How f'ed is my D44a rear axle? - Page 3 - JeepForum.com
post #31 of 38 Old 06-28-2013, 08:18 AM
PolkaPower
Originally Posted by leftfield6 View Post
I guess I'm guilty of assuming then. When I see a 6 inch lift in someone's signature I assume that they do a fair bit of wheeling.
It will be interesting to see if I have a different experience with the D44a than you did. Your setup is far from a stock configuration. You may DD it, but it's not set up like most DDs.
My niner sits at stock height and always will. It's rolling on BFG Long Trail tires (basically a street tread all season tire) in the stock 225 size. Brand new Bilsteins all around. Original 249 transfer case with brand new VC. The only "mod" on the engine will be the plenum repair I have planned for a few weeks from now.
My expectations for this vehicle is that it will occasionally commute me to work on days to knurly for my motorcycle, occasion long interstate trips to see family, possible snow when I visit family, and occasional towing. Towing will mostly be the motorcycle trailer, the utility trailer with yard project stuff, very rarely a tow dolly with a project car.
We'll see how it holds up.
You should cut the runners and trim the injector bosses when you have the intake off for the plenum repair. I thought about doing that but I was too lazy but now I wish I had.
PolkaPower is online now
post #32 of 38 Old 07-01-2013, 06:54 PM
Taz360ZJ
1994 ZJ
I'm curious how yours will hold up actually. I guess I'm getting my moms stock 5.9 from what I understand. I know that 44A is noisy, and its getting a 242 swap. I'm debating new bearings in that axle & seeing how they hold up. They are the same carrier bearings 8.8's use believe it or not.
'94 ZJ, AX15, UC+BB, Ravine's, 31's, 3.8L fan, D2S's, fully murdered out.
Taz360ZJ is offline
post #33 of 38 Old 07-02-2013, 09:26 AM
speedbucket
The carrier bearings aren't the problem on a 44a.....the aluminum housing is.
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #34 of 38 Old 07-03-2013, 09:41 PM
Taz360ZJ
1994 ZJ
Have you not read this thread at all? I was trashing swapped in 44A's under gen 1 ZJ's when WJ's were still in production.
Taz360ZJ is offline
post #35 of 38 Old 07-04-2013, 03:48 AM
speedbucket
The aluminum housing allows the races to spin in the caps....the housing is why they fail
post #36 of 38 Old 07-04-2013, 09:26 AM
Taz360ZJ
1994 ZJ
Uhhhh yeah....tell us something that leftfield6 & I did not cover already on the first 2 pages.
Taz360ZJ is offline
post #37 of 38 Old 07-05-2013, 12:24 PM
speedbucket
And maybe you should read your own damn posts ^^^
You compare the 8.8 to the 44a bearing and I say the housing is the problem not the bearings and you get pissy. Change your tampon.
post #38 of 38 Old 07-05-2013, 05:58 PM
Taz360ZJ
1994 ZJ
I haven't had the covers off...let alone the carrier out of the white 5.9 yet since she bought it 3 years ago. They live an hour & a half one way, not driving all that way just to see if the races spun in the housing like my 44A's have. I'm pretty sure it hasn't been rebuilt yet, its bone stock and the last 2 owners were women, it hasn't been used to tow anything. My mom ain't that hard on drive line parts.
If the races haven't spun....I'll slap bearings in it & drive it & hopefully it will last long enough to long arm & 5 speed my slate 5.9. If they have....8.8 will be going under it.
Same carrier bearings bro.
Its expensive enough dd'ing a large thirsty ZJ, let alone taking on another 5.9 that needs maint first. Yes I know the alum housing is junk..I just hope THIS one isn't trashed yet to last a little longer.
Taz360ZJ is offline
