how to get stuck wheel bearing out - JeepForum.com
post #1 of 10 Old 02-19-2016, 07:29 PM Thread Starter
biggreen
So I bent and destroyed my right passenger side axle shaft awhile back. I finally got the old one out and noticed that the wheel bearing had partially welded itself inside the housing. Any ideas on how I can clean this up and get it out?
biggreen is offline
post #2 of 10 Old 02-19-2016, 07:40 PM
Technohead
I recommend:
-Eric
Technohead is offline
post #3 of 10 Old 02-19-2016, 07:56 PM Thread Starter
biggreen
Not sure how that fits inside the carrier of the housing...Good idea though.
biggreen is offline
post #4 of 10 Old 02-20-2016, 12:26 AM
power
1994 ZJ
I used heat and cold chisels for removal which of course will destroy the bearing. I apply ant-seize when installing the new bearing.
94 ZJ,4.0, AX15, NP231
power is offline
post #5 of 10 Old 02-20-2016, 12:40 AM
Uniblurb
Uniblurb's Avatar
Have you already tried a slide-hammer bearing puller? If that breaks the bearing up I've seen some use a dremel with metal cutting wheel for removing the race stuck in the axle housing. But you have to watch you don't cut into the housing itself.
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 93 4.0 XJ (spare), 96 4.0 XJ (son's)
Uniblurb is offline
post #6 of 10 Old 02-20-2016, 01:08 AM
jnicewan
There are various attachments for a slide hammer to remove this stuff, like mentioned above, or a 2 to 3 jaw puller, there are also adapters that make and almost full circle that spread out as you tighten them up (blind hole puller), these would work better if its just the outer/race part of the bearing that's left. I would think the local auto parts store would have these on loan/rent if you didnt want to buy.
This, this or this. They all would probably work with a slide hammer.
jnicewan is offline
post #7 of 10 Old 02-20-2016, 05:28 AM
12tamale
Air hammer
Early on a Sunday morning, in the driveway
12tamale is offline
post #8 of 10 Old 02-20-2016, 07:11 AM
ZJswagg
LMAO that's the best
ZJswagg is offline
post #9 of 10 Old 02-20-2016, 07:24 AM
ZJswagg
I just had to get a bearing out the other day this worked, its a seal and bearing puller
ZJswagg is offline
post #10 of 10 Old 02-20-2016, 09:31 AM
MKCoconuts
Depending on how much bearing is left is going to determine what tool to use. But a BFH, lots of heat, and a chisel can usually get the job done.
MKCoconuts is offline
