How to: Fix a cracked, broken or holes in your bumper cover - JeepForum.com
post #1 of 15 Old 07-19-2012, 08:17 PM Thread Starter
Area.3.Fiftyone
The bumper cover on my ZJ is not the correct one for my model (Limited) and while most people would never notice, I do and it does bug me even though it's been trimmed quite a bit to clear my 35's.
My original one was cracked pretty bad and the PO really did a bad job of painting it with a rattle can and there were holes in it from a previous license plate bracket.
I had another 96-98 bumper cover laying around, but it was not the Limited model and the lines are slightly different. It too has some holes from a front license plate, and I temporarily drilled more holes in it and mounted a Euro plate on it from a friend in Czech for a different look.
Well, I finally came across another good Limited front cover in the junk yard a couple of weeks ago that was in pretty good shape. These things are really hard to find used that aren't all beat to hell, chipped, cracked or broken in some way. The only thing wrong with this one are a couple of light scratches and yes, previous holes from a front license plate.
Here is what I did to fill the holes.
  1. Clean the area very well with soap and water
  2. Using a soldering gun and another piece of the same bumper cover material left over from when I trimmed my old one, heat and melt the plastic into both sides until it's relatively flat. Put more in than you think you need.
  3. After the plastic has cooled, take a sharp razor blade and carefully shave off any high spots.
  4. Lightly sand the repaired area with 220 grit sand paper. Use a block to keep the panel straight.
  5. Fill any remaining imperfections with either more plastic, glazing putty or bondo. I chose to use glazing putty because there were only tiny pin holes and I already put the soldering gun away and got lazy.
  6. Lightly sand again using 400 wet/dry sand paper and it's ready for paint and primer.
I need one more light coat of glazing putty on the holes I filled in and a couple of minor scratches. More pics once I get this done and ready for paint.
Obviously the same thing can be done with the textured bumper covers, but you have to be real careful when melting the plastic in. You won't be able to fill any imperfections on the raw cover so take your time.
This procedure also works well for large cracks. Just heat and melt some donor plastic into the crack from both sides.
IMG_20120718_132037.jpg   IMG_20120718_132102.jpg   IMG_20120718_132048.jpg   IMG_20120718_132355.jpg   IMG_20120718_133933.jpg
79' CJ7 - 82' CJ8 - 94' YJ - 96' ZJ
Diagonally parked in a parallel universe.......
Area.3.Fiftyone is offline
post #2 of 15 Old 07-20-2012, 04:26 AM
speedbucket
I seriously thought it would just be a pic of a torn off bumper cover
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #3 of 15 Old 07-20-2012, 05:07 AM
gearheadnick
This works on most types of plastic. I learned to "weld" plastic years ago using my pencil tip soldering iron and a zip tie as a filler rod. One thing you want to do when working with melting plastic is to put a fan on yourself to blow the fumes away, it's not fun breathing that stuff in.
My cylinder head overhaul:
My transmission overhaul: http://www.jeepforum.com/forum/f13/how-change-transmission-electronics-1560948/
gearheadnick is offline
post #4 of 15 Old 07-20-2012, 05:41 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Nice, I was just thinking of a bumper sticker.
Well done.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #5 of 15 Old 03-04-2014, 08:01 PM
ZeeJay1997
you guys think i can fix this with a soldering iron and donor plastic. it was just melted on there to begin with.
ZeeJay1997 is offline
post #6 of 15 Old 03-05-2014, 03:19 AM
gearheadnick
Should be no problem. And it's a good place to learn if you've never done it, since it won't be seen.
post #7 of 15 Old 03-05-2014, 04:16 AM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
The HF kit works pretty good, comes with filler rod. Used it when I transferred 5.9 trim to less faded panels.
Originally Posted by HighLonesome
coralman is offline
post #8 of 15 Old 03-05-2014, 07:07 PM
ZeeJay1997
the cover had tabs on it that the block was slipped on to, then the tabs were melted to hold the block to the cover. Those tabs snapped off.
i dont know how i can duplicate that process with a heat gun... unless i build the tabs back up and file them to size... X6
I am looking into adhesives. Pricey but may be worth it in time
Opinions?
post #9 of 15 Old 03-05-2014, 11:45 PM
Myusername1674
same
95 FiveTwo ZJ, DD, Lifted, Locked on 35s,
(in progress)
Myusername1674 is offline
post #10 of 15 Old 03-06-2014, 03:22 AM
gearheadnick
I would just melt the edges into the bumper, being careful not to melt through to the front. And use lots of filler material. I prefer zip ties myself, I've found the nylon to work well when it's mixed with plastic.
post #11 of 15 Old 03-06-2014, 04:28 AM
ZeeJay1997
i can see myself melting a a hole in it now. i forgot to mention that the two pieces are different type plastic. TPO and TEO.
post #12 of 15 Old 03-06-2014, 02:21 PM
gearheadnick
I've never let details like that stop me before
Personally I'd try it anyway.
post #13 of 15 Old 03-06-2014, 02:38 PM
x10radsponge
JB weld... I did mine. Yet to put it on, but I did it...
x10radsponge is offline
post #14 of 15 Old 03-06-2014, 04:52 PM
joe19934
The HF kit works fine you just have to be patient & take your time !
I fixed the rear bumper cover on mine it had a 3'' crack down the driverside.
If You can't Go Around It then Go Over It !!!!!!!!!
joe19934 is offline
post #15 of 15 Old 03-06-2014, 04:55 PM
joe19934
I would try using Gorilla Glue Epoxy, it should do the trick
Scuff up both pieces then apply epoxy !
joe19934 is offline
cracked bar running length of valve cover demjets01 ZJ Grand Cherokee Forum 7 11-10-2011 09:31 PM
'04 WJ, what lights to put into the round bumper holes? JeepsOLot ZJ Grand Cherokee Forum 5 12-29-2008 05:19 AM
power loss and cracked valve cover QuadraTokn ZJ Grand Cherokee Forum 31 07-09-2007 07:15 PM
Holes in valve cover..? 02jeepGCL ZJ Grand Cherokee Forum 4 04-03-2006 09:46 AM
my attempt at hiding holes drilled in bumper.. before and after . .yes or no sanboy ZJ Grand Cherokee Forum 26 03-02-2006 03:31 PM
