How far can you drive without a serpentine belt? - JeepForum.com
post #1 of 27 Old 01-18-2007, 08:59 PM Thread Starter
SPL Tech
I know this is a dumb question but I am asking it. Can you drive 1.7 miles on a flat surface without a serpentine belt on a 1994 ZJ with the 4.0L if the engine is cool from the start? Will the engine over heat that fast being that there is no coolant pump or fan running? Also do you have oil pressure if you have no belt?
SPL Tech is offline
post #2 of 27 Old 01-18-2007, 09:10 PM
Reswob
I'm gonna go with....no. Where are you trying to go and why don't you just replace the belt where it is now?
'11 WK2 Limited 5.7
Looking for a WK2 full size spare tire and 18" rims
Reswob is offline
post #3 of 27 Old 01-18-2007, 09:17 PM Thread Starter
SPL Tech
The belt is fine. The thing is I am stripeing down my Jeep. I need the two aftermarket alternators in the Jeep. The problem is they take a long time to take out and I dont want to do it in the -10 degree cold. So my shop is 1.7 miles from my house. Well the Jeep is not going to be driven untill summer so I dont need to put a new belt on tell summer. It would make things 10x easier if I could just drive it home without a belt because I dont have a AC compressor anymore and thus I have to pretty much randomly guess as to the new belt size and that will take many trips back and fourth to the automotive parts store. But if it cant be done I will just pull the alts at home I guess then.
SPL Tech is offline
post #4 of 27 Old 01-18-2007, 09:50 PM
adgjqetuo
adgjqetuo's Avatar
Suck it up and walk there
Just kidding... you don't know anyone who you can get a ride off of?
04 Jeep grand Cherokee Overland - Sold
98 Jeep Grand Cherokee Laredo SE - Sold
adgjqetuo is offline
post #5 of 27 Old 01-18-2007, 10:05 PM
JeepZJ94
1994 ZJ
Well it might be possible. I did this with a friends xj. The motor was already blown and the belt was gone. But other than the harder than hell steering and some other minor difficulties it was done. It was dark out too and couldn't use the lights because it would drain the battery to quick.
Why dont Money Grow On Jeeps?
1994 Jeep ZJ. 5.2L Engine, 3.5" Lift. 15x7 Steel Wheels w/BFG AT's, Push bar with 6" lights. Factory tow package. Bigger tires to come and much more.
RnR 4x4 Club
JeepZJ94 is offline
post #6 of 27 Old 01-18-2007, 10:25 PM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Steering will be difficult...overheating may be possible if it gets much above 10 deg I bet...battery will be drained pretty quickly...
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #7 of 27 Old 01-18-2007, 10:26 PM
camjamsdad
I drove about 4 miles without mine a couple weeks ago. The AC idler pulley locked up and broke the belt. So I pulled over let it cool down (at Taco Bell) then fired it back up. Pulled out on the road, got up to speed, shut it off, coasted to the red light, repeated till I got home. I live in Florida and it wasn't -10. Just keep a close watch on the temp gauge.
camjamsdad is offline
post #8 of 27 Old 01-18-2007, 10:27 PM Thread Starter
SPL Tech
Well does the oil pump still run? I was not sure of the water pump pully also ran the oil pump. Because without oil the thing wouldent last 3 min.
SPL Tech is offline
post #9 of 27 Old 01-18-2007, 11:00 PM
sgarlic
Oil pump is not driven off a belt. Its driven off a gear.
You'll overheat within a minute or so without the water pump spinning.
96 5.2 Ltd - Flame Red - Every factory option except engine block heater,
, removed silencer, 15% tint.
sgarlic is offline
post #10 of 27 Old 01-19-2007, 04:41 AM
greasefingers
greasefingers's Avatar
1994 ZJ
Of course you can make it. Just be smart about it. Watch your temp gage. Stop the engine if necessary. Dress warm! Have a friend follow you!!!
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #11 of 27 Old 01-19-2007, 05:18 AM
Turbonut
I agree with Steve, no problem as you'll only be driving maybe 2 minutes most. If it's dark and battery is good, you'll have lights also for that time, but as they have said, no power steering.
Turbonut is offline
post #12 of 27 Old 01-19-2007, 05:28 AM
Katesdad
Katesdad's Avatar
Piece of cake ...like these guys said just watch the temp gauge. Gets hot shut it down til it cools ...have someone follow with a warm car
Katesdad is offline
post #13 of 27 Old 01-19-2007, 05:32 AM
greasefingers
1994 ZJ
Oops forgot about the PS. Yea I having me jeep a short distance without the PS. It is a huge choir to make turns at low speeds! I would call it dangerous. Thanks for pointing that out Turbonut.
Cheers Steve
post #14 of 27 Old 01-19-2007, 07:22 AM
98zjdave
oh this is definately possible. i was coming home one morning at 4:30 in the am in my mustang hatch 5.0 and the belt broke. I didn't know at first and went to turn a corner and the steering was out of control, and the alt light came on. Looked down at the temp and it was slowly starting to climb. Sure enough no belt and about 4 miles from the house! I let the car cool down to a cooler degree, then drove home without a problem.
98zjdave is offline
post #15 of 27 Old 01-19-2007, 08:15 AM
ajmorell
ajmorell's Avatar
That's a little exagerated. My dad lost the belt on his old F150 and drove it for another 10 min to the nearest exit off the highway without overheating it.....and it was already up to temp.
ajmorell is offline
Serpentine Belt Nofear6372 ZJ Grand Cherokee Forum 8 05-16-2008 09:41 AM
Serpentine Belt Bricolage ZJ Grand Cherokee Forum 1 04-13-2008 03:24 PM
'96 - Serpentine Drive Belt muzicman82 ZJ Grand Cherokee Forum 10 10-29-2007 07:55 PM
Serpentine belt on WJ. rrubio ZJ Grand Cherokee Forum 9 01-06-2006 06:50 PM
Help with serpentine belt. ibms10 ZJ Grand Cherokee Forum 3 03-31-2002 08:15 AM
