How hard to fix transmission leak? - JeepForum.com
post #1 of 6 Old 09-28-2009, 10:42 AM Thread Starter
allready_gone
98 ZJ with 4WD Automatic Transmission. Seal between the transmission and the transfer case appears to be leaking. Bolts have been checked and are tight so they are not the problem. Showed signs of a leak last weekend but then not a drop for a week while we watched it like a hawk. Leak showed back up after a 1 hour plus drive and then again after the same drive back. Can novices fix this or should we take her in?
allready_gone is offline
post #2 of 6 Old 09-28-2009, 11:06 AM
lonestar_yj
Easy fix, unbolt drive shafts, undo linkage, electrical connections on tc, bolts on tc to trans. Get some rtv sealent and put a bead on the transmission and put everything back together.
93 wrangler sahara, 4" lift, 1" shackles, 33x12.5 maxis buckshots on crager rims, hm front,back bumper,towbar, hand throttle
lonestar_yj is offline
post #3 of 6 Old 09-28-2009, 11:08 AM
impuresoul2k3
Just take off the transfercase and replace the transmission output seal, make sure not to gouge the seal housing.
1993 Grand Cherokee Limited, 5.2L
Modified/Slightly Ported Kegger
Air hat spacer
Modified Throttle body
Flowmaster muffler
impuresoul2k3 is offline
post #4 of 6 Old 09-28-2009, 02:21 PM
cmonson
there is a seal between the trans and t-case. NO RTV...
While you have the t-case out, replace the input seal of the t-case.
cmonson is offline
post #5 of 6 Old 09-29-2009, 03:22 PM
wetmonkey
1997 XJ Cherokee
Shouldn't take you and a friend longer than a 12 pk to finish.
'97 XJ Up Country
wetmonkey is offline
post #6 of 6 Old 10-01-2009, 05:27 PM
purplepig
i think i am having the same problem. the leak is slow so far. it just barely drips and doesn't really fall to the ground. do you by chance have a picture of your problem so i can compare it to mine?
purplepig is offline
transmission pan leak rjs1956 ZJ Grand Cherokee Forum 27 05-01-2013 09:48 PM
AC leak this hard to find (96 GC) luckyjeep ZJ Grand Cherokee Forum 2 08-01-2008 01:19 PM
Transmission Oil leak dwaned ZJ Grand Cherokee Forum 5 06-12-2008 05:29 PM
Transmission Leak pcorad ZJ Grand Cherokee Forum 0 11-28-2006 08:31 AM
Transmission leak STJGCL93 ZJ Grand Cherokee Forum 3 09-30-2005 09:13 AM
