How to fix a leaky axle seal - JeepForum.com
post #1 of 15 Old 01-21-2013, 12:43 PM Thread Starter
xcaliber81
Is it a hard job, I am by no means a diff expert its my left front. I might add I did my universals a few months ago, I had it in a tranny shop to fix the cooler lines and they pointed that out could just a bit have leaked out I moniter it and I have never had to add fluid to it, however Its long overdue for a fluid change.
xcaliber81 is online now
post #2 of 15 Old 01-21-2013, 12:49 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
need to remove the carrier to do it. not too hard, but you'll need a torque wrench and to come up with something tricky to drive the seals out and new ones in with. always replace those ones in pairs.
ratmonkey is offline
post #3 of 15 Old 01-22-2013, 07:38 PM
tazz33
Did u by chance do the ones at the wheels?
I did that on my old XJ and found that my diff was a small amount over filled and when I pulled the shaft out a bit leaked into the tube and leaked for a week or so. Was not much at all just looks like its more than it is as wattes washes it out of the alxe tube.
Just a thought?
1998 niner!!!!! K&N, BFG All Terrains, MSD coil, Taylor Thundervolt wires, Superchips Programer, Kolak 3" tailpipe, Magnaflow highflow 3" Cat, MBRP 3" chambered muffler, MBRP 3"-3 1/2" dual wall stainless tip, and gonig to be more to come!!!!!!
tazz33 is offline
post #4 of 15 Old 01-22-2013, 07:57 PM Thread Starter
xcaliber81
Just a thought?
HUH? at the wheels? when i did my universals there was no seal at the end of the tube and it is leaking because i scoped out where my usual park spots are(not hard to miss as the red stains stand out like a sore thumb) and i can see tiny black dots and also i checked my fluid in the front diff and it was low and it was not leaking before i did my universals.
post #5 of 15 Old 01-22-2013, 08:07 PM
riot1987
My dad made a tool for pushing the new seals in. I wish I had a pic of it. Basically A short piece of allthread with short sections of tubing at each end. Then you thread out a couple of nuts and it pushes them in.
..I dunno if that makes sense but it worked well. Its not too hard of a job. Just be careful to not damage the new ones when you put em in.
Build thread^^
riot1987 is offline
post #6 of 15 Old 01-23-2013, 07:11 AM
KJK
I popped the old seals out with a broom stick. You could also use a piece of conduit or whatever. Stick it in the tube (like the axle) and you can catch the edge of the seal and knock it out.
There is room in the diff. housing to tap the new seals into place with a hammer. You'll need a very short piece of capped pipe to set the seal so you don't hit it directly with the hammer because you are driving it in from it's backside.
5.9 ZJ SCT tuned PCM/ KJK CAI/ Thorley headers with 3" Magnaflow cat and muffler/ Modded kegger/ TransGo shift kit/ Vanco brake kit/ Braided steel brake lines/ Mopar cupholder insert!
KJK is offline
post #7 of 15 Old 01-31-2013, 10:06 AM Thread Starter
xcaliber81
where should i get the new axle seals from, just get the ones from the parts store or is there a better quality set i should be looking for.
post #8 of 15 Old 01-31-2013, 10:23 AM Thread Starter
xcaliber81
ok nevermind they are only 16$ each from mopar so i ordered up a set.
post #9 of 15 Old 01-31-2013, 01:55 PM Thread Starter
xcaliber81
just wondering if i am replacing the front axle seals is there anything else i should replace that's not to major to do.
post #10 of 15 Old 02-01-2013, 07:23 AM
riot1987
You will be pulling axles so look at your ujoints/cv's now would be a good time to replace them if needed
Build thread^^
riot1987 is offline
post #11 of 15 Old 02-01-2013, 07:29 AM
riot1987
Check out your carrier bearings as well
Build thread^^
riot1987 is offline
post #12 of 15 Old 02-01-2013, 08:50 AM Thread Starter
xcaliber81
the carrier bearings are they the ones that go around the edge of the axle shaft, the pinion bearing is obviously behind the pinion right. If so are they an easily replaceable item because i am no diff expert and i definitely do not want to screw anything up.
post #13 of 15 Old 02-01-2013, 04:27 PM
riot1987
The carrier is what the ring gear is attached to and what houses your spiders. At each end of the carrier you will have bearings. They take some elbow grease to get them off but its not too hard. Youll need a press or a vise to press the new ones on. DONT HIT THEM ON WITH A HAMMER
Build thread^^
riot1987 is offline
post #14 of 15 Old 02-01-2013, 05:07 PM Thread Starter
xcaliber81
By replacing the carrier bearing will there be any type of backlash to deal with I was asking around and was told it might be to troublesome, there is a low pitched hum in 4 wd only from the front.
post #15 of 15 Old 02-01-2013, 05:35 PM
riot1987
All my bearings have come out well. Make sure you put any spacers you might have back on the right side.
Build thread^^
riot1987 is offline
