#1 | |
How I Saved My 44RE tranny
Ever since I bought my 96 ZJ limited, 5.2 L in Nov 08, the tranny has performed pretty poorly. When I first got it she would slip when kicked into passing gear. I had the tranny fluid flushed and that problem was cured, but she still took forever to shift from gear to gear. She would also bang sometimes when I let off the accelerator. I changed the tranny fluid a couple more times and added some Lucas, but still, it felt like the tranny was living on borrowed time.
Then I found some posts here on the forum dealing with installing a new valve body.Some of the symptoms that were present because of a worn out valve body were identical to the ones that my ZJ had. So I thought, what the heck, I'll get a new valve body. So I bought a new valve body, heavy duty for the ZJ's towing package, and the ZJ is running like a new Jeep. I mean, man it is like night and day. I was amazed! The valve body wasn't that difficult to install. The worst part of the swap was taking off and reinstalling the transmission cable linkage. The 2nd worst part of the reinstall was putting that little c clamp back on the parking prawl rod. Everything else was a cakewalk. While I was at it, I added a drain plug to the side of the pan so I can easily and frequently change my tranny fluid. I bought the valve body from trans_converters on ebay for $249.00, and there was a $150.00 core charge. These guys were great. I needed a governor solenoid for the new valve body and they sent it to me for free within 3 days. These are other items on their ebay store:
#2 |
Headed Out West
![]() _________
Jeff |
#3 |
very nice
98 ZJ Limited 5.2, Blacked Out, 5.5" lift made with IRO coils and ACOS, 15x8 Pro Comp 97's, 33x12.5 General Grabbers, Custom Front Bumper, Rusty's Disco's, KOR Light Bar, 8000K HID's, Magnaflow, PA, CB, 5% Tint, System, TJ Gas Bezel, JKS Rear Trac Bar, Rusty's Front Trac Bar, KOR Stabilizer, Airaid, Hella 700's w/HID's, E-Fan, RCX Diff Guard, Clayton Brake Lines, Iron Man Extreme Control Arms, MSD, Gen Right Louvers, Custom Sliders, IRO Belly Skid |
#4 |
what do you mean it took forever to shift? would the RPM's just rise without acceleration or would it just max out the gear and take time shifting into the next one? my tranny is jerky from 1st to 2nd but seems to be only when cold
[FONT="Impact"][SIZE="3"]1997 5.2L [COLOR="Red"]ZJ[/COLOR] [COLOR="DimGray"]Limited[/COLOR][/SIZE][/FONT] [URL="http://www.norcal4x4forum.com"]Norcal 4x4 Forum[/URL] | [URL="http://www.fquick.com/RrCoX22"]My Garage[/URL] |
#5 | |
"God will get you for that, Walter," Maude said. (my name is Walter).
#6 |
Transfer Case Guru
Just out of curiosity, did you attempt to adjust the TV cable before you replaced the valve body?
Want to swap an NP242 or NP231 into your ZJ? Here's how: http://www.jeepforum.com/forum/f13/np249-np231-np242-swap-information-updated-685644/ |
#7 |
Can you tell me a bit about replacing the VB? I have done it before on a Ford Explorer..
I would like to know the bolt pattern for the VB? the Torque for the bolts? I would really like to find some detailed instructions, but I have not been able to find any. I hate to buy the ASTG manual for this trans , just to replace the VB.. Any info or pointers would be very much appreciated. |
#8 |
IF you can change an A4LD VB then you can do a 44RE in your sleep
VB bolt torque is 100 in/lbs the toughest part is dealing with the E clip on the park rod |
#9 |
Tough parts are removing the transmission cable linkage; the two bolts are a little tough to get off. The park rod clamp is a challenge too. I wonder if there is a special tool made for that puupy that hold it in place while you are trying to press it on. YOu have to watch out for the plastic piston assembly and 2 springs that are right above the valve buddy. They come out when you lower the valve body. It is really not a hard job. Just more time consuming than it should be because of that cable linkage.
#10 |
Need a little help please?
I am ready to lower the VB on my 42RE and have a couple of questions..
My first is, what linkages do I take loose before removing the VB? In the picture below, do I remove that bolt and is that it? Cane you point me to anything from the picture? Or does someone have a schematic of what to take loose? ![]() second question is this rod? I suppose it detaches from something as I lower the VB? Can I do this with 3 hands? ![]() Thanks for all and any help. Using your experience , vs. me learning by doing is the best move everytime! You guys and gals know your Jeeps! Last edited by mackg@goodweb.o; 04-28-2009 at 05:05 PM.. Reason: added " and Gals" |
#11 |
If I remember correctly, there are 2 bolts on the bracket - the one is in the picture is one of them, and you have to loosen them for the bracket to come off. Regarding the rod, as you lower the valve body, the parking rod will start coming down with it, still connected to a short post with an "e" clamp. The "e" clamp isn't too hard to remove, but it's a little challenging to get back on - but not impossible. It's not a hard job at all. My tranny improved 100 % after I changed the valve body and then adjusted the throttle valve cable.
#12 |
Never mind the below post... I figured it out! Comes loose at the top... I got confused because the VB I bought to replace this one still had the rod attached to the top... So I imagined that was part of the replacement,,, duh,,,
_____________________________ HELP I can't get the rod loose? does the rod come off the top of the valve body? or the other end, ? I am confused.. The valve body is loose and I can't figure out how the rod comes off. I thought some sort of linkage slid out that I could disconnect, but I can't get anything to slide out.. Does this make sense? anyway, I'm stuck.. please help Last edited by mackg@goodweb.o; 05-02-2009 at 03:40 PM.. Reason: new information |
#13 |
Ok, newb question. How do I know if I have a 44RE tranny?
96 Jeep Grand Cherokee Laredo I6 auto |
#14 |
42re in your 96 w/I-6.
Same as mine. ![]()
"...a long habit of not thinking a thing wrong, gives it a superficial appearance of being right, and raises at first a formidable outcry in defense of custom. But tumult soon subsides. Time makes more converts than reason." Thomas Paine |
#15 |
what tranny would i have no tags no marking
i hav a 94 grand cherokee laredo 4x4 automatic has over drive, i-6 |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
