how do you remove front bumper of a 97 zj - JeepForum.com
post #1 of 9 Old 02-22-2005, 06:36 PM Thread Starter
1997zj
im curious of how to remove the front bumper of my jeep. I found what looks to me to be push pin type things in the wheel wheels? what is the best proceudure to remove the bumper?
1997 Jeep Grand Cherokee Laredo i6
235/75/15 bfg's all terrains
plenty of trail damage
Future upgrades...
31x10.5 bfg all terrains
3 inch rustys suspension lift
steering stabilizer (any suggestions)
jks quick disco's
1997zj is offline
post #2 of 9 Old 02-22-2005, 08:12 PM
WVZJ
Take those plastic pin things you described in the wheel well and pull them out. I've used needlenose pliers in the past they work ok. There are also a couple in the front bottom part of the bumper under the radiator. Once they are out pull each side off (there is a stud on the metal bumper underneath the fascia that the fascia slides into to hold it).
98 ZJ 5.2, LA n Locked, 242 sye, 35's
87 MJ, 4.0, 8.8, 33's, oba
07 Ram 2500 5.9 ctd
WVZJ is offline
post #3 of 9 Old 02-22-2005, 08:52 PM
PlatinumZJ
Senior Moment Member
PlatinumZJ's Avatar
You have got to remove the grill to get to the 4 screws in the top of the bumper cover. Also, there is slots on the sides of the bumper that slide onto pegs. once you have all the screws and plastic pins it pulls off to the front. It might be easier to do one side then the other.
Doug
When all is said and done, more is said than done.
Platinum '97 ZJ LTD, I6 (see profile) Paid for!
Links:
for ZJ & WJ stuff,
for performance stuff. I6 performance info at
Other stuff: Kevin's Roof Rack. KOR sliders, Bored 62mm TB, Blaupunkt Bermuda w/ ipod, Brembo Slotted rotors,
OME steering stabilizer, H4 headlight upgrade...
PlatinumZJ is offline
post #4 of 9 Old 02-22-2005, 10:09 PM
Brian's 97 ZJ
Brian's 97 ZJ's Avatar
What they said and when you are squatting down pulling on the bumper to remove it, if it happens to suddenly break free and you fall a$$ first into a drain pan full of used oil, I'll understand your frustration.
- Brian
For some reason, being a member of the
just isn't as cool... Member #1
Brian's 97 ZJ is offline
post #5 of 9 Old 02-22-2005, 10:23 PM
Trailzj
Here's the best procedure to remove the front bumper.
Al
2 1/2" lift on 33" Pro Comp Xterrains
I traded my ZJ for an AR15
Function before fashion
Trailzj is offline
post #6 of 9 Old 02-22-2005, 10:25 PM
Derek33
Derek33's Avatar
i suggested hooking up a rope. one end to his front bumper, the other to the tow hitch on my jeep... should be quite simple.
Derek33 is offline
post #7 of 9 Old 02-22-2005, 10:41 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Once again Al, I too used that method at first. Not the most forgiving method.
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #8 of 9 Old 02-23-2005, 01:38 AM
Trailzj
True Hunter, I wasn't able to reinstall so I have been bumperless ever since.
Trailzj is offline
post #9 of 9 Old 02-23-2005, 05:32 PM
freak4jeeps
freak4jeeps's Avatar
I just used a small tree and a slippery rock and mine popped right off. Oh wait I had to use reverse to....the rest I leave to your imagination.
Later, J
98ZJ 4.0
  • RE3.5" Super Flex
  • 32" BFG ATs on 15x8 Hellcats
  • JKS Quicker Discos
  • Adj. Tbar F/R
  • Flow 40 Series
  • Kevins Sliderz
  • Custom Front Bumper(Fab'd up by a tree)
you don't need lockers.
Got
freak4jeeps is offline
How to remove ZJ rear bumper? sp9861 ZJ Grand Cherokee Forum 4 12-31-2008 09:15 AM
How to remove front bumper cover aaron7 ZJ Grand Cherokee Forum 7 03-25-2008 10:23 AM
How do i remove my bumper? Jmila1901 ZJ Grand Cherokee Forum 7 09-12-2007 08:00 AM
How do I remove front bumper cover on 99 GC Shawn w ZJ Grand Cherokee Forum 5 11-26-2006 02:23 PM
Should I remove my bumper? coolest_Stan ZJ Grand Cherokee Forum 12 03-29-2005 10:32 PM
