How Do You Set The Memory Seats In A WJ Limited - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > How Do You Set The Memory Seats In A WJ Limited
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFather's Day & Moving Day Sale!Engo winch sale-- Best deal you will find. and FREE SHIPPI
Unread 05-04-2006, 03:30 PM   #1
gambit023
I have a question regarding my memory seats on a 2003 GC Limited. I’ve been following the owner’s manual directions by doing:
1. Turn ignition to on position
2. Press memory button #1
3. Press Set button
4. Adjust seats then press #1 button
Here’s my problem. When doing step 2 my seats will move to the position that it had in its memory which was for the previous owner, and when pressing the Set button it’ll move it to yet another position.
It will not save my settings. I’ve even tried to skipping step 2 and starting off by Ingition On then pressing the Set button, but that doesn’t work either.
Is there some type of trick to this?
Any info would be greatly appreciated.
gambit023 is offline   Reply With Quote
Unread 05-04-2006, 03:49 PM   #2
Briandl
I thought it was:
3. Adjust seats
4. Press Set button
5. Then press #1 button
2002 Jeep Grand Cherokee Limited 4.7L H.O. V8
Briandl is offline   Reply With Quote
Unread 05-04-2006, 04:08 PM   #3
skatingbo
Hey
First start the car up and the way I set mine is set the mirrors, seats, and radio, then hit set and the number you want to set it too. make sure you seatbeat is not clicked in, it will not
work if it is and the car has to be in park.
Mike bo
skatingbo is offline   Reply With Quote
Unread 05-05-2006, 03:33 PM   #4
HawkeyeWJ
Mike bo
That is exactly how I've done mine and that procedure should work perfect for you! Good luck!
Jeepiki.com - Jeep Encyclopedia
2002 WJ 4.7 Limited
Onyx Green Pearl
HawkeyeWJ is offline   Reply With Quote
