and screws to mount the sub into the box. If you're seriously taking this on and have no idea what to connect them to, get help before messing it up. It'll be cheaper up front than fixing mistakes afterwards. If you're comfortable with it, go for it...it's not that bad!
Chris93zj is offline
post #7 of 10 Old 08-02-2009, 08:37 PM
cloiselle
audio section of the forums..............
mount in box, wire up , use crutchfield.com for wiring diagrams to match the impedence of your sub and amp, connect rca cables to head unit or splice in rca line converter to your factory amplifier, check this to do that....
http://jeepsunlimited.com/forums/sho...d.php?t=397627
cloiselle is offline
post #8 of 10 Old 08-07-2009, 10:02 AM Thread Starter
grandneuman
The sub i got for free from a friend, not sure on brand but is already in box.
would it be possible to use the stock infinity gold amp or would i need a new amp.
post #9 of 10 Old 08-07-2009, 10:32 AM
Chris93zj
Aftermarket amp...period.
post #10 of 10 Old 08-07-2009, 11:17 AM
SnowLeopard
The infinity amp is just not up to par for aftermarket stuff. It can be a bit irksome setting up a Jeep with an aftermarket setup, but it's worth it. I still have no sub. Someday. Polk components kick the bass though. They're excellent speakers. Almost better than my Paradigm Legends for my home theater.
SnowLeopard is offline
ZJ radiator install, best spark plugs, bumper guard install doccjp ZJ Grand Cherokee Forum 10 09-30-2010 07:20 PM
IRO 4'' LA install complete!!!! post install questions (pics to come) FrankTheDank ZJ Grand Cherokee Forum 9 07-12-2009 08:51 PM
02 Gc Trailer Hitch Install And Wiring Install evanlaczi ZJ Grand Cherokee Forum 2 03-02-2009 09:10 PM
DRL install Dieseljoe WK Grand Cherokee & XK Commander Forum 8 10-10-2007 12:54 PM
BB install JeepingOverYou ZJ Grand Cherokee Forum 9 02-19-2005 01:48 PM
