How to get error code from A/C unit - JeepForum.com
post #1 of 6 Old 08-11-2011, 12:42 AM Thread Starter
SouthZJ
Hey Guys
I red somewhere that you can read out error codes from the heat and A/C unit over the display when you press A/C and recycle button, something like that.
Can some one give me a little description how to read it out Thanks, got to fix my heat until the winter sets in
A/C is good just no heat at all, some times i get a "Er" in the display when i start the old girl up, checked the hoses for the heat exchanger and both are hot, i even flushed it and totally clean water and very good flow so its not that, when i turn the round button for the temp adjustment i can hear a motor move but no heat it just stays cold so i guess the door thing in there is broken and i just would like to try to get the codes out first before i start tearing everything apart
Thanks Guys
1995 ZJ Orvis 5.2l
SouthZJ is offline
post #2 of 6 Old 08-11-2011, 08:01 AM
dpshoup
2011 WK
press both buttons and turn the dial one click clockwise to enter diagnostics mode. Service manual or Haynes will have the codes listed....
HT1 (SW/AW) USN RETIRED (HT-4946)
24 Jun 81-30 Jun 01
ASNT NDT Level III (VT, MT, PT)
02 WJ-4.7 My DD [04 WJ-4.0, 00 XJ-4.0 Gone]
03 WJ-4.0 Dau #1 DD
93 ZJ-5.2 Dau #2 DD
USN Jeep Club #153
dpshoup is offline
post #3 of 6 Old 08-11-2011, 10:40 AM Thread Starter
SouthZJ
Thanks tried it with the ignition in on and when i press both buttons and turn the dial on clockwise and let go i get a scale of some sort where i can choose from 00-38 not sure what thats for but if i press the a/c button again i get a 02 with a sitting men next to it, i guess thats the error code
whats the 00-38 for?
Thanks guys
SouthZJ is offline
post #4 of 6 Old 08-11-2011, 06:11 PM
PA 5.9
Thanks guys
Those are all of the different tests you can run. When "00" is showing, press either the AC or Recirc button. That's the overall test. Assuming this is what you did and you got 02, is supposed to be "In-vehicle temperature sensor circuit open", this is from a 98 manual. Not sure if other years are different or not. But your problem sounds more like a blend door motor problem.
PA 5.9 is offline
post #5 of 6 Old 08-11-2011, 11:57 PM Thread Starter
SouthZJ
Thanks so i can run 38 different test than i got something to do for the weekend
I would also say its my blend door but what if the blend door does not know what temperature it is in the car and it thinks its too hot does it close than?
Got to check my Rep Manual if there are any codes in it for the A/C also not sure if i got the book for the pre 1996 ZJ's, let you guys know tomorrow if i found out more
SouthZJ is offline
post #6 of 6 Old 08-25-2011, 09:49 AM Thread Starter
SouthZJ
so big surprise, i come back from my vacation and will i was driving the last km home i turn it to hot and there it was Hot air, i could not believe it so i tried it the following day and again there was Hot air coming out of my vents, i did not touch anything but for the past few days i have a fully working system and that for the fist time in 12 month, lets see how long it last
Thanks for all your reply's guys, always a big help this forum
SouthZJ is offline
Error code 32 lilrebel ZJ Grand Cherokee Forum 0 10-24-2010 02:59 PM
Error code 72?? $300zj ZJ Grand Cherokee Forum 1 09-24-2007 02:42 PM
New error code! KingPrat ZJ Grand Cherokee Forum 4 04-27-2006 12:41 PM
Error Code sbotos ZJ Grand Cherokee Forum 3 09-15-2005 02:04 PM
error 32 code trailboy ZJ Grand Cherokee Forum 1 04-06-2004 10:25 PM
