How to fix stabilizer bar linkage - JeepForum.com
post #1 of 12 Old 08-05-2010, 10:14 AM Thread Starter
picflight
How to change Sway bar link
I think it is a stabilizer bar linkage that has come loose and hitting the spring.
Picture is take inside the right wheel well, front of the jeep is to the right.
1996 Jeep Grand Cherokee 5.2L V8 4x4. 180K
Every time I entered a driveway or drove into a gas station I would hear this horrible noise from the front-end. I had the steering box replaced about 3 months ago and this noise started happening about a couple of weeks after the steering box replacement. I have only driven about 200 miles since the steering box replacement.
Do you think that this came off because of the inept service technician?
It is worth taking it back to him, will they accept if it is their mistake?
How do I fix this if I have to do it? Anyone has detailed instructions?
[EDIT]
After some search I found that this part is called Sway bar Link
picflight is offline
post #2 of 12 Old 08-09-2010, 04:11 AM
freakinheep89
yea thats the swaybar end link. to tell the truth the dealer is gonna want about 75 apiece for the OEM ones, that one in the pic is dead beyond repair. your better off just ordering a set of JKS quicker disconnects, they are meant for off roading and crawling, but they would actually end up being cheaper than the OEM replacements. they are relatively easy to install
i doubt that came off due to the tech but its possible, i seriously doubt they would admit fault and fix it for free
TJ-
95 ZJ 5.2- D30/XJ shafts/D35 Yukon alloys,249, 2"BB, 30x9.5"Wildcat EXT,lots of motor mods, rancho shocks & stabilizer.
Originally Posted by slayercr23 View Post
How would i go about Stroking it?
freakinheep89 is offline
post #3 of 12 Old 08-09-2010, 07:06 AM
sandman
Uploaded with ImageShack.us
super glue will fix that one. JK, buy the sway link and replace it, its easy. BTW, it came loose from wear and tear, nothing your mechanic did.
1993 Jeep ZJ. 4.0
sandman is offline
post #4 of 12 Old 08-09-2010, 07:57 PM
freakinheep89
alright i was close: called the dealer today and a swaybar end link for a 96 ZJ 5.2= $68.59 + tax. i would never replace a part like that as one, i would do it as a pair so thats $140, JKS QD's are $163 and much higher quality
TJ-
post #5 of 12 Old 08-10-2010, 04:27 AM Thread Starter
picflight
Thanks for the help.
I have read these forums alot in the past couple of days and am somewhat encouraged to replace these myself, just have to make sure that I have the tools, torx bits and sort.
I will also replace the sway bar bushings while I am at it.
If anyone in the San Fernando Valley area of CA has done this replacement, has the space and time to do this for me, I would appreciate. PM me with your labor charge. Thanks
post #6 of 12 Old 01-16-2011, 01:59 PM
theuniversalist
1995 XJ Cherokee
I'm in the middle of doing this myself...how far down should I tighten the bolts and compress the rubber? till I cant tighten them anymore? or less? should I put lock tite or something like that on the bolts?
theuniversalist is offline
post #7 of 12 Old 01-16-2011, 02:10 PM
newfieZJ
spec is 45 ft lbs
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #8 of 12 Old 01-16-2011, 02:11 PM
theuniversalist
1995 XJ Cherokee
on top and bottom?
post #9 of 12 Old 01-16-2011, 03:56 PM
newfieZJ
bottom is 70 . Lock tite isn't really needed
1995 Orvis build
1988 MJ build
newfieZJ is offline
post #10 of 12 Old 01-16-2011, 08:03 PM
LouC
2007 WK
MOOG makes a nice grease-able one, I was going to change mine thinking they were causing a noise but it turned out to be the sway bar bracket bushings. When they go I'll just pop em on...
LouC is online now
post #11 of 12 Old 01-17-2011, 12:12 AM
ZJ5point2GCL
do you wheel your jeep?
if not i would just get factory replacements from napa or i think iro has some cheap ones
98 Deep Slate Niner- 6''s on 35's ---11 F150 Platinum Pearl White- Modded Tiny V6 with Two Turbos. ---93 Black 5.2 limited- Slowly dying in my Parents Driveway
ZJ5point2GCL is offline
post #12 of 12 Old 01-17-2011, 11:04 PM
Dustmuffins
I've broken both a front one and a rear one. Don't worry about it. It happens.
Dustmuffins is offline
suspension
Stabilizer Bar bad? OMEWI ZJ Grand Cherokee Forum 3 11-30-2009 08:22 PM
Anyone using this TC linkage ... 1sportsdoc ZJ Grand Cherokee Forum 14 05-27-2009 03:20 PM
Which Linkage?? GCJeeper1993 ZJ Grand Cherokee Forum 10 09-07-2006 01:21 PM
OME stabilizer bloodspilla ZJ Grand Cherokee Forum 14 12-31-2004 11:14 AM
Stabilizer Diehard ZJ Grand Cherokee Forum 3 11-01-2004 09:38 AM
